"patch mix dsp error!" "you dont apiear to have sufficient e-mu hardware to load the sessione in your sistem. this may be becouse the session expects more emu hardware then what you have installed o
Linkums
  • 30 Answers
SOURCE: Games initial load before Play Starts receive error 'cannot read disk see instruction manual'
If this happens for only some games, you should try cleaning the discs with a disc cleaner. Otherwise, you could try asking around at stores like circuit city, radioshack, best buy, etc. for what you could use to clean the lens, the part that reads the disc in your gamecube. If that doesn't work, chances are that the lens is damaged and your only hope is to send it in for repairs or get a new gamecube (or Wii).
Posted on Oct 21, 2007
SOURCE: i keep getting no m-audio hardware found
change that cord then boot the computer with the USB  hooked up good luck
Posted on Dec 06, 2007
weblord
  • 507 Answers
SOURCE: Yahoo Mail closes unexpectedly
this is an issue with firefox 3 try to use firefox 2 when logging in yahoo mail, other yahoo services are ok.
Posted on Nov 08, 2008
SOURCE: mbox cannot start new session or load in old sessions.
Session Must Be On An Audio Record Volume Means You Do Not Have Protools Program, Session Files, Audio Files Installed And Set To Record On The Main Hard Drive Or A Hard Drive That Has Be Formated With A Volume .  Un-Install Then Re-Install Protools Software And Make Sure The Programs And All Files Are Written To The Main Hard Drive .  When You Open Protools Files Or Older Version Protools Files That Are Not On The Main Hard Drive You Need To Copy And Paste The Session With All Audio Files To The Same Hard Drive As The Program Before Opening Them .  If You Plan To Record, Mix, Master On A Previous Protools Session I Suggest The Session To Be On The Main Hard Drive .  One Thing To Do In Order To Prevent Protools From Recording To Back Up Hard Drives Or Media Disc Is To Create A New Session As Soon As You Get Protools Up And Running, Make Sure The Session Is Created/Saved Into The Main Hard Drive .  Do Not Open Previous Sessions That Are Save To Other Hard Drives/Media The First Time You Get The Protools Installed .  Protools Can Record On External Hard Drives ( Firewire Recommended ) But Work Better With A Internal Hard Drive With at least 7200 RPM And 8 MB Cache .  Hard Drive, Cables, And Port Strength/Compatibility Have A Lot To Do With Weather Or Not A External Drive Is Best For Recording .  To Repair, Format, And Set Your Hard Drive With A Volume Go To Disk Utility Under Utility Located In The Applications Folder .  Reformatting Or Repairing A Internal/External Hard Drive Will More Then Likely Erase The Whole Hard Drive So Make Sure U Back Up All Files To A Hard Drive/Media To Save All Information .  I Hope This Helps You Out A Lot .  Thanks .
Posted on Dec 25, 2008
SOURCE: I have big problem.I have Vista Home Premium 64
simple solution is that just set your laptop to previous back up date at which it operates better
Posted on May 15, 2009
HP error code 363, what does this mean?
I went online and found the HP8600 user manual and this is their solution to the error code 363 that you reported, which I copied off their site. Hope this works for you:
  • Turn Error Correction Mode (ECM) off, if you encounter the same error repeatedly. Click this link HP All-in-One and Fax Products for more information on enabling or disabling ECM.
    beaac3qsmgaaaaaelftksuqmcc
    NOTE: Error codes that apply specifically to ECM have ECM listed next to them.
Error Code: 356, 357, 358, 359, 360, 361, 362 ECM, 363 ECM, 364 ECM, 365 ECM, 366 ECM
Definitions
  • The remote user pressed the Stop key, causing the session to be terminated.
  • The remote machine encountered a system problem such as no paper or a paper jam. This prevented the fax from receiving any more pages, and caused it to terminate the session prematurely.
  • The call-waiting service can cause this error. The click, heard for an incoming call, is actually a momentary disconnect of the line.
  • The remote machine encountered an incompatible feature causing it to terminate the session.
Solutions
  • Configure the remote machine for document reception by clearing any paper jams, loading sufficient paper, and clearing any other error messages.
  • Configure the local fax machine to use a slower reception speed.
  • Enable or disable the ECM setting.
May 27, 2014 | HP LaserJet 3050 All-In-One Printer
I have an m-audio fast track and have 10 sessions recorded. This is perhaps a foolish question, but what is the best software to load these 10 songs into to make a finished album. Thanks.
Do you want to layer the sessions and mix them together? Then Cubase is the best software.
http://www.steinberg.net/en/products/cubase/cubase6_why_cubase.html
OR
Do you just want to edit the sessions individually? Then Wavelab is the best software.
http://www.steinberg.net/en/products/wavelab/why_wavelab.html#c61447
Mar 15, 2011 | M-Audio Fast Track External Sound System
Have a 85 errors
When you try to connect a drive that was previously connected to a Distributed File System (DFS) resource, you may receive the following error message: System error 85 has occurred. The local device name is already in use.This error message persists for the particular drive letter in that particular Terminal Services session. The same drive letter for other Terminal Services sessions may work as expected. A different drive letter that is not typically used also works as expected. The only way to correct the issue is to restart the Terminal Services-based system.
To resolve this problem, obtain the latest service pack for Microsoft Windows 2000. For additional information, click the following article number to view the article in the Microsoft Knowledge Base: 260910 How to obtain the latest Windows 2000 service pack (if you are using windows 2000)
Jan 17, 2011 | Computers & Internet
No audio from EMU 0404 soundcard
may be problem in power unit. you can try it, first uninstall driver and after setup.
Apr 06, 2010 | E-Mu 0404 Sound Card
I have trouble connecting to the internet vie a motorola surfboard modem. I have optus cable this pc works but the XP wont. when I put installation disc in it goes so far then I get an error message...
If you are switching the hardware connected directly to the surfboard, then you may need to call the Internet Service Provider and let them know. They usually set up a session based off of the hardware address of the device hooked up to their modem. If it changes, sometimes you have to get them to close the old session.
Mar 31, 2009 | Motorola Computers & Internet
MP600R
Sir,
Change the settings of my Airport Extreme back to "Create a wireless network".
Check your airport settings using Airport Utility (if you don't have it just download it from Apple) and look for "Wireless Mode";
Make sure is set to "Create a wireless network".
it is a driver, settings or software version based problem. So try to download latest driver and change the setting of above i mentioned.....
sir once we finish this chat you will be asked to rate the chat. that time please dont forget to give a good rating
and review. because many customers dont rate the chat and we experts are left with no credits for providing a
solution.
so please dont forget to rate the chat after end of the session. this is just a information to you. always use end
session button to end the session.
Aug 20, 2008 | Canon PIXMA MP600 all-In-One InkJet...
Working with Vista
M-Audio Session is looking for the USB device, e.g. "Micro" or "Fastrack"
Jun 21, 2008 | M-Audio Session KeyStudio USB Keyboard
E-MU 0404 input problems
try to reset the inputs on your sound card ,CLICK ON the PATCHMIX ICON, GO TO OPEN SESSION (IT IS THE FOLDER ICON IN THE MIDDLE ON THE TOP OF THE PAGE) AND TRY TO OPEN SNOTHER SESSION, IF THIS WORKS YOU ARE GOOD .YOU MIGHT HAVE TO OPEN A FEW SESSIONS BUT IT WORKED FOR ME
Aug 27, 2007 | E-Mu 0404 Sound Card
Computers & Internet Logo
226 people viewed this question
David Payne
David Payne
