Hi pls which direction do i turn the middle knob(written temperature ) in order to get the best cooling/chilling effect from this portable indoor AC??
    New Friend:
  • 7 Answers
Turn it clock wise for best cooling, more blue, more cooler
Posted on Dec 09, 2012
22yooper
  • 828 Answers
SOURCE: I have an older unit need to know what the top knob does
One of the knobs controls fan speeds, cooling speeds and an off position. Center knob controls temperature and bottom knob more than likely controls air exchange. As for the front cover it would depend on the units age as to if it would be available.
Posted on Jul 05, 2008
SOURCE: Mr.Slim Mitsubishi dual zone system
We had that problem with two units that we just had installed. Both are hooked up to one compressor. After several calls and the service person coming out twice, it turned out that they had two wires mixed up when they did the installation. Once they switched the wires the units ran ok.
BUT...now we are having another problem with the units/compressor not working after losing power in our house. We lose power on a regular basis here. Does anybody know if that means we will constantly need to call the service people to come to get the compressor working again? Or is there anything we can do to reset it? The service person that came today was not very helpful and didn't have a lot of answers for us.
Thanks
Posted on Jul 23, 2008
jgwhomeequip
  • 1902 Answers
SOURCE: my room AC , gives not 100% cooling air, ita gives
Check the outdoor side of your unit. Make sure that nothing is blocking the back and also take a hose and clean out the fines of the AC unit. If problem still persists after that, then check to make sure that the internal filter is not blocked or dirty.
Posted on May 17, 2010
  • 7 Answers
SOURCE: Hi my Hitachi Quadricool Win ac cooling does not
service and checked the gas you see ice is coming or not on cooling coil
Posted on Jul 29, 2010
mpcheeseman1
  • 1400 Answers
SOURCE: Hi. I recently installed 1.5 T, 3 * Split AC, LG.
Hello
Sounds like the compressor is shuting down on high heat.There could be a couple reasons for this.
1 Check that proper voltage is being supplied to compressor.
2 Freon level may be low.This would be a service call.
3 Bad or intermitent connection at thermostat.
4 Main contacts to compressor sticking,usually burnt or pitted.
Posted on Apr 08, 2011
2011 Crown Victoria Police Interceptor overheating problem: I observed that the temperature gauge indicator reached the highest point and the warning light lights up while driving with the AC switch is...
nothing to do with the ac charge
the fan not running is a problem so check out the relays , fuses and temperature sensors that control that fan
Nov 03, 2017 | AC Cars & Trucks
Why is the refrigerator side is freezing food
First some fridge 101, the refrigerator/freezer models cool by directly refrigerating the freezer section and the refrigerator section is cooled when "some" of the cold air from the freezer is directed over to the refrigerator side (typically by a fan) to keep food fresh and not frozen a temperature controlling damper opens and closes to regulate the temperature of the fridge by introducing more or below freezing air into the cabinet. In older models where the freezer was on top the air simply "gravity" drained into the refrigerator cabinet, if the food was too cold you turned the fridge knob up and less air sank from the freezer to the fridge, simple but effective.
When you adjust the temperature level it controls the freezer temperature and this turns the compressor on and off to keep the food frozen. There is typically a knob or lever and some even have electric dampers that open and close to direct more or less air from the freezer and direct it to the refrigerator cabinet based on your temperature requirements.
Now that you know how it works there are a couple things to check. If the condenser coil is plugged with dust the internal system pressure will rise and in some cases make the fridge an over achiever and can chill too much so check/clean the condenser coil. Check the freezer temperature control and turn in up, also make sure the fridge temperature control setting is not set too cold.
Finally as the temperature changes around the refrigerator it will have an effect on the inside of the fridge too so expect to turn it up and down as the environment changes, down in the summer and up in the winter.
Hope the novel helps to resolve your issues.
Nov 01, 2017 | Refrigerators
Goodday.Pls how do I regulate the middle knob to realize best chilling from my Air Conditioner?
Hey, just where did you put the middle knob? If you have it, put it back on and turn it all the way clockwise tgo get the coldest setting of the thermostat where the 3 blue lines are.
Dec 24, 2012 | Heating & Cooling
Beverage Air MT17 cools sporadically. I turn the temp control setting to 5 and it will go down to 28 degrees F and the next day it will be at 55 F. I have to turn the control knob to off position then turn...
Low refrigerant would make it inefficient but if it chills to 28° it can't be that bad. I think you have a control issue. The compressor runs when you reset to off & on, then chills until it satisfies the thermostat, then shuts off. But then is not starting again when the temperature rises. You'll need to follow the control wiring to see what contacts are open and not passing power to the compressor. Control wiring is typically 24v ac or 115v ac. There's also the possibility that the compressor is tripping out on overload at 28°. You effect a reset when you turn it off, then on.
Mar 26, 2017 | Beverage-Air MT17 Refrigerator Commercial
I have a Daewoo Air Conditioners dwc 055rl can i plug it into a regular wall outlet
features Cooling Capacity 5,340 BTU/h 10 Energy Efficient Rating Cooling Area (sq. ft.) 100 to 150 Low Noise Operation Washable Air Purifying Filter Effective Dehumidifying Operation Indoor Temperature Sensing Thermostat Window Kit for Easy Installation Power Supply (V/Hz): AC 115V/ 60Hz Power Consumption: 525 W
Answer = yes regular 115 vac outlet
Aug 21, 2010 | Daewoo DWC-056CL Air Conditioner
My a/c won't blow cold and heater doesnt get hot
Is the heater working? Turn the A.C. off with the car at an idle. Turn the A.C. on and listen for the compressor to turn on. (should hear a click under the hood and the motor should change pitch. If no noise, the compressor is not comming on. The o-rings were bad about leaking on these cars, letting out all the freeon. If there is no freeon, the low pressure switch won't let the compressor run.
May 20, 2009 | 1997 Ford Taurus
Jul 05, 2008 | Fedders AEQ07FBG Air Conditioner
Heating & Cooling Logo
66 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
