Question about Dryers
Hi have a7yr old dryer vent is clean dryer run 10 mins and fire stops and dryer runs
  • 334 Answers
You probably have a clogged vent pipe.
This causes the unit to overheat and shuts down the burners.
Clear all lint from the pipe, the dryer exit inot the pipe, and the pipe exit from the house.
Posted on Jan 13, 2009
LG Model DLE1501W - I set the dryer for appropriate cycle. It shuts off after 10-15 mins or so. clothes are still wet.
The moisture sensors seem to be the issue. The two metal bars on the lint filter housing. Try cleaning with alcohol and stop using dryer sheets.
Dec 14, 2016 | LG Dryers
DRYER STOPPED VENTING SHUTS OFF AFTER 10 MIN
sounds like the lint is blocking the exhaust to outside vent, remove the vent and pipes from dryer and clean.
The second thing that may be a problem is the "thermister" , this is a temperature sensing device that may need replacing, the purpose for this is to prevent fires from overheating.
Mar 15, 2014 | Haier HLP140E Electric Portable Dryer
Sears lawn tractor
Check fuel tank or cap vent to be sure it is not plugged.
May 03, 2013 | Garden
Hi, the dryer keeps stopping (the timer jumps), only runs for about 10 mins at a time AND the part that worries me the most is that I haven't had to empty the lint trap which I usually do after e
sounds like the vent tubing is not hooked up as it should be and that can cause a lot of lint buildup inside of the dryer parts. take it apart again and clean out all of the lint because this is a fire hazard. make sure that the vent is connected to the lint trap and try working it again. it sounds like maybe the buildup of lint is making the drying hard to do.
Aug 27, 2012 | Whirlpool 8579123A DUET DRYER DR REVERSAL...
I have a kenmore gas dryer model 110.74894401. When the start button is pressed it sometimes makes a clicking sound and the dryer does not start. However, when the dryer does start it tumbles for 15-20...
how old is the dryer?sounds like the motor is bad.i see this when the owner doesn't clean out the dryer,it's not that hard to change out the motor,if it's in good shape and not to old go for it but you gotta clean the dryer out,you need to clean out the duct that the lint filter slides into,if you have a shop vac blow off all the lint on the motor and out of the heating box or tube and vac out all the lint and if the vent line is long remove it from the back of the dryer,go outside and make sure the outside vent is clear and then from the back of the dryer blow out the vent line with a leaf blower,i've seen bird nests blow out of the vent lines,you could have a fire in the dryer or the dryer will run hot and damage parts and your clothes will take a long time to dry.all a dryer does is move air,if it can't your gonna have problems,let me know what you find and how you make out,if i can help you with anything else let me know
Aug 29, 2010 | Kenmore Dryers
The igniter fires the gas, it burns for a minute or less, then stops and won't restart unless the dryer is stopped and restarted? Is this a coil problem?
Sounds like a clogged vent. If you let it run for a few minutes after it shuts off, it will come back on. Your overtemp. thermostat doesn't allow it to work, because the hot air is not being sucked in. But to answer your question, not the coils for sure in my opinion. When coils fail, it won't turn on after 10 min of running or more. Not right away.
Maytag Neptune dryer repair in orange county, ca
appliance repair orange county, ca
Feb 07, 2010 | Maytag MDG9206 Dryer
Dryer gets hot runs for 10 min, then cools off
Make sure the hot air vent to the outside is clean and has no more than two 90 deg bends in it.
If the vent tubing is restricted, the system will shut off the heat source to prevent a fire.
Make sure you take it apart and thuroughly clean it.
Good luck.
Regards,
Jul 04, 2009 | Dryers
Kenmore Series 80 (110.74882401) heat cycles on only for 10 secs
This is a pretty easy fix and I recently had the same problem. I made a quick video about it. The problem was the dryer was run only a few mins then quit. The dryer limit was tripping because the control thermostat was not shutting down the lower safety limit was tripping and the power from the control thermostat was diverted via the orange wire to the timer motor which kinda caused the main motor to stop. When i ran the dryer in NO HEAT the dryer stayed running and that was my clue as to what may of been happening and that was the problem in a nutshell. My video:
Jun 21, 2017 | Kenmore 659 Electric Dryer
Dryer will not stay on
thanks for the question. how long does the dryer run for 1 min 10 min 15 min if it runs for 10 min or more you could just have lint covering the motor so it cant breath vacuum the dryer clean the venting this could cause this problem thanks the appliance doc
Sep 15, 2008 | GE Dryers
Dryer runs for minutes then stops timer keeps going and going and .....
remove the vent on the dryer that goes to the outside start the dryer if it continues to ru n and not cut off you have a venting problem of the house
if it cuts off after 5 mins with the vent off you have a motor that is going bad
Jun 11, 2008 | GE DBXR463EBWW Electric Dryer
Dryers Logo
73 people viewed this question
Top Dryers Experts
