Question about Amana ARSE67RBB / ARSE67RBW / ARSE67RBC Side by Side Refrigerator
Amana arse67rbb compressor gets hot. replaced overload relay still happens. works fine for a few days after unplugging for a few hours. do I replace fridge?
Fridge is 8 yrs old and this is been goig on about 2 weeks
    Top Expert:
  • Amana Master
  • 9,472 Answers
Are the coils clean?
Posted on Dec 09, 2012
  • themanrkm
    themanrkm Dec 10, 2012
    Yes first thing checked!
  • Richard Roth
    Richard Roth Dec 10, 2012
    What exactly is it doing?
  • 1462 Answers
SOURCE: Refrigerator not cooling.
compressor has failed. not a diy job
Posted on Apr 25, 2007
watugot
  • 290 Answers
SOURCE: Quick Fix?
The compressor is locking up when it gets hot. We have seen alot of this on the units with Tecumseh compressors. If it is less than 5 yrs old it should still be covered by the sealed system warranty and repaired free of charge.
If it is out of any warranty, there are "fit-all" compressor starters with start capacitors built in them that give it a little extra boost on start-up. They are called 3-in-1 or kickstart starters. This will usually buy you a few months until you can replace fridge.
If it is covered by warranty but will take a few days to get repaired, you can get by ok by unplugging fridge at night and plugging back in in the morning. This is what I tell my customers when I have to order a compressor and so far they have been able to keep from losing food.
Posted on Nov 05, 2007
fridgetech
  • 473 Answers
SOURCE: refrigerator compartment not cooling
If you are sure the fan in the freezer is running and you don't feel any air flow out of the top middle vent inside the fridge section, then the damper motor must be bad. The damper motor is behind that vent cover inside the fridge section.
Posted on Nov 16, 2007
  • 29 Answers
SOURCE: amana drs2462bw, replaced the relay
relay has gone again or compressor has a problem
Posted on Aug 13, 2008
Macmarkus
  • 2605 Answers
SOURCE: I have amana bottem freezer,1 month ago i
Hello, Unfortunately the compressor likely is seized now. There are a couple of reasons that the original start device failed, 1) faulty connection. 2) poor quality part. 3) compressor was running non-stop due to other deficiencies in the unit or 4) the compressor was failing to begin with. The compressor may indeed check out ok as far as electrically ( windings ) but the mechanical component ( rotor ) has locked/seized up. You can determine whether it is the windings by checking the ohm value between common to start, common to run and run to start ( c-s, c-r, r-s ) and look for values similar to 6ohms, 3ohms, & 9ohms. Then check the start and run & common windings against the compressor casing to see if windings are shorted. In order to double check the mechanical component you'd need another hard start, ( or a test cord direct to 120vac, but that should only be done by an experienced tech ). nothing else will start it at this point obviously or you wouldn't be using a hard start already. The other unfortunate issue is this, many of these compressor's have a 10yr. parts only warranty but that was voided as soon as the 3in1 hard start was installed. In the end I'm likely not telling you anything you didn't already suspect or know in fact, but it is likely the compressor. I sympathsize, seized compressors **** ! Hope this answers your question and moves you forward. good luck macmarkus :)
Posted on May 08, 2010
Amana ABB222DE is the overload/capacitor the same thing as the compressor relay? I just had the compressor relay replaced in amana bottom mount. Frig cools fine but every 2 days or so buzzing noise...
I have been doing refrigeration for over 30 years and I have never seen a compressor with a chip inside of it. Have you tried cleaning the condensor coils? I almost sounds like you have a weak start capacitor. Let me know if i can help you any futher.
Apr 24, 2011 | Amana ABB2224DEW / ABB2224DEQ / ABB2224DEB...
My amana bottom freezer model #abb1921dew smelled like smoke and the compressor was not running. I unplugged it over night and when plugged in again it appears to be running fine. Any suggestions?
I would suggest replaceing the overload/relay w/capacitor .
Pt # 67005560 . This piece , easily plugs onto the side of the compressor . If you replace it now , since it is already burnt , it would save you the trouble of replacing it later , when the compressor will not restart . It will happen again , due to the burning .
Nov 22, 2009 | Amana ABB1921DE Bottom Freezer...
Compressor stops running and keeps cycling every few minutes. It buzzes as if the compressor is gone. the compressor is hot. If the thermostat is turned to off for 6 to 8 hours and then turned back on the...
you can replace the relay with a 3 in 1 made by supco. i generally just use a supco 0410.
www.supco.com
it is a start relay, overload, and start capacitor all in one. works great for residential systems.
Nov 06, 2009 | Frigidaire FRS3R5EMB Side by Side...
My Amana fridge (model ARSE67RBB) compressor has stopped working. It locks up when it gets too hot, and then makes a high pitched buzzing sound. I purchased the fridge used, so I don't think Amana is...
The buzzing noise is the compressor stalled and trying to start. Is the condensor fan working? (the fan at the back by the compressor) as if it's not it could cause this issue. If the rest of the unit is in good condition then yes I'd replace the compressor as these are normally good models and aren't cheap to buy new. This problem shouldn't happen again if you have a good new compressor installed by an expert. cheers
Oct 30, 2009 | Amana ARSE67RBB / ARSE67RBW / ARSE67RBC...
Does not cool and compressor relay keeps intermittently buzzing every 1 to 2 minutes. Condenser coils are cleaned and when you check across the overload protector pins there is no continuity.
When there's not continuity across the overload is because the compresor overheated , it could be the relay or the compressor that is burned out or stuck .I would let the compresor coold down for a few hours (unplugging the unit) and replace the relay (no more than $20) and if still having problems the compressor needs to be replaced.
Aug 23, 2009 | Amana Freezers
Help w/ Refrigerator Compressor Overheating?
I had a similar problem yesterday (Maytag side by side unit 5 years old, however this apply to most brands). All operation seems normal other then that the refrigerator was not cooling, the air that was blowing inside the refrigerator was room temperature and not cold air. The compressor was also very hot to touch (could not touch it for more then 1-2 seconds) and didn't buzz or hum as in standard operation. I also heard few clicks from the compressor every time I plugged / unplugged the AC to the fridge. Replaced the overload/ relay device with a new one I got at a local appliance parts distributor ($30) and MAGIC. The unit went back to work as soon as I plugged the AC power. The relay/overload unit is on the side of the compressor and that?s where the electric wires are attached to. The unit turns the compressor on and off. The unit is attached to the compressor side with an "electric outlet" like three holes and three prongs. It might be held tight so you can pry gently (between the unit and the compressor body) with a screwdriver. Once pulled out, release the wires connectors that are attached to the relay/ overload unit. You might need to use pliers as they are tight fit. If unit smells like burnt or if you shake and hear rattle then it?s bad. Find a local appliance parts distributors and call to see if they have part for your model/ type. Remember to unplug AC before starting to work on the fridge and good luck.
Jun 29, 2008 | Refrigerators
Faulty defrost timer, overload relay, cap, compressor?
when it ran over night did it cool properly or not if it did then the relay/overload might be bad if it did not you might hae a different problem ill check with you tommorow for an update
Jan 02, 2008 | Amana ARB2517CC / ARB2517CB / ARB2517CW...
Quick Fix?
Nov 05, 2007 | Amana ARSE67RBB / ARSE67RBW / ARSE67RBC...
Apr 25, 2007 | Amana ASD2622HR Side by Side Refrigerator
Amana ARSE67RBB / ARSE67RBW / ARSE67RBC Side by Side Refrigerator Logo
81 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
