It has nothing on the screen even after i reset it
SOURCE: I have a Rand Mcnally
Welcome to FixYa.
The hard reset button is located at the back of the unit (soft reset is turning the unit OFF and back ON).
Please be informed that screen freezing is a very common issue with the IntelliRoute TND 500 and 700. There is no known fix as of this time not even Rand McNally's techs are able to fix it. This is clearly a manufacturers glitch and a mechanism error which can only be corrected by having the unit replaced if it is still under warranty or have it fixed by the manufacturer (they will send you a new one anyway).
I hope this information will save your time and money in searching for answers that do not matter.
SOURCE: Droped my new rand mcnally gps and cracked the
You can replace a cracked GPS
screen, but you can't repair it. If your GPS is under warranty, you can
contact the manufacturer directly about sending the unit back to have
the screen replaced. If the device is not under warranty, you can still
contact the manufacturer about replacing the screen. The company will
charge a fee to replace your GPS screen if you don't have a warranty
that covers that type of repair. You can also replace the GPS screen
yourself, but be aware that replacing your GPS screen can void your
warranty.
Instructions
Things You'll Need
http://store.randmcnally.com/?SCCampaign=cjaff&gclid=CPe2iu2B36oCFVAaQgodIwM58g
HERE IS THE LINK BELOW TO COPY AND PASTE AND PUT IN YOUR BROWSER AND THIS IS YOUR OPTIONS, CAN CONTACT THEM AND SEND IT IN AND THEY CAN REPLACE IT FOR YOU, OR CONTACT THEM AND HAVE THEM SEND YOU OUT THE PART AND REPLACE YOURSELF, BASED ON INSTRUCTIONS I LISTED ABOVE.
MY ADVICE IS : Sense your unit is expensive and new, it is worth having them fix it or fix yourself. I hope hope this helped you, and on the good size you for sure have a good unit. Thanks Mike , your fixya Expert.
