Question about KitchenAid 24 in. KUDI01FLSS Stainless Steel Built-in Dishwasher
Dishwasher blowing thermal fuse
My Kitchen Aid dishwasher keeps blowing the thermal fuse (fsp 661663) I replaced the fuse and it didn't make it through a cycle before blowing again. What could be the cause
  • 5 more comments
  • npriest716 Jan 22, 2009
    5th time in 6 months a blown fuse on a new kitchnaid dishwasher installed in a new home. Extremely frustrating and time consuming.
  • gorman941 Jan 23, 2009
    i have same problem, install new fuse and it went out on the 2nd use, it appears it may be related to cookware/hi temp wash cycle, will replace the fuse again and just use the other cycles to see if that works
  • Christopher Morse
    Christopher Morse Mar 11, 2009
    Hi I'm in the same boat. I've had the thing for 3 years and it just started happening. I agree with Gorman941. Seems to happen when I do the "sanitation rinse" mode.
  • Anonymous Mar 17, 2009
    I all so have the same problem fuse blows mid cycle changed it 3 times what is the answer besides a new product thanks norm
  • jmoore720 Mar 31, 2009
    Same as everyone else fuse keeps blowing going on third one in last 12 mo.
    John
  • Anonymous Apr 05, 2009
    second time my fuse blew as well ( i have kennmore but made by kitchen aid.) I think this thing gets really hot as i have noticed the insulation melt around some of the power lines. I suspect at times this thing draws more power than anticipated and thus blowing the fuse.
    if i can just figure out what amperage this the fuse is then i can replace it with a circuit breaker switch. the fuses are expensive to replace 20-30 dollars.
  • Anonymous May 17, 2009
    I have the same problem with the dishwasher blowing the thermal fuse and as mentioned, the fuse costs around $20. I went to an electronics store and bought just the thermal fuse for $1.96 and put it in the old fuse housing. In other words, replace the actual fuse in the blown one with a new one of the same temperature rating. The fuse still keeps blowing about every 6 months but at least its not costing me $20. I had the Sears repairman come the first time when the fridge was under warranty and he said that it is a common problem and did not know why the problem occurs. I have 3 fuse assemblies made up and it takes me about 5 mins. to replace a fuse.
huuum
  • 750 Answers
SOURCE: Cancel Light Flashing on Kitchen Aid Dishwasher
Hi 1cassie1,
Did you try to turn the power off at the breaker box?
This resets the whole system usually!
Let me know how it goes? Write me back!
Other wise you need a hands on tech.
ngafm
please give me a rating before you sign off!
Posted on Sep 11, 2008
aborcass
  • 2651 Answers
SOURCE: Kitchen Aid dishwasher Child lock light on and dishwasher will not start.
if your unable to unlock the "childlock" by holding down the button, then it woud seem that theres a problem with the user interface itself
Posted on Oct 19, 2008
  • 338 Answers
SOURCE: kitchen aid dishwasher doesn't clean dishes in the top rack
Sounds like you have 1 of 2 problems. Either your pump is clogged or you need a bigger drain loop.
Posted on Nov 25, 2008
localwonder
  • 6784 Answers
SOURCE: Kitchen Aid dishwasher is not cleaning like it use to
Check the following to address this issue further.
1. No water
Make sure you get water to the dishwasher. Check to see if the water shut-off valve (located under the sink) is open. If you get water to the dishwasher, but there is still no water inside during the fill cycle, the problem might be with a faulty water valve (located at the bottom of the dishwasher, behind the kick panel, on either side), in which case replace the water valve.
2. Not enough water
If there is not enough water, the dishes would not get cleaned. This could be caused by a partially closed water shut-off valve (located under the sink), or a faulty dishwasher water valve (located at the bottom of the dishwasher, behind the kick panel, on either side).
3. Clogged spay arms
There is usually two, sometimes three spray arms in a dishwasher. Make sure there is no debris blocking the holes inside each spray arm.
4. Water temperature is too low
To get the best results, the water has to be at 120 degrees Fahrenheit when entering the dishwasher.
5. Not enough soap
If you only fill one part of the soap cup, try adding soap to both parts.
6. Smoky film on dishes and glasses
This problem occurs due to excessive calcium build up inside the dishwasher. Try cleaning you dishwasher using a dishwasher cleaner. There are a few out there.
Posted on Jun 21, 2009
FixinFax
  • 3085 Answers
SOURCE: what does add rinse aid and where do you put it
You don't need rinse aids anymore. It rots the wiring...use FINISH tablets, the rinse aid is built into the tablet.
Posted on Jun 28, 2009
The start button on my KItchen Aid Built in Dishwasher KUDI01FLSS2 will not start, there is power and the control lock is not on. It just will not start
I had the same problem although my dishwasher quit working in mid cycle. Once it quit, there was no power to the unit. I replaced the thermal coupling fuse and that solved the problem.
Dec 27, 2012 | KitchenAid 24 in. KUDI01FLSS Stainless...
Kitchen aid dishwasher not running
Check your breaker or fuse panel first.
Dec 12, 2011 | Dishwashers
My Kitchen Aid dishwasher was running and we had to open door to remove something. Door was closed and button pushed to restart. No power at thr panel. Checked for power to the dishwasher. OK There is...
The thermal fuse is clipped onto the conrtol board and to check it ya would need to disconnect power to teh dishwasher and use a multimeter and check for continuity on it here is what the thermal fuse looks like oldtech2332_150.jpg
GENE
Oct 31, 2011 | Dishwashers
Control panel not lighting
Hello, welcome to FixYa.
I understand by reading your post which indicates it is a KitchenAid KUDS02FRSS
you appear to have a concern with no power to the control, manifesting in the control panel not lighting, correct ?
The one thing I'd suggest is the thermal fuse, typically the symptom you've described is associated with a bad thermal fuse. (part #
661663).
Here's a helpful link below to a video from "repairclinic.com" to assist in changing (or simply checking it as shown in the second link) the fuse kit...it generalizes on most Whirlpool built dishwasher's such as yours, but if slightly different it is essentially the same.
http://www.youtube.com/user/RepairClinic#p/search/0/jdlVbTXm8SY
http://www.repairclinic.com/PartDetail/Thermal-Fuse/675813/679723
I'll watch for your reply and try and help going forward. Hopefully this will provide you with the solution you seek, but please keep me posted if not.
...If so, please take a moment to rate the assistance provided for you here today. Good luck and thank you for choosing FixYa.
Regards,
Macmarkus :)
Oct 17, 2011 | KitchenAid 24 in. KUDS02FRSS Stainless...
No power kitchen aid dishwasher mod kuds01flss6 what do I check first after checking the door switch?
kitchen aid dishwasher mod kuds01flss6 you appear to have a concern with no power to the control, correct ?
8193762)
Regards,
Macmarkus :)
Oct 12, 2011 | KitchenAid Dishwashers
Thermal fuse keeps blowing
Mr. Larry (guru?)
The thermal fuse is just that It doesn't protect the circuit from over current although it certainly can open in that case. It is there to protect the board from overheating , thus the term thermal. The dishwasher could be allowing the water to heat too hot or the water heater in the home is turned up too much. The heater could also be shorted to case thus allowing it to be on even though the control is not calling for it especially if the polarity is incorrect to the dishwasher or the relay on the board could be welded closed so that the heater can't turn off even though the thermostat is satisfied. The best thing is to get a person who can check these things. You don't necessarily need to change the board with a fuse. I have changed many fuses with no other problems and verified that the machine was still working years later. sometimes the fuse just blows!
Dec 02, 2008 | Dishwashers
Kitchen aid dishwasher fuses
There may be a thermal fuse located on the electronic control board housing that may have failed.This replaceable part (gray or white) is clipped on to the side of the housing. It will not look like the type of 'fuse' you may be accustomed to. It could be a round or bullet style.
Jun 06, 2008 | KitchenAid Dishwashers
KitchenAid 24 in. KUDI01FLSS Stainless Steel Built-in Dishwasher Logo
825 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
