Question about Exercise & Fitness
Slimline treadmill error e01
Stops and give error e01
    Top Expert:
  • 12,223 Answers
Adjust the spee sensor, test for open or faulty, clean it, and tight the connector very well, see the diagram attached.
2) test the input voltage motor, if there are the motor need repAIR, see my personal TIPSO for motor help
3) test the ouput voltage board, for input voltage motor, if there are NOT the board is faulty.
God bless you
Posted on Dec 13, 2012
How do i get the e01 away and start the tredmill
How To Lubricate Treadmill
this error is coming from lack of lube
Let me know
Blessing
cuadra2016@yandex.com
cell+whatsApp: +50588611441
Jan 26, 2018 | Exercise & Fitness
I have an ninja 4 in 1 cooker. it comes up with an eo1 message. what can i do?
  1. The thermostat may temporarily lose calibration due to temperature changes resulting in an E01 error message on the display. Repeat the following steps to reset the unit.
  2. 1. Unplug the unit from the wall socket for approximately 10 seconds.
  3. 2. Plug the unit back into the wall socket.
  4. 3. Press the POWER button once. Within one second, press the COOK button once. The unit should now be reset
or Cooking pot is not inside the cooking system housing. Insert the cooking pot.
Search Results
SOLVED: When I turn it on I get E01 - Fixya
www.fixya.com/support/t305866-when_turn_get_e01 Dec 19, 2007 - When I turn it on I get E01 When I turn on power it is giving me E01. ... I had the same E01 error code. .... How to fix on a ninja crockpot e01. According to the manual it means the cooking pot is not inserted into the device.
ninja cooking system e01 error Questions & Answers (with Pictures ...
www.fixya.com > Forum > Tags Find solutions to your ninja cooking system e01 error question. ... ...fix error code eo1 and err i getting an error code eo1 and err and it not cooking For one, you ...
SOLVED: How to fix on a ninja crockpot e01 - Fixya
www.fixya.com/support/t17203774-fix_ninja_crockpot_e01 Mar 19, 2013 - how to fix on a ninja crockpot e01 - NINJA SEARious Slow Cooker question. ... According to the manual it means the cooking pot is not inside of the device. Same thing happened to ours .... you can use it. Here is a tip that will tell you how to fix the EO1 error code. ... ninja cooking system e01 e01. Feb 07 ...
Ninja cooking system e01 - Fixya
www.fixya.com/support/t23385060-ninja_cooking_system_e01 Feb 7, 2014 - ninja cooking system e01 e01 - NINJA SEARious Slow Cooker ... I have an E01 error code on my West Bend slow cooker, how do I fix it?
[PDF]3-in-1 Cooking System - The Home Depot
www.homedepot.com/catalog/.../3f/3f5a04f4-303f-482a-a702-eeb5ecab0bdb.pdf In the event of a loss of power, an error .... The Ninja® 3-in-1 Cooking System Steam Oven offers a revolutionary new way to cook your .... "E01" Appears on the.
ninja 4 in 1 cooker eo1 error - Google Search
Apr 02, 2017 | Kitchen Appliances - Others
Reebok z9 treadmill beeping with error e01,this happened once before then went ok,driving me mad any help please
Try to check the Speed sensor. Check for its aliment also check is there is any dust accumulated on it .
If you wish to get some details; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Sep 13, 2016 | Reebok Exercise & Fitness
Code error e01
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
Mar 01, 2016 | Exercise & Fitness
From the first use my treadmill keeps bip-ing and shows error E01. It is new, i just opened it from the box. It just won't start
HI There, what style or brand of treadmill? You said this is a new unit. Can you call the manufacturer for a replacement or service?
If this is a Horizon unit, this happens everyday to their customers!
If it's a Horizon T101, unplug treadmill, remove motor cover, look at motor control board, to the right of the PCB you may see ONE small blue block, this is a small adjustment pot, or potentiometer.
If you have found this to be exact, and there is only ONE pot there, you can turn this pot gently to the right all the way til it stops and the back it off just a hair and retry the tread. This is a current adjust that has caused trouble for Horizon since about 2011. If you need additional help google jatinah electronics. Good Luck!
Jan 20, 2015 | Exercise & Fitness
Error message : e01 f09
First try holding down the cancel button for 10 seconds and releasing (might have to do this 2~3 times). The technician manual is located under the lower front panel. I've heard that locating the CCU (brain box, in lower right) freeing it up and giving it a couple of wacks has worked. F09 is pressure switch, E01 is Thermistor. The tech manual will be a great help!!
Feb 16, 2014 | Whirlpool Duet 4.3 cu. ft. Front Load...
I have just used my LIME MT9 treadmill for the first time and it keeps stopping every few minutes with an E01 error message.
lube the deck belt and proceed according. However you must readjust the speed sensor + Reed switc. Run the software calibration for easy diagnose and fix it. see the diagram attached.
God bless you
Mar 23, 2013 | Lime Pro Lime Mt9 Treadmill Exercise...
Got carl lewis treadmill MOT566 IT SHOWING ERROR CODE E01 WHAT DOES THIS MEAN
1) this means a) problem with the speed sensor b) main motor problem c) main motor board faulty. see the block diagram attached.
God bless you
Jun 24, 2012 | Exercise & Fitness
Exercise & Fitness Logo
471 people viewed this question
Top Exercise & Fitness Experts
Howard
Howard
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
