Question about Adcom Audio Players & Recorders
Weak left channel
More sound received from right channel than from left. balance set correctly,speakers work fine
techman
  • 3130 Answers
SOURCE: no surround sound
So your saying that you have no rear channel. Some recivers use a single stereo output ic for both sides on the rear speakers. you could have a defect with this IC . Anther thing Im sure you check3ed the obvious ie : the switch is on suround sound? If there is a front to rear fader is it in the middle? Good Luck
Posted on Jun 04, 2006
babb
  • 104 Answers
SOURCE: ASUS P4S800D sound card problem
Check to see if your audio header is hooked up correctly on your motherboard if your using the front panel audio, if your not using the front panel audio then make sure the audio header has the two jumpers on them!! Check your mother board manual for proper procedure to hook up! If that still doesn't help then it could be a faulty sound device! You can fix this buy purchasing a new sound card! hope this helps! regards, babb
Posted on May 05, 2007
SOURCE: Hp speaker problem. Please help
I have no sound at all, HP Pentium 4...please help
Posted on May 28, 2008
SOURCE: tivoli model two - low/no sound in base unit
I have exactly the same problem but found two work arounds, either one that I am completely satisfied. 1. unplug and replug the AC.
2. I have a subwoofer, when I plug the subwoofer cable half way in, the sounds of the base speak goes back to normal (but not all the way in)
Posted on Nov 22, 2009
SOURCE: Yamaha RX-550 receiver. Presently, no sound on
were you able to solve this one ? I have the same problem with mine. The only way to clear the lack of sound in one of the speakers is to rotate the input knob !!
Posted on Dec 20, 2009
No left a or b speakers
have you checked the speaker balance position as what you describe indicates you have the setting all the way to the right
Oct 03, 2016 | Audio Players & Recorders
Subwoofer
go to audio set up and configure the system for 5.1 or higher sound output.then only all the speakers ll work
Jan 03, 2008 | Yamaha RX-V640 6.1 Channels Receiver
Balance control
The channel that is weak will either have a faulty transistor or a bad capacitor on it. Most engineers would test it by injecting signals into the circuit at different points. Working backwards from the front end. When the signal goes weak, you have found the faulty stage.
Jul 02, 2017 | Yamaha RX-V690 Receiver
How do you balance sound between two speakers. Where is the balance control? JVC RX5000v
On the front panel ONLY:
1. Press ADJUST so that the MULTI
CURSOR up/down buttons work for
adjusting the sound.
2. Press MULTI CURSOR up/down
repeatedly until "BALANCE"
appears on the display.
3. Press MULTI CURSOR left/right to
adjust the balance.
• Pressing left decreases the right channel
output.
• Pressing right decreases the left channel
output.
please rate my solution.
Jul 04, 2011 | JVC RX-5000V 5.1 Channels Receiver
I have a Pioneer VSX 452 receiver. I am trying to run a second set of speakers off the b channel and use the a and b switches on the front of the receiver. If only the a channel is depressed the two...
Thanks for the detailed explanation...
It seems to be there is a short or misplaced (+) (-) leads on the speaker connection you made..sometimes a tiny cable piece can make a short in between the leads and cause such problem..My recommendation is:
** take all the wires off..
** install only B speaker leads and test it..( make sure LEFT and RIGHT (+) and (-) leads properly
and individually connected to the right places on the back......it is important...This causes balancing problem..
** if it works fine...
** than go ahead and install the A speaker leads..and test it..
if you do everything properly both A and B speakers should work fine as independently ...
Take care and if it succeeds please Remember to rate/vote and give me 4 Thumbs Up
for Helping out the Community :)
Hope this helps!
Jun 22, 2011 | Pioneer VSX-454 Receiver
I have a cambridge audio Azure 540R. WAs all working fine. A red box with SW under the L speaker channel has appeared. No sound from the L speaker, Although the test sound through the L channel is ok. The...
Register and download the manual for free at retrevo.com
http://www.retrevo.com/s/Cambridge-Audio-540R-Receivers-review-manual/id/2536dj197/t/1-2/
"SW" stands for SubWoofer.
Page 8...
Shows the currently active channels depending on decoding mode and source material. Icons lit indicate active channels in the source material. Icons with a box around them indicate actual channels being output separately.
Search for the word "balance". Page 8 again (circled 8)...
Lights when the Front Left and Right speaker outputs have been set to different levels in the OSD, i.e. a balance adjustment has been made.
You can look at the relative levels of all channels as described on Page 14.
Mar 22, 2011 | Cambridge Audio Azur 540R Receiver
Str-gx800es sony receiver problem- right channel speaker sound is 'static', low and distorted. I have checked checked all speaker and output/input source cable connections with no luck. All left channel...
If you have checked the speakers and wiring, the right channel has a audio driver or output problem, which explains the low volume, static, and distortion. A service technician will be required to fix the receiver so it will balance the left side.
Jan 10, 2011 | Sony STR-GX800ES Receiver
Sony AV Recever STR DE 675 weak right channel
What' are the answers to these 2 questions:
How does it sound when you run through the speaker setup routines? Page 19 - 21 in the manual.
Do all sources do it?
Feb 21, 2010 | Sony A/V Receiver
My l/r channel will not work
With the radio on u will need to push audio button it will change to something different on the face push until speaker balance comes up & then push butons below it left or right to balance each side of speakers. For me it was the left speakers that i needed to balance good luck John
Jun 06, 2008 | Pioneer DEH-1600 CD Player
22 people viewed this question
Top Adcom Audio Players & Recorders Experts
 Grubhead
Grubhead
Computer Links
David Burbee
David Burbee
Are you an Adcom Audio Player and Recorder Expert? Answer questions, earn points and help others
