Question about Philips WACS700 Shelf System
How to replace hard drive
Show me how to replace harddrive
    Problem Solver:
  • 15 Answers
Hi, everything you need to know about to replace the HDD on Philips WACS700 can be found here: http://www.scribd.com/doc/12808150/14051wacs700-How-to-open-Philips-Streamium-WACS700-courtesy-of-AndrewT
I have done this myself and must admit that it is a bit fiddly. You need to be a bit handy, know your way around with electronics and have access to screw drivers/soldering equipment and electronics pliers.
Good luck.
Posted on Jan 20, 2013
  • Luca Borra
    Luca Borra Aug 07, 2017
    Dear stijnsg, is there any possibility to get the HDD image you saved? I got the same problem, the HDD is now on my desk, but there are many damages on the HDD. If you can send me the image, I'll probably be able to run again the system.
    Thanks,
    Luca
    superborra22@gmail.com
My lacie hard drive turnes on ,shows that its running,stops running and keeps showing pink light but does not show appearance on my laptop,
Right click "My Computer" and select Manage. In the window, select Disk Management on the left column. If the drive is not listed on the right column, then the BIOS has not detected the harddrive - it might have a harddrive password lock. You will need to go into the BIOS and unlock it with the password.
Nov 01, 2010 | LaCie External USB 2.0 500GB 7200 RPM 500...
I have samsung (Model hd501hi) hard disk but it
Hi. Sounds like a problem with the harddrive boot block. Try the torubleshooting steps i provided to you below. If same issue appears after thes troubleshooting then theres a need to replace your Harddrive.
* If you have a floppy try to boot with bootdisk http://www.bootdisk.com/
if you have a bootable windows CD - try booting that then go to the repair console.
have a good one!
Jul 29, 2010 | Samsung 250GB HD250HJ SATA II 300 7200rpm...
All my files on simpletech harddrive show as 0
you mean you HDD does not show the capacity it holds? try using it on another pc, or even try using it on your friends pc, see if it works?
Mar 28, 2010 | SimpleTech SimpleDrive 160 GB External USB...
Harddrive connects to computer but no files appear
Hi I have an Acer 5720 with 80GB hard drive, with windows vist, there is very little on it in the way of programs, yet the C drive is appers to keep filling up, D drive is empty, help please, thanks
Oct 08, 2009 | Western Digital My Book Home Edition 500...
Malfunctioning WD passport that windows doesn't detect.
Inside the case is a regular laptop size harddrive.
Laptop harddrives are 2.5 inches across. (2-1/2 inches. Desktop harddrives are 3.5 inches)
I would suggest the external enclosure the harddrive is in, is defunct.
I would suggest buying a new external enclosure, and putting this harddrive in it. Then just plug the USB cable in, (As you did before), and download your data, to be ready to transfer.
You need an external enclosure that is Sata, and is for a 2.5 inch harddrive. These are relatively inexpensive.
Let me show you some examples:
1.http://www.tigerdirect.com/applications/category/category_slc.asp?CatId=2783&name=2.5-eSATA-Hard-Drive-Enclosure&Nav=|c:2781|&Sort=0&Recs=10
May 10, 2009 | Western Digital Passport WDXML800UE...
Trying to copy harddrive to another harddrive. want to move to larger drive. problem is optiplex gx260 convertible desktop only shows 1 harddrive in my computer. only a c drive shows up. the secondary...
To clone a disc , acronis true image home is a very good software . A free software based on it is available from seagate called as disc wizard but it will only work with seagate drives. about hard drive not being detected , try upgrading your bios . Some bios dont detect new higher capacity harddrives. Do tell what is your drive capacity.
Mar 21, 2009 | Dell OptiPlex GX260 PC Desktop
Simple tech 500gb usb hard drive
Youve damadged the harddrive, is the harddrive spinning or making any noise?
Jun 16, 2008 | SimpleTech SimpleDrive Pininfarina 500GB...
Computer not reading the hard drive
i have formatted the hard drive and put in all three recovery discs and it still won't load windows xp home edition.. i thought that was what the recovery discs were for.. maybe the hard drive is bad i don't know but if someone is having the same problem i could sure use some help here..
May 10, 2008 | Balance CN6555 Notebook
Ibm thinkpad 390
This issue showed that the harddrive is not found. Try to fixed hardware connecting from harddrive and the board.
did you see hard drive detected in the bios at start? if your are sure that the connection cable is firmly fixed and the hard drive still not detected by the bios. so there is a problem with your harddrive. you should/may replace that.On the other hand if in case your hard drive is detected and still thesame problem encountered. then, you should reinstall your operating system by inserting the original operating system recovery/ windows bootable installation disc to refresh the state of your system.
any problem srising this solution please notify me.
Jan 23, 2008 | IBM ThinkPad 390 E Notebook
Philips WACS700 Shelf System Logo
454 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
