Projector tv color is all wrong I need help - Televison & Video
  • 8,617 Answers
That can either be the Guns are out of adjustment or the CRT coolant needs replacement. You can verify if the guns are balanced properly by simply turning the color level down to zero. The picture should appear all gray like the old black and white Tvs. Any color tint would indicate the guns need to be balanced properly. If they wont balance out then its usually because CRT coolant has failed and that can be verified by looking into the lens of each CRt as its playing you will see bad crt coolant instantly if its present because the image will not be clear and you will see bacterial growth inside the lens if its bad Coolant.
Posted on Dec 09, 2012
My lg projection tv model rt 62na31rb curved color problems
you need to adjust the convergence setting on the tv.
http://www.youtube.com/watch?v=esk4nYZKFcg
enjoy the groovy music on the video
Oct 08, 2014 | Televison & Video
Want to change the convergence chip in my philips projection tv model#51pw9363/17f
Has a projector tv model 50p8341 philips that has a pink color to it work fine but the color, has a new board in it going to throw it in the trash is 10 years old if you no anybody that need parts let me know. no one can tell me what is wrong . would you no?
Feb 19, 2013 | Philips Televison & Video
My Infocus 4805 is just showing the INFOCUS logo and not showing the picture from the TV. all connections are correct but no signal....help
Powering On
  • If your InFocus 4805 projector is having a hard time powering on or doesn't power on at all, it could be one of two things. Due to the extreme temperature of the lamp that causes the temperature of the projector to rise, every InFocus 4805 projector has a cooling system. Check your projector's cooling solution, as it may need to be replaced. Also check the projector's fan---if the fan doesn't spin, the unit will not turn on. If the problem is the fan, you'll have to get it replaced. You can do this at the same place you bought your projector.
  • The Lamp
  • If your InFocus 4805 Projector powers on but does not project any light, the lamp will need to be replaced. All projector lamps must be replaced at some point---how often usually depends on how much use the device gets. Simply order a replacement lamp, unscrew the old one and screw the new one in. The projector will then work like new.
  • Color Wheel
  • If your InFocus 4805 projector powers on and is displaying images but the colors on the images appear warped or are not in the proper places, your "color wheel" will need to be replaced. The color wheel is a small device that essentially acts like a prism. Light is projected through it and it displays the appropriate colors on screen the way they appear in the original video source. Order a replacement color wheel that fits your model and use your instruction manual as a guide as you swap the old one out and put the new one in.
  • Aug 08, 2010 | InFocus ScreenPlay 4805 Multimedia...
    My sony color rear video projector tv has fuzzy picture & colors seem to un together
    I think it something wrong with the convergence circuit, two STK ICs need to replace, the Generic part # like STK394-160E. you can check on the IC. The price approx $35.
    Apr 28, 2010 | Sony KP-53V75 53" Rear Projection...
    I was just given this t.v because friends couldn't figure out what is wrong with itl. The colors don't line up right,looks kinda blurry depending on the lighting of the program being watched. How do i fix...
    According to the manual:
    1) go to the "TV Main Menu"
    2) Select "Screen"
    3) Select Adjust Projection TV (obviously only if a projection TV).
    This then allows you to adjust the TV's 3-colors. Selecting GREEN CENTERING brings up a control panel that lets you center the green projection tube on the screen. Selecting RED CONVERGENCE or BLUE CONVERGENCE lets you align the Red & Blue projector tubes. Centre the green projector tube 1st. Then adjust the red & blue until the test pattern on the TV screen appers white.
    Good Luck!
    Jun 08, 2009 | Proscan PS50700 50" Rear Projection...
    I HAVE A RCA 52 INCH SCREEN WHILE I WAS WATCHING IT THE SCREEN WENT TO A CURVE SHAPE AND THE COLORS ARE GHOSTING. MODEL #R52WH74.WHATS WRONG
    you have a very common tv projector problem bad convergence
    you need stk ic big chips on large silver heat sink.cost to fix from tv shop is around 250 to 400 depends who you get part are only 45.00 dollars
    I hope this helps good luck
    doctor video leadingedgelectronics since 1987
    Apr 29, 2008 | Televison & Video
    T5AH250V
    Hi there
    You can buy it from your nearest TV or AV Repair shop.
    Apr 01, 2008 | Panasonic PTL-520U 2000 ANSI lumens/SVGA...
    51 magnavox projection tv-color mixing wrong
    The are controls on the inside of the tv above the circuit boards for focus and to turn up intensity of the projector lamps (red, green, and blu). If you turn it up too far all three projector lamps kick off. If this happens, power off the set and turn down the lamp that you turned up. Power it back on and slowly turn the projector lamp up until the picture looks OK. You have to take off the panel on back of set to get to the controls.
    Nov 19, 2007 | Philips Magnavox 51MP392H Rear Projection...
    Televison & Video Logo
    26 people viewed this question
    Top Televison & Video Experts
