Question about Schwinn 220 Recumbent Bike
Connector male missing - Schwinn 220 Recumbent Bike
    Top Expert:
  • Schwinn Master
  • 12,223 Answers
O.k. go to www.fitnessrepairparts.com and buy it
God bless you
Posted on Dec 13, 2012
Missing adapter or plug in connection to 15 balance mointor model 2015
The Balance CM2015 monitor uses a VGA connector,
http://www.ebay.com/ctg/Balance-CM2015-15-LCD-Monitor-Black-/52125929
(The above is for reference only. Not advertising)
A VGA connector is also referred to as a 15-pin D-Sub connector,
http://en.wikipedia.org/wiki/VGA_connector
This is information on a DVI cable, and DVI connector,
http://en.wikipedia.org/wiki/Digital_Visual_Interface
If this is the monitor cable you have, you need this type of adapter,
http://www.directron.com/dviadapter.html
Now LOOK closely.
This adapter has male pins that stick out, and go into a female VGA connector on the monitor. The DVI side of this adapter has socket holes, for a male DVI cable.
IF, your monitor has a male VGA connector on it, and the DVI cable you have has socket holes, you need this adapter,
http://www.directron.com/dvitovga.html
If your monitor cable is not a DVI cable, post back with the style it is.
If nothing else post how many pins are in the connector on the cable, and how they are arranged.
For additional questions please post in a Comment.
Regards,
joecoolvette
May 27, 2012 | Computers & Internet
Seperating the electrical connection on radio in rover45 2001
a SMALL blade screwdriver (1/8" or smaller), "gently" inserted between the male and female jacket of the plug connector, where the catch protruding from the male connector through the female jacket. Gently rock the connector back and forth working the catch, (from the male connector) out of the slots, (of the female connector) of the female jacket, on both sides.It can be a little tricky the first couple times you try this, but you will get it... Good Luck.
Feb 12, 2012 | Cars & Trucks
I would like to know what adapter (DVI to VGA Cable Adapter) I need to connect to a Macintosh G4. Thanks
Without knowing what Model Number of MAC G4 you're referring to, I can only give you generic information.
If your MAC G4 has a DVI port it is generally the female style.
The DVI connector on the adapter will need to be a male DVI style.
The VGA end of the adapter will be either male, or female. Most VGA connectors on a monitor cable have a male VGA end.
(The DVI end will have the pins sticking out on the adapter. The VGA end will have the socket holes)
Also stated as the monitor cable end will be a DVI male. The port {Connection} on the computer is a VGA female)
Example of a DVI male to VGA female adapter,
http://sewelldirect.com/dviaftovgam.asp
Barring that you need the other style of DVI to VGA adapter, (DVI female on the monitor cable, VGA male on the computer), this is an example,
[ Note* The newer VGA connectors are also known as an HD-15 connector.
More information on the Video Graphics Array connector,
More information on the DVI connector styles, and the Digital Visual Interface technology,
If you should find all of this confusing, simply state in a Comment as to what connector is on the end of the monitor cable, and what connector is at the computer.
State whether the connectors are Male (Pins sticking out), or Female (Socket holes)
Regards,
joecoolvette
Jul 16, 2011 | Computers & Internet
Phoneline has 4 pin male connector, printer has 6 pin female slot . . . .What do I do now?
If the 4 pin male connector is the same shape as the 6 pin female slot (but just a bit shorter) then it should fit centrally in the slot and work just fine
If on the other hand the phoneline 4 pin male connector is a BT connector (completely different shape) then you will need to but an adapter.
Jun 10, 2011 | Canon PIXMA MX300 All-in-One Printer
I want the pictures of VGA CABLE of Samsung Sync Master 798 MB plus
Hey,
All VGA cables going to a CPU are essentially the same. Although, you may come across two types of cables. Picture 1 shows male-to-male connections. One end goes to the monitor and the other one to the CPU. The 2nd picture shows a male-to-male connector. It's always male-to-male connectors. However, you may use a male-to-female connector if you want to extend the existing VGA cable. Before buying it, just check what type of connection your CPU and monitor have at the back, for safety sakes.
Picture 1: .hak26_0.jpg
Picture 2: x hak26.jpg Hope this helps.
May 03, 2011 | Computers & Internet
When I unplugged my electrical wiring harness, one of the male connector tabs stayed with the female part. The male end has rotted off the wire. I need to find a male connector for 10ga wire that has the...
Best bet, see if you can find the exact connector off a junkyard wreck. The parts remover personnel will simply clip the connector on both sides of the junction and you can rewire into your existing harness.
Sep 30, 2009 | 2001 BMW 330
Lowrance depth finder missing adapter cable
I own a 1995 Four Winns and what you need is a Lowrance LSM-1 depth finder unit. It accepts the two pin lead from the transducer and send the depth reading to the dashboard display via the 6-pin connector. There is also a three wire harness (red/blk/wht) that connects to a power supply.
The reason I know all this is my depth finder fried a couple years ago so I removed the Lowrance LSM-1 from the boat in order to find a replacement. Unfortunately, this was an OEM part that is not available from Four Winns or any aftermarket source. Probably your best bet is to look in a boat salvage yard or purchase an aftermarket depth finder.
Jul 28, 2009 | Boating
Cable?
since the DGL20 uses a PAL connector, you will need an adapter plug from PAL male-to-RF male (75 Ohm) connector. You can also try a RCA male to RF male (75 Ohm)
May 12, 2009 | Digimate DGL20 Television
Color change
1. red colour on the screen , or redcolour missing. redpatchs on the screen. tell me.
(1). in case red colour on the screen red colour missing.change the vga male connector.
2. red patches on the screen external digosing use.
Oct 13, 2008 | HP Pavilion M703c 17 in.CRT Conventional...
Schwinn 220 Recumbent Bike Logo
53 people viewed this question
Top Schwinn Exercise & Fitness Experts
Steve
David Payne
David Payne
Matt Olenzek
Matt Olenzek
Are you a Schwinn Exercise and Fitnes Expert? Answer questions, earn points and help others
