Question about Home
One of the screws is stepped on the drain in my shower. How do I get the drain off to clean it?
    Sergeant:
  • 462 Answers
They have a stripped screw removal tool in hardware stores or drill the head till you can remove the cover then using pliers remove the remaining scew shaft
Posted on Dec 12, 2012
Clogged shower drain
Shower drains are all designed to be opened and cleaned, usually hair builds up, if there is a visible screw remove it and lift the drain cover, if you can get fingers under the cover try lifting it off to clean it. If its stiff and its made of plastic do not use metal tools to lift it. Instead pass a trouser belt under both sides and use this to pull it up, then clean it.
Dec 04, 2013 | Home
Shower not draining iflo waste
The domed drain plug has to be removed periodically, disassembled, cleaned, and reassembled. Be sure to disassemble it in order so you can reassemble it correctly.
While the drain plug is removed, apply drain cleaner in accordance with the directions
Nov 10, 2013 | iflo Home
I would like information on steps to remove bathtub and install pre fab shower
This is a fairly big job but can be done if you have the right tools and a little bit of time....... Depending on the existing tub material (cast iron,fiberglass, tin type ). You will want to remove faucet trim(handles,spout) first. Then the over flow plate on tub,as well as drain in the bottom (this will require a drain removal wrench or pair of needle nose pliers and screw driver, and some strong arms).After this is done remove tub unit , if the unit is a cast iron unit a good sledge hammer will work as you will need to break into halves to remove unless your trying to save tub and provided you can then get the unit out the door in one piece...... Caution, protect body and eyes in this process, flying pieces of cast iron can do some damage to body......cutting tub will take several blades and take quite a while to do......The next step depends on the location of faucet and if you are replacing the tub faucet or going to use the existing faucet.... I would recommend a new faucet because if this is going to be a shower only you may want to raise the faucets so they will be easy to operate without having to bend..Depending on the model pre-fab (two piece,three piece) unit you wish to install you may need to prep the drain to make sure it will fit your new installation. Let me explain... most tubs have the drain located at the right/left end of tub and the showers are located in the center of the unit thus leaving you to relocate the drain. If house is on slab it means a little jack hammering the concrete to provide this, if the floor is a conventional it means re-routing the drain to the center.......once all this is accomplished you are ready to install unit base,connecting drain. Next you need to get the faucet located to the right height or be able to get to the back side of the shower and remove the existing faucets and replace them after you install surround.....turn off water supply before removing faucet..... A sturdy surround will make for a less involved support system around shower area.Be sure to leave enough space between studs for faucet attachment. Sounds like a lot of work and it is but after its done you will have a great bath shower..... hope this was helpful.... sorry this only dealt with the plumbing aspects of the job......
Sep 05, 2011 | Home
My shower drain was running slow during a shower, and when i stepped out i realized that the toilet was leaking from the bottom -screw under cap on left side. i am at a loss and do not even know where to...
You can try using rock salt and boiling hot water down your drains. That will help if you have roots getting into your line. Chemicals are not very good for your pipes. If you have PVC drains the chemicals can eat a hole in the pipe because most of them have acid in them. They are also bad for your health (breathing in fumes, getting on skin, etc.) If the line is broken down, has a break in it, it will need to be repaired.
Jan 24, 2011 | Plumbing
Shower drain still leaking
Shower drains can be a real pain to install. If you have the screw in type with the rubber gasket and card then you need to take it appart again. The card usually rips and then the rubber is twisted out of place. Use clear bathroom silicone (not acrillic based) between the upper grill part and the shower base, lube the plascit nut & rubber with silicone grease (home depot) and throw the card (now crushed or soaked) in the garbage. Have someone hold the grill in place (needle nose pliers) while you put the rubber & nut on. Keep a close eye on the rubber as it can still get forced out as you tighten. Clean up the silicone before it sets. If you have the rubber wedge style then I would suggest that you buy a screw on type.
Mar 07, 2010 | Plumbing
Water leeking from hose ,and water not going down thr drain of shower unit
what hose? as far as the drain goes, it needs to have the hair cleaned out of it. Do you mean hand held shower hose? needs tightening or replacement
Jan 10, 2010 | Sterling Plumbing 1500D-31S VISTA PIVOT...
Bathtub will not drain...
remove the two screws on the overflow,thats where the lever is, then pull out the plunger. clean it off and turn the water on and let it run a minute so it can flush out any grime or hair that may be down there. If you look at the linkage on the plunger it will have a threaded piece. unscrew that a couple of turns to lengthen the linkage. dont lengthen it to much,only 2 or 3 turns should do. reinstall plunger and fill tub, if it is still giving you problems try adjusting it again. If all else fails then goto a plumbing store and buy a new drain, you can buy just the plunger,linkage, and handle.
Mar 24, 2009 | Plumb Shop Alsons #PSB2510 Chrome...
How to Remove Shower Head
Once you've purchased your new shower head the first step in replacing the head is to make sure your shower faucets are firmly turned off and then remove the old shower head. If you look at the existing shower head, you'll notice flat spots on what's called a pipe nipple at the base of the shower head where the head screws into the goose-neck pipe that sticks out of the wall. * Take an adjustable wrench and tighten the wrench onto the base of the shower head flat spots. * Turning counter-clockwise, loosen and remove the old shower head. * Clean the threads on the goose-neck of any debris such as old pipe compound or Teflon tape.
Aug 27, 2008 | Dynasty Hardware Single Handle Shower Only...
Home Logo
65 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
