Question about LG LRE30757ST (Electric) Stainless Steel Range
LG Oven "resets" itself and displays 'PF' when I try to bake/broil/convection cook
I've got an LG LRE30757ST oven that "resets" itself when I try to bake something. The range works fine, the warming drawer works find and the proof function of the oven also works fine, but whenever I hit bake or convection (operations that require high current draw) I hear a click and a sound like the heating elements are warming up and then I get the PF reading on all the oven displays as if the power went out. Any help on diagnosing this problem. Does anyone have a service manual to help with the diagnosis and subsequent repair part purchase. Thanks, Greg
5 Suggested Answers
TheMobilian
  • 8220 Answers
SOURCE: I have an LG gas range Model LRG30855ST. I tried
See page 30
Posted on Mar 30, 2010
heatman101
  • 43501 Answers
SOURCE: My oven is not working properly Went to bake a
If your electric2_bing.gif oven is not heating then you probably have a bad heating element in your oven. This is not that hard to fix yourself...
Check out this tip that I wrote about the Oven not heating problem..
Oven Problems Electric2_bing.gif Oven is Heating Slowly or Poorly
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
Posted on Jun 01, 2010
  • 2006 Answers
SOURCE: LG Range LRE30453ST quit working.
I can tell you aren't familar with house wiring. So we will start from the beginning. Circuit breakers are rated by the AMPERAGE that it can handle. When there is a current surge above the rated AMPERAGE the breaker is supposed to trip. When the breaker trips it doesn't always trip all the way to the side, sometime it looks okay so shut the circuit breaker off and reset it and then do it again to make sure you did it right the first time. If that does not cure your problem you might have blown your thermal fuse (Item #5016) or blown the power control board (Item #5070)
http://www.searspartsdirect.com/partsdirect/part-model/LG-Parts/Range-Parts/Model-LRE30453ST/3204/0124111/F0903017/00005?blt=06&prst=0&shdMod=LRE30453ST
But since the display screen is also completely blank it could be one of the PCBs in the control panel.
Posted on Aug 16, 2011
richroth
  • 9472 Answers
SOURCE: LG LRE30451 won't maintain temperature
Check the oven temperature probe (thermister) to see if it is good. To check it, use a multi-meter and Ohm it out. It should be between 1100 and 1600 Ohms. If it is out of tolerance, you will need to replace it. Here is the part to order.
Posted on Nov 30, 2012
When using oven it beeps twice and oven light comes on and oven shuts off
[PDF]Bosch Hbl8650uc Use And Care Manual - Cloudfront.net
https://d1vofmza27mmhi.cloudfront.net/.../bosch-hbl8650uc-use-and-ca...
foods with the appropriate oven mode, temperature, rack position and bake time. This section also ..... Preheat. Light. Lower. On/Off. Upper. True. Convection. Speed. Convection. Broil. Bake. Roast .... Cook Time: Turns off beep for the end of cooking time. •. Timer: Turns off ... Press Timer twice to exit the timer menu. Note: •.
PDF]Use and Care Manual for Bosch Electric Built-in Single ...
pdfstream.manualsonline.com/.../9d658fa3-efaf-44a3-beb6-bc5f9c80d5...
realize the full potential of your new Bosch oven as well as protect it from damage ..... On/Off light. • Heat light. • Door lock light. • Timer/Manual selector knob .... the display will come on showing all the call-outs, .... Electronic Control of Oven. Immediate. Start/Automatic. Shut-Off. To use the .... Depress Cook Time button twice.
Dec 02, 2015 | Bosch HDI7152 Stainless Steel Dual Fuel...
Amana Convection Oven - Not heating in normal bake mode, but works otherwise
I will say that is the control board that is not working properly. Have you try to unplugged for phew minutes?, this will reset the current settings. If not, I will star replacing the control board. Good Luck!.
Jan 13, 2014 | Amana Ovens
Oven does not work
What is the model number listed inside the oven door area or the storage drawer on the bottom (if it has one).
Jun 05, 2013 | Kitchen Ranges
Dacro Wall oven (electric) does not heat past 345 degrees on bake or convection bake but broiler works and bottom oven works fine (for bake, convection bake and broil).
it could be the oven temp sensor rod located near the top of the inside of the oven,or possibly the bake element has a hot spot on the element and can no longer pass enough current thru this spot to correctly heat to your settings a hot spot on the element will look discolored in this area
Jul 28, 2012 | Dacor Ovens
Oven symbols
bake:convection(heated air) cooking
broil:flame cooking
Is this what you are asking?
Jan 29, 2010 | Ovens
Oven will not heat up on bake broil or convection cook.
I justn encountered the same problem (Model KERS507Y). Haven't checked yet...but am suspecting the Thermal fuse. Have you solved the problem?
Jan 18, 2009 | KitchenAid Architect Series KEMC308KSS...
Electrolux built in wall oven, lights and digital display work fine, fan works fine, but the oven will not heat regardless of the mode (broil, bake, convention roast, convection bake)
Hello stevefer
Welcome.
You said, Your Electrolux built in wall oven, lights and digital display work fine, fan works fine, but the oven will not heat regardless of the mode (broil, bake, convention roast, convection bake)
First,
1.What is the Model Number and the year of your wall oven?
2.Did the oven light up and display with any error codes?
3. Did you try to turn the breaker off for 5 minutes to see if this will reset the system?
Perhaps the heating element is failing and may need to be replaced.
I will be able to better assist you when you reply with this information.
Waiting your response.
Huuum
Oct 16, 2008 | Kitchen Ranges
Oven will not stay on when baking regular none at all, convection have to set a couple of times
I had a similar problem when you turn the oven on it would shut off either on broil or bake,I tried switching the lock for the oven cleaner back and forth and now the oven works.
Jul 05, 2008 | GE JBP90 Electric Kitchen Range
Amana Convection oven not controlling temp
I have just checked the baking guide in the manual and have found that it may not be us after all. (Maybe this is why they telll us to read the whole manual. Well, I never have) According to the cooking time for Baking, the range is very extensive. For example, an angel cake at 350 could take from 28-50 minutes, buscuits at 375-400 could take 8-16 minutes, layer cakes at 350-375 could take 25-40 minutes, pound cakes at 325-350 could take 45-70 minutes and fresh pies at 400-450 could take 35-60 minutes. Basically, the baking directions on the box means absolutely nothing to use Amana oven owners. We have no choice but to cook our food or baked goods until they are cooked, whenever that may be. :) Linda
Dec 11, 2007 | Amana AOCS3040 Electric Single Oven
LG LRE30757ST (Electric) Stainless Steel Range Logo
35 people viewed this question
Top LG Kitchen Ranges Experts
JP Services
JP Services
Dan Webster
Dan Webster
Mike Carew
Are you a LG Kitchen Range Expert? Answer questions, earn points and help others
