Question about Jenn-Air Refrigerators
Came back from vacation and all food on both freezer and fridge side was spoiled. Fan on freezer side was still working and fridge appears to be running but not cooling. Tried to change the Jen Air se
Tried to turn fridge on and off and waited 5 mins. Followed directions in manual to reset control panel, but panel is not responding. Only two displays lighting up are fridge and freezer temp which are both at 65.
  • Peter Krawiec Dec 09, 2012
    its a jen-air jcd2297key
    Top Expert:
  • Jenn-Air Master
  • 9,472 Answers
What is the complete model number of your unit?
Posted on Dec 09, 2012
mikedurland
  • 481 Answers
SOURCE: Maytag MSD2651HES fridge not cooling freezer works find
Sounds like a defrost problem. Check to see if there is any frost buildup in the back wall of the freezer. If so, it is not defrosting as it should.
  • possible causes:
  1. bad defrost timer
  2. bad defrost heater (in freezer)
  3. bad thermo switch in freezer
If you don’t know what these are then unplug the machine and let the ice melt in the freezer overnight with the door open. Then try it the next day, if is cooling fine then you need to have a service person replace one of the above items.
Posted on Jul 06, 2008
22yooper
  • 828 Answers
SOURCE: Freezer / Refrigerator not cooling
When the fans are running the compressor should also be running. If the compressor is hot but not running you have a compressor problem. If the compressor is running check for frost on back wall of the freezer compartment which would indicate a defrost system problem. At five years old have you cleaned the condenser where the heat is transferred to the outside air in the room?
Posted on Nov 19, 2008
  • 1122 Answers
SOURCE: Fan runs constantly and does not keep temp cool enough
forst on the back wall means you have a defrost problem or a air leak aroudh the door gasket-mike
Posted on Mar 16, 2009
SolutionGuy
  • 331 Answers
SOURCE: model# 596.58642891 freezer side thawed first and
I humbly disagree with Sea Breeze. We know the thermostat (cold control) is working because the fans are running and the compressor is hot to the touch. So we're getting power to the compressor. Now, only TWO things will keep the compressor from firing up when it has power supplied to it.
1.) A failed Starter. (that box connected to the left side of the compressor.)
2.) A failed compressor.
Then there are two things that'll take out the starter.
1.) Just a mechanical failure within the starter (blown ceramic disk). Note ---> You can normally tell if a starter is bad just by taking it off the compressor and shaking it. If it sounds like it has pebbles in it... it's bad. If it's solid, it's probably good.
2.) If the compressor locks up or fails, the starter is not far behind.
This Kenmore is made by Frigidaire. My experience with these is that 90% of the time, the compressor has locked up. You said you had access to the compressor... if it's made by Tecumseh (you'll see a blue Indian head logo on the sticker) I can almost guarantee it's failed. (Frigidaire is now putting Embraco compressors in their machines because Tecumseh was such a terrible one.)
All that to say this... you may decide that you want to replace the starter (if it's bad/rattling). If you do, go here and look at parts # 211 & 251 on the diagram... you'll need these. So, all-in-all, it'd cost around $20 plus shipping to replace the starter. If the new starter works? Great! You fell within the 10%... (almost like winning the lottery!) If the starter doesn't work, all you're out is the $20.
Good luck,
SG
Posted on Mar 28, 2009
taran_2005
  • 10515 Answers
SOURCE: I have this fridge: jcd2295kes
This is Also a Problem with Many Maytag and Kitchen Aid Models.I am not sure what they have Replaced. The Error you have indicates that the Control Board has lost it's Programming Code. Unfortunately, you need to have a New Control Board.The Cost of Board would be around $150.
Note - You could Again Try Unplugging. Unplug it for few minutes, say 30 minutes and then TURN ON the machine. If same Error Reflects, you need to Replace Control Board.
Let me know, if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Feb 27, 2010
Freezer is working,but fridge is warm. Fan in back of fridge will not shut off.
If your fridge is not designed with an automatic de-icing function, then there may be an ice dam blocking the cold air from moving from the freezer to the fridge. I had a fridge once that would get blocked with ice even if the rest of the freezer was ice-free.
Unplug your unit (often shutting off the breaker is easier than digging behind the fridge for the plug).
Pull everything out of the freezer and put it in a box. Cover the box completely with blankets to insulate it so your food doesn't thaw and spoil. Prop open the freezer door and let any ice accumulation melt.
Once everything has thawed out, wipe up the water and plug the unit back in. You should be able to tell after 10 minutes or so whether the fridge is getting cooler or not.
Mar 04, 2015 | Refrigerators
Water leaks inside food compartment
Your fan has stopped working. You need to either replace it or see if your defrost timer is working.
Jan 07, 2014 | Frigidaire FRT15B3A Top Freezer...
Hi I have pressed the vacation button on my side by side refrigerator/freezer as we are going away for 8 weeks. The display has lit up but there is no difference in the way the fridge is operating - same...
The settings will reset to a lower settting as the fridge/freezer will not be disturbed . So wait for the fridge to run and shut down and it will continue to run in this low mode to save power but to keep the food in prime condition. The fridge alone will not be shut down.
Aug 31, 2011 | Samsung SRS20DTD Side by Side Refrigerator
Freezer works great but food is spoiling and not cold enuff in fridge. dosent seem to be air flowing out of vents in the side in fridge. is there a fan that quit or could it need freon
when you fridge is running open the freezer door and listen for a fan there may aslo be on ein the fridge compartment,also look for frost build up on the back wall of the freezer.if there is ice build up you need to defrost it.when the unit is in the cooling mode and you do not here the fan running on the inside of the unit the the fan needs to be replaced.
Jan 31, 2010 | KitchenAid Superba Architect KSCS25INSS...
My 685 freezer is fine, but the fridge is only getting upto 50
Check the compressor fan motor. Is it running?
Check the freezer and Fresh food fan motors. Arte they running?
Jan 04, 2010 | Sub-Zero 685/S Stainless Steel Side by...
Refrigerator stopped cooling
the problem is in your freezer !
open the back wall of your freezer and check if the fan working then if you see a big build up of ice. then its your heater unit or your heater thermostat. to check that it is the problem unplug the unit defrost the freezer coil with hair drier gently and when it done plug it again and see if your fridg get cool (1h or 2) then you know its the heater unit or the thermostat :(
911servicetoday .com
Jan 01, 2010 | Whirlpool ES5FHAXS Side by Side...
Fridge not cooling, freezer not cold enough, ice maker not workin
is there alot of frost in the rear panel of the freezer if not the compressor is not start or getting hot because fan that cools it has failed is the part between the side/side door extremely hot if so check the cooling fan for the compressor
Aug 19, 2009 | Maytag MZD2766GES Side by Side...
Side by side fridge not cooling, not making ice
if it seems like the evaporator is getting cold then your sealed system should appear to be ok. you need the evap fan to transfer cold air into fresh food section. if not turning u need to replace fan motor. make sure your not getting to much frost build up on the evap.
Jun 24, 2009 | Frigidaire Freezer Refrigeration White...
  • possible causes:
Jul 06, 2008 | Maytag MSD2650HES Stainless Steel Side by...
Refrigerators Logo
134 people viewed this question
Top Jenn-Air Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Jenn-Air Refrigerator Expert? Answer questions, earn points and help others
