Need wiring diagram for electric fireplace model EF-ES-GB3W
Power toggle switch failed (overloaded). Need wiring diagram to rewire and correct potential recurrence of overload.
  • 3 Answers
SOURCE: Have a hampton bay 24000
I checked wiring on my other 17,000 BTU Hampton bay AC & noted there was no overload switch wired into capacitor. So i just removed the burnt out overload switch which was causing a ground & blowing breaker. I noted it was not wired in between the compressor circuit but just attached to the compressor terminal & common terminal on capacitor. I guess it is a sacrafise type device that saves the compressor from burning out on overload. Anyway The AC worked fine with the burnt overload switch removed. It has been runnning 2 days now with no problems. I however did replace the capacitor with a new one. You can use either an oval or round capacitor as there is ample room. Just make sure your cap. values match old one. I will probable try & purchase a new overload switch if possable & install it at a later date, for the extra protection.
Angelo V.
Posted on Jul 21, 2008
koolbreezes
  • 540 Answers
SOURCE: overload burnouts
Check the back coil from the inside and see if they are plugged up, where the fan blades throws the water and air on the back coils ( If this is plugged solid and can,t get rid of heat, the Iamps wll climb and tripp out the overloads, and will restart later on when it cools down and continue to trip this cycles till the overloads burnout! Thank You very much!
Posted on Nov 05, 2008
SOURCE: A/C stopped working because contactor melted, new con. installed
no we did not solve, also we do not have your slim a/c but an old outside model as above.
sorry if I have filed in the wrong box for help.
L.Nejedlik
Posted on Jan 30, 2009
  • 653 Answers
SOURCE: furnace overload limit switch
Here is the service manual with wiring diagram.
Posted on Dec 19, 2009
  • 110 Answers
SOURCE: I need to replace the fuse on an electric
If you can't find the fuse how do you know it needs to be replaced?
The fuse will probably be located at the beginning of the circuit, so somewhere near the plug.
Posted on Mar 06, 2010
How to rewire a GE 75423 electric fan
Four wires coming from base to motor. I need a diagram of which wires connect to the electrical components in the base.
Aug 26, 2012 | Dryers
INtermatic Model ST01 timer is to be used in a 3 way switch arrangement. The unit works in one switch position but fails to allow the light to turn on in the other switch position. Several other switches...
ST01C timer replaces one 3-way switch and the other 3-way switch remains.
The ST01C timer does not work exactly like a 3-way switch.
When the timer blue and red wires are connected together, they reverse whatever program is in effect.
When the timer is wired for single-pole, the red wire is capped off. When timer is wired for 3-way, the red wire is used to reverse the timer, thus causing the 3-way effect.
So if timer is ON, and red and blue wires are put together, the timer turns OFF.
That's why the remaining 3-way switch has to be rewired.
The remaining 3-way switch is rewired so it will connect and disconnect the red and blue wires, causing the timer to reverse program each time, and creating 3-way effect.
Other requirements of ST01C is that the black wire must connect to Hot wire, and the blue wire must always connect to Load. This means that you have to correctly pick which 3-way switch to replace, where the hot wire from breaker arrives.
Open following link for wiring diagram showing how to wire for 3-way:
http://waterheatertimer.org/ST01C-program.html#ST01C
All 3-way timers require rewiring second 3-way switch to create 3-way effect.
Jun 21, 2011 | Microwave Ovens
My electric fire is just blowing cold air?
It sounds as if the heating element has burned out (which is very common with electric fireplaces) or it overheated and the overload switch turned the heater off. Since you didn't mention who the manufacturer of your fireplace is or the model number, it's hard to make any suggestion on how to solve the problem. Other than one: Turn the fireplace OFF, unplug it and wait 30 minutes to plug it back in and hopefully, it will reset itself.
Mar 02, 2011 | Heating & Cooling
I NEED TO REWIRE A DOERR LR22132 ELECTRIC
The green should be connected to the chassis, it is ground.
There should be a wiring diagram on it to tell you how to do this, but if not:
There may be T-leads on the motor labeled
P1, P2, T3,T4,T5,T8
P1-L1(black wire)
P2-cap/tape don't use.
T2,T3, and T5 wire nut together
T4,T-8 wire nut together with L2(white)
The power leads will be coming from your switch box on the compressor body itself. Don't wire the 220v directly to the motor, you replace the leads where the first motor was connected on the cutoff switch. There will be only 2 leading from the switch to the motor.
Mar 24, 2010 | Plumbing
I need to replace the fuse on an electric fireplace heater model EF-ES-GB3W. I cannot locate the fuse location.
Mar 06, 2010 | Heating & Cooling
I'm attempting to wire a 3 way switch with a dimmer
Hello Chris,
What has happened, is that you've got th two "traavelers" reversed on the plain toggle switch. These are the RED and BLACK wires. turn off the power and reverse the position of these wires and the switch should work correctly from either the Dimmer switch or the plain switch.
Here's a link with a diagram, which might not exactly match your circuit configuration, but you can also watch a short video that explains how 3-way switches work.
It is just a matter of getting the travelers on the correct screws in order for the circuit to operate properly from either switch. Also, depending on the type of dimmer you've installed, the other switch will only turn the lights on at the dimmer setting that you've left the dimmer switch in. So be sure that you're not turning the dimmer all the way down before you shut it off (at the dimmer) otherwise, the other 3-way switch won't be able to turn the lights on, regardless of whether you've got the travelers in the correct locations.
Remember to turn the power off to the circuit you're working on while you rewire it and flip the breaker back on when you're done.
http://www.electrical-online.com/3waydiagram.htm
Hope you find this Very Helpful and best regards!
Nov 17, 2009 | Lutron Dimmers S103PNL 1000W 3-Way, Preset...
Need correct MOB location for power switch on emachine W3410.
what kind of motherboard did you change..?
try to search in the internet.. just type the name of the board and including the diagram.. sample.."ASUS MOTHERBOARD POWER DIAGRAM"...
Apr 27, 2009 | Computers & Internet
I need a wiring diagram for a 1986 strat style washburn guitar with humbucker and two single coils pickups. three toggle switches and a volume and a tone knob
Hi vallast
Here is a diagram on how to wire your 3 toggle setup.
3cd7a58.gif There are endless variations on how to do it. Pickups can be switched in and out of phase, in parallel or series.
Check out here for more details on the above wiring diagram.
Strat style wiring is done with a 5 way switch generally. Using the toggles allows you to rephase vitually all the pickups getting heaps of different tones. Thanks for using FixYa, good luck. A decent guitar Tech can easily help you to rewire your Axe. If you get stuck. hit me back here and I will help you further:) Cheers.
regards
robotek
Apr 13, 2009 | Audio Players & Recorders
Rewiring Fireplace Electrical Insert
I looked up regular electral diagram for the different elements.
Dec 15, 2008 | Leisure HOMEPRIDE Electric Fireplace...
Heating & Cooling Logo
61 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
