When i turn the key to start the car the security light comes on and shuts down all systems
It
can be any of the car doors not got properly locked or the door is locked but
the switch is not sensing the door locked. Open and close each door again
properly. Or
else its problem with any of switch wiring getting in contact
with alarm wiring causing it to happen. And
last thing alarm connections need to be inspected. It's getting short somewhere
in between. There
is a help link with solutions, to troubleshoot these types of problems.
I suggest going through these link. Click
the link below: ------ CAR ALARM ISSUES
http://alltypesofpartsreplacing.blogspot.com/2012/11/factory-alarmsecurity-system-alarmcar.html
SOURCE: 1999 Chevy S-10, how can I bypass the Security Fuel shut off sytem?
the way that i was told how to do a quick fix for is to hold the key in the electrical start and the actual start up of the engine and hold it there tell the security light is solid and then turn off the truck then bring it back to that point and let it blink until it turns off then you can start the truck.
SOURCE: 2002 Monte Carlo wont start
sounds like your passlock sensor on the ignition barrel is faulty. you will have to go to the dealer to have it replaced because of the programming after replacement.
SOURCE: Security light stays on, and car won't start.
leave key in "ON" position (not start) for EXACTLY 10 MINUTES! As SOON as the light shuts off, turn key and start key.
Every time you put key in, turn and start right away, DO NOT HESITATE.
There is a problem with the car's computer causing this problem IN ALL GM VEHICLES.
SOURCE: chevy cavalier z24 theft system light on
This is a easy fix. Lucky just follow the procedure and your car will start. This is a theft system shut down.
The procedure is. Disconnect battery for a minimum of 30 seconds. ( one post is OK. )
Reconnect battery and get in the car and start as usual 1 time only. When it starts and stops letthe key just return to run position as if it was running. Do not shut it off and if you do you must stert the procedure all over again. i usually put on the emergency brake before i start and that shuts of the driving lights etc.
Just leave the key in on running position and go have a coffee. it takes 15 to 20 minutes for the car to recycle the system. When you come back to the car the flashing theft light will either be off or solid.
Try to start again. If it doesn't go shut it off and turn back on and start as usual. It will start and run and stay running.
The reason you have this problem is something electronic was disconnected whe the battery was hooked up. always disconnect the battery before you touch anything electronic and you will not have this problem.
SOURCE: 99 chevy cavalier theft system light on steady, car wont crank.
My 2000 cavalier has done this for 6 months. You take your key out then open your door, wait ten minutes and the system resets itself and the car will start-annoying you bet!!!
