Question about GE Energy Star WCVH6260F Front Load Washer
How do i enter service mode?
I am having problems with my washer. will not complete a cycle, leaves 1 minute on timer and sometimes the door won't unlock. how do i enter service mode to check for trouble codes?
  • 2 more comments
  • mkspmom Jan 13, 2009
    I haven't had the door remain locked but the hanging at 1 min is happening.
  • combatmech Jan 16, 2009
    My washer has the same problem the door stays locked and it stops working
  • ruhtra48 Jan 23, 2009
    I have watched the machine try and retry the spin cycle. It appears that if the load is too far out of balance it will never go into high speed. I find the only way around this is to open the unit a "unwind" the towels then try again. Most of the time this allows for a high speed spin. I have found this washer to be a lemon during the first year I have owned it. Have had GE out here at least six times. They even replaced the motor and drum shaft bearing due to a squealing noise in the spin cycle. They will be here again Monday because of the poor spinning situation. Will let you know if they find a fix.
  • mkspmom May 11, 2010
    Does it ever get into a real good spin? Mine will sort of rinse but won't ever get a good spin cycle going and will finally try to fill and rinse while staying at 1 min. Never finished the cycle.
  • 3 Answers
I had the same problem and here is what solved the issue.
In the front of the machine under the door is a panel. Take off the 3 screws holding panel on. You will see a white looking plug, this is your drain trap. Unscew it 3 or 4 times then pull it out and clean it. If the washer is not draining properly it will not go into a high spin or appear to not work properly. You may want to get something to catch the water that will come out when you open the drain trap.
Good Luck!
Posted on Feb 14, 2009
How do I pull up error codes
Follow these steps to enter the service mode on a GE front load washer. 1. Close the door.
2. Clear current cycles by pressing the power button. Make sure the screen is blank before attempting to enter the service mode.
3. Disconnect power to washer for at least 30 seconds.
4. Reconnect the power and within 30 seconds of reconnecting power complete the next step.
5. Press signal -delay start -signal - delay start.
If you successfully enter the washer into the service mode, t01 will be displayed and the door will lock.
Here's a link to the codes: http://www.appliance-repair-it.com/GE_front_load_washer.html
Good luck with your troubleshooting!
May 28, 2014 | GE WCVH6260FWW
Washer stops during normal wash cycle for a minute or more, and then continues. Would replacing the timer fix it?
If it actually goes on and finishes the cycle and that really bothers you replace it. If not leave it alone and allow a little more time to complete its cycle. The lid switch only keeps the spin cycle from going with the top open.
May 23, 2014 | Whirlpool Washing Machines
Kenmore model # 110.244222300, Won't automatically complete wash
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.#######) and you'll see a list of major sub-components with diagrams and parts.
Following is a Whirlpool / Kenmore service manual for top load, direct drive washers.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
Initial thoughts are that the Timer is worn / broken.
Here is a description of how to gain access to the console on these washers where you may be able to test the timer. (See the Whirlpool service manual for testing)
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131
Jan 19, 2010 | Kenmore Washing Machines
Washer only runs on drain cycle. Cannot engage any other cycle. Water does not enter the washer.
Door switch The door switch is important because, if it's defective, the dishwasher won't work at all. To reach it, you need to remove the control panel cover, or sometimes the interior liner of the door. If it's defective, you need to completely replace it.
Wiring check the wiring to the door switch, the wiring between the door and the lower part of the dishwasher, and the wiring to the timer. Timer or selector switch Although it's uncommon, the timer or the selector switch may be defective. If so, you need to replace the defective part, because neither of these can be repaired.
Aug 11, 2009 | Dishwashers
Maytag neptune MLG2000AWW does not turn off at end of spin cycle
d sounds as if your having a timer issue here. not recognizing the end of cycle and entering a new one ( bad timer).. as far as time of unlocking this is normal, theres a wax motor holding the door shut for i believe 3 min's.. and the water sloshing sounds is also normal they use a "water filled" balance ring around the perimeter of tub to help with the overall balance of machine
Mar 20, 2009 | Maytag Neptune MAH5500B Front Load Washer
Intermittant trouble with code d 11
Answer Duet HT®
Duet®
duet_f_dl_actualsize.gif Duet SportTM
This error code indicates that the door is not locking.
Is the washer door firmly shut?
The door must be completely closed for the washer to operate. The door may look as if it's closed, but it may not be latched. Open the door and firmly close it.
Were you washing a large load?
Before you close the washer door, check for laundry items sticking out beyond the door opening. Leave enough space in the washer to allow the clothes to freely tumble. Reduce your load size if needed.
fl_doorseal.jpg To remove the error display, press Pause/Cancel twice.
If Pause/Cancel does not work:
  1. Unplug the washer or disconnect the power for one minute.
  2. Plug in the washer or reconnect the power.
  3. Re-select the cycle and press Start.
NOTE: If the error remains on the display, and all of the other conditions above have been checked, call for service.
Dec 19, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore Elite top load washer timer will not rotate by itself through the wash/rinse/spin cycles
Gkar06,
Hello
Welcome to fixya.
I'm Huuum and happy to assist you,
You said, Each portion of the wash/rinse/spin cycle work correctly, but you have to manually move the timer to each cycle.
This tells us the timer is bad and needs service to replace it!
You will be fine, it is not a big job!
If you like you can try this first!
Like with an error code.
This can reset the system if it is electronic!
Unplug the washer and wait a 5 minutes then restart it.
If you can't reach the plug, use the breakerto cut the power for 5 minutes.
It's like rebooting your computer when its acting strange!
Usually it corrects some error problems if they are not serious.
Or they are sometimes just a glitch.
let me know how it works out.
How old is the appliance?
Let me know!
Please remember to enter a rating before you leave.
Thank You
Sep 25, 2008 | Kenmore 24032\24036 Top Load Washer
GE Energy Star WCVH6260F Front Load Washer Logo
153 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
