Question about Essick Air 447 302 Console Whole House Humidifier - Cherry Humidifier
Need to reset the cf notification
Ive changed filter but cant get the cf notification on the machine to reset
I have an essick humidifier and it keeps flashing CF but it continues to run. What does the CF mean.
Check Filter Indicator The ability of any humidifier to efficiently supply humidity output relies heavily on the condition of the filter. As the filter loads with impurities it gradually loses its wicking capability. When this happens, moisture output is reduced and the humidifier has to work longer to satisfy the selected setting. This humidifier has a check filter reminder timed to appear after 720 hours of operation. When the Check Filter (CF) message is displayed, disconnect the power cord and check the condition of the filter. If a build-up of deposits or severe discoloration is evident replace the filter to restore maximum efficiency. The CF message is reset when the humidifier is plugged back in.
Dec 03, 2017 | Humidifiers
My Kenmore Humidifier 15420 has a code of "cf" what does it mean?
Depending on your model, the CF could mean the filter needs to be changed or that the unit needs to be reset. If your model doesn't have a reset button, you can unplug the unit from the outlet for 5 minutes.
Jan 18, 2017 | Kenmore Humidifiers
How do you reset the cf on essick humidifier
I just changed the filter and it started flashing CF. How do you reset this other than changing the filter?
Feb 04, 2013 | Essick Air Humidifiers
Humidifier what does CF stand for
It may mean "Change Filter." After you replace the filter, unplug the humidifier for 30 seconds, and then you plug it back in, the CF code should be gone.
Dec 04, 2011 | Kenmore 14410 Humidifier
Our machine is flashing CF. We've put a new filter in, but cannot get it to reset. Do you know how to reset the machine?
You have to unplug the unit from the electrical outlet. Just shutting it off won't clear the CF code.
Mar 11, 2011 | Essick Air MA0800 Humidifier
CF is displayed on my humidifier...what is that?
Mar 05, 2011 | Bemis 826 800 Humidifier
I have the MA0800 and I have a CF flashing on the display. How do I get rid of this code? If it requires a clean filter, then how do I reset this code once I have a clean filter?
Change the filter then unplug the unit from the electrical outlet and the code will be cleared. Just shutting the humidifier off won't clear the code, it has to be unplugged from the power to clear the flashing CF.
Jan 21, 2011 | Essick Air MA0800 Humidifier
What does the cf stand for
Found the answer in the original manual. CF means check filter, this displays every 7200 hours of operation. If the filter is OK just unplug the unit for 2 minutes and the display will reset.
Dec 26, 2010 | Essick Air Humidifiers
Cf diplayed after filter change,how to stop CF?
The CF comes on after 720 hours of operation (while continuously plugged in). Really stands for Check FIlter, not Change FIlter.
Just pull the plug and let is stay unplugged for 30 seconds or so. When you plug it back in, it will be reset for another 720 hours.
Gene
Jan 01, 2009 | Emerson HDC12 Humidifier
Kenmore 15408 Humidifier How to Reset CF
Per the owner's manual, you simply unplug your device for 30 seconds. Upon plugging it back in, the CF notification should be cleared.
This assumes you have also changed the filter, of course.
Feb 08, 2008 | Kenmore 14410 Humidifier
Essick Air 447 302 Console Whole House Humidifier - Cherry Humidifier Logo
63 people viewed this question
Top Essick Air Humidifiers Experts
Mack Baxter
Joseph Mueller
Joseph Mueller
R Daniel Wolfe
Are you an Essick Air Humidifier Expert? Answer questions, earn points and help others
