SOURCE: wii will no longer read wii disk and tried different wii disk.
try unplugging it for at least 5 minutes and then plug back in and retry.
Fiend your solution direct from nintendo. Here is your solution....
http://www.nintendo.com/wiiconsole/prob676ijt65/solution
aqrtyctr-85
SOURCE: disk won't work
Did you put it in correctly? If the Wii is facing vertically, the side with print on it goes AWAY from the buttons. Anytime you put in a Wii disk in, the print side must go away from the buttons. Hope this helps :)
SOURCE: Power works; fan spins;light is
The most likely situation you have here is that the cd drive lens isn't reading, just because with a gamecube, it relies on that lens to detect if there is a disc inserted. Your best bet is to try and clean the lens with a que tip and some rubbing alcohol. Be gentle, only very gentle wipes back and forth in a circular motion, then dry it the same way. If that doesn't work, I can give you some tips on how to rip the thing apart and see if it is a connection inside somewhere
SOURCE: console won't read disk. when disk in console,
If you are getting that message then there is likely 2 reasons.
1: is because your disk is scratched up or something.
2: your disk reader that is inside of your Wii Console is out of place.
