Question about Bosch Nexxt WTMC 3300 Electric Dryer
Bosch Nexxt 100 Electric Dryer Went through a flood....Nothing n
Is there a main fuse or something that may have blown? Water reached a depth of probably 5 feet so the dryer was at least on its side. An expensive dryer that insurance will not cover. Thanks for any help that may be out there
    Genius:
  • 1,198 Answers
Check all around for a dealer with one that got crushed, but has good working parts. They call them scratch and dent. Have your dealer search other dealers. You may have to buy something from him to butter him up, cause this is a real favor. Water is really rude to appliances. You'll need the motor, timer,any electronic controls, all that stuff.
Posted on Apr 24, 2009
Bosch nexxt 500 series dryer how to reset
Turn off the main breaker for a few minutes then turn it back on.
May 23, 2014 | Bosch Nexxt WTMC 3300 Electric Dryer
Dryer not getting hot
Probably a burnt out heater coil or a blown temperature fuse. If it's the temperature fuse, then I would make sure your vent isn't clogged before putting it back into service.
Dec 09, 2012 | Bosch Nexxt WTMC 3300 Electric Dryer
Bosch Nexxt WTMC 6300 Electric Dryer won't start/ no light, No power
check and see if the outlit it is plugged in to works with somthing simple like a light somthing may have triped the breaker in your house
Jun 05, 2012 | Bosch Nexxt WTMC 6300 Electric Dryer
Bosch nexxt 500 plus dryer no power
could be a fuse on the main board. open the dryer and look for one either in line to the main boasts our on the main board itself
Feb 01, 2012 | Bosch Nexxt 500 Plus Dryer
My Bosch dryer is running but there is heat?
Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable.
On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.)
Jan 04, 2011 | Bosch Nexxt 500 Dryer
Does not produce heat anymore. 3yrs 8mos old.
Check the blown fuses and home’s circuit breaker tripped. Dryer use 2 household Fuses or a circuit breakers, Replace the Fuses or reset the circuit breaker.
Make sure front of dryer is not blocked, Air Flow is needed to dry. Check that the lint filter and exhaust duct is clean.
Another common cause of a dryer failing to heat is a faulty Heating Element. You will need to replace it.
Good Luck and have a nice day.
Rating the solution is highly appreciated.
Jul 01, 2010 | Bosch Nexxt WTMC 3300 Electric Dryer
Why won't my Dryer "start"? Could it be the "start" button? It flashes "lint filter" even after I have cleened the lint filter, the hose in the back and used my leaf blower to blow out any lint in the vent...
HELLO THERE
Here is the most common things that will make a dryer not work and will need to be checked
Door switch If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. Thermal fuse On many dryers, there's a thermal fuse (a heat-sensitive fuse that blows if the dryer overheats) mounted to the exhaust duct inside the back cover panel. The fuse is about an inch long. It's usually embedded in black resin and mounted in a white plastic housing.
If the fuse has blown, it has no continuity. When this happens, your dryer either just stops heating, or it doesn't work at all. Be sure to inspect the venting/heating system before replacing the fuse to put the dryer back into operation. (You can't re-set this type of fuse.)
Wiring Often the main wiring connection from the house, at the dryer, burns and the connection breaks. In this has happened to your dryer, you need to replace the power cord and the terminal block inside the dryer to which the wire is attached.
Jan 09, 2010 | Bosch Nexxt WTMC 3300 Electric Dryer
Heats and turns but shuts off after about 15 min
This may be an indication of an internal duct restriction due to lint. If it is clean inside there may be a problem with the main electronic control board but the only way to know for sure is to do some electrical testing with a volt/ohm meter and the wiring diagram located within the appliance.
Go here for LG Dryer Parts: http://www.repairclinic.com/LG-Dryer-Parts
www.RepairClinic.com
Feb 03, 2009 | Bosch Nexxt WTMC 3300 Electric Dryer
My Bosch nexxt electric dryer won't turn on
Belt broke or came off. Replace or reset belt. Be sure to reset the switch that the tension arm activates when tension is lost.
Nov 04, 2008 | Bosch Nexxt WTMC3321US Electric Dryer
Bosch Nexxt WTMC 3300 Electric Dryer Logo
95 people viewed this question
Top Bosch Dryers Experts
Lawrence Oravetz
MightyMikeJr
Are you a Bosch Dryer Expert? Answer questions, earn points and help others
