Question about Kitchen Ranges
I hv glem gas cooking range of 5burners fm saudiarabia......i am in bangalore please let me know the service centers in bangalore for replacment or service of burners......my id is latkas_2000@yahoo.com
SOURCE: Dynasty DGRSC 30 Gas Kitchen Range parts replacement
Have you tried contacting Jade Products who manufactures Dynasty ranges? 866-607-5694
Posted on Dec 28, 2007
SOURCE: will not cook properly with downdraft vent on. JDS9860AAP Range
You can purchase a 2 burner cartridge. However, the problem I'm having with that is the gas is too high and is unable to cook anything on low.
Posted on Feb 13, 2008
battlesmith
  • 382 Answers
SOURCE: lighting pilot light on magic chef gas range
Hello Jim,
Try to replace the ignitor if it is more than 3 or 4 yrs. old..If it not that old then Turn the knob to the pilot setting and depress the handle. Holding it down and at the same time, press down on the red button that sparks. You may have to repeat this a few times. Once the pilot lights, continue to hold down on the pilot knob for about 30 seconds. When you release the knob, the flame should stay oN. If it does not, replace the thermocouple. Once the pilot flame is steady, turn the gas valve knob to on!!!..Thank you...
Hope this helps you!!...
Regards!!!....
Posted on Jul 24, 2008
SOURCE: Low Heat from GE XL44 gas range
you can increase the sides of the flames by opening the orifices, if not differences. make the orifices holes a bit bigger, you can have as big of a flame as you want. those orifices are at the connection of the burner with the valve that supplies gas to the burners.
Posted on Dec 09, 2008
jsrock516
  • 5911 Answers
SOURCE: Opening the cook top in a Whirlpool electric range
The cooktop on this model range will lift up, exposing the surface burners and wiring harness. The screws are located along the bottom of the frotn edge of the cooktop. You will need to open the oven door to see them. Just follow these steps:
Before you begin:
1. UNPLUG the range before servicing. There are dangerous voltages still present even with burners turned off.
2. There are a few screws located under the front edge of the cook top. You will need to open the oven door to see them. Remove these screws and the top should lift up. If the range is not equipped with any kind of hinge supports, the top will have to be propped up.
On some ranges, there is a disconnect plug for the surface element wiring harness. If you have this feature, Follow these steps:
a. Unplug the cook top and leave the elements in place.
b. Place the whole cook top assembly face-down on a soft surface (like some old towels, or a blanket).
c. Remove the bad surface element by removing only the bracket pair that the affected element is attached to. Leave the rest of the elements wired together. Write down the wire color codes so you can be sure the new element is installed correctly. HINT: A digital camera can save you some time.
d. When installing the new surface element, make sure you use the same alignment marks (the numbered positions around the perimeter) as the old element. Avoid touching the burner surface and handle with care. Try to handle from the underside of the element only. Oil from your hands can cause damage to the element and/or premature failure. The elements are fragile.
If the wiring harness does NOT unplug, prop the cook top in place and install the surface element from underneath. A helpful hint: Use some duct tape to hold the assembly until you have screwed it back into place. Don't forget to remove the duct tape when completed.
If you have any questions about this repair, please let me know. You can reference searspartdirect.com for some helpful exploded view diagrams of you range for assistance if you need it. I hope you find this information helpful.
Posted on Nov 12, 2009
Testimonial: "Did not update until late, thanks for the detailed directions. No hinges on my stovetop, just detach and remove. Thanks, again!"
I tried to use the oven part of the glem gas, the igniter fires it up but it turns off as soon as I remove pushing the knob
can you smell any gas when the knob is set ?
before you ignite
in none or only a small smell of gas
can only think the gas valve faulty on that knob or the
gas pressure to the burner is lower than it needs to be
this is an example its a glen gas double oven
Oct 17, 2016 | Kitchen Ranges
Adjusting Air/Gas mixture on a Glem Gas cooker
The only change I know of is a jet change, from bottled gas to natural gas . it may pay to have the regulator pressure checked .
Aug 03, 2015 | Kitchen Ranges
Fix please
I PURCHASED GAS-ELECTRIC COOKING RANGE FROM SAUDI SOME YEARS AGO. NOW I AM SETTLED AT MOHALI NEAR CHANDIGARH. PLEASE LET ME KNOW DETAIL OF SERVICE CENTERS AROUND OR IN CHANDIGARH/PUNJAB.
Jul 04, 2013 | Ovens
Sir my acer model is 4736z shift keys are locked what is the remidiation and let me know bangalore acer service center thank you
Open RUN and type DEVMGMT.MSC, now the device manager window will open. There you can able to view the keyboard. Click on the + mark and under you can able to view the expanded keyboard name. Right click on that and select un-install, reboot your pc and check. If the issue continues you can contact the service center (Compherals).
The address follows:
Acer Customer Service Center, Compherals, #2A, Alsa Glenridge, 32, Langford Road, Bangalore, 560025, TEL: 41526018/19/20.
Please let me know for further assistance.
Dec 21, 2010 | Computers & Internet
SERVICE CENTER ADDRESS OF I-MATE IN BANGLORE
These are the main and most popular I-mate and Cell Phones service centers in Bangalore:
1. Ambika Enterprises in Peenya S.I., Bangalore
  • #159/1, Laggere Main Road, Peenya S.I., Bangalore -560058
  • Landmark: Near Shani Mahatma Temple
  • Phone: 080-28912017
  • Mobile: 9886114468
  • Contact Person: Gandhi
2. Pace Communications in Dharmaram College, Bangalore
  • #38443, 2nd Floor, 3rd Cross, Dharmaram College
  • Bangalore -560029
3. Vinayaka Agency in Richmond Town, Bangalore,
  • #47, Lakshmi Building, Ashok Nagar, Richmond Town
  • Bangalore -560025
4. Adishwar India Ltd. in Indira Nagar, Bangalore,
  • #812, 27th Main, 1st Sector, H.S.R. Layout, Indira Nagar
  • Bangalore -560038
  • Landmark: Opposite ICICI Bank
  • Phone: 080-42134000
  • Mobile: 9731306601
  • Contact Person: Rajesh
5. Rathan Mobile Centre in Old Tharagupet, Bangalore,
  • #40/1, Old Tharagupet
  • Bangalore -560072
6. Sai Nagasri Communication in Seshadripuram, Bangalore
  • #47, Bangalore Complex, Seshadripuram, Bangalore -560092
  • Mobile: 9342120667
7. Tata Prepaid Store in Frazer Town, Bangalore
  • #25/130, B.S.A. Road, Tannery Road, Frazer Town
  • Bangalore -560005
8. Vodafone Inn in Koramangala, Bangalore
  • #270, 1st A Main Road, 7th Block, Koramangala
  • Bangalore -560034
9. Online Communications in Brigade Road, Bangalore
  • #1& 137, Business Point, Ground Floor, Brigade Road, Bangalore -560025
  • Landmark: Near Brigade Towers
  • Contact Person: Abhishek Jain
10. Ess Telecoms in Gandhi Nagar, Bangalore
  • #4, Bajaj Complex, K.G. Road, Majestic, Gandhi Nagar
  • Bangalore -560009
  • Landmark: Near Anand Rao Circle
  • Mobile: 9845351670
11. Soniye Mobile Shop in Domlur, Bangalore
  • #19, B.D.A. Shopping Complex, Domlur
  • Bangalore -560062
  • Contact Person: Tajas
12. Cell Clinic in Seshadripuram, Bangalore
  • #1,1st Main Road, N.S. Iyengar Street, Seshadripuram
  • Bangalore -560020
  • Landmark: Near Jala Ashish Apartment
  • Mobile: 9886114409
13. Deepumalaya Mobile Communication in Marathahalli, Bangalore
  • #5, MSR Complex, Ring Road Junction, Varthur Main Road
  • Marathahalli
  • Bangalore -560037
14. Bharath Mobile Centre in Jaya Nagar, Bangalore
  • #427-1/12, 10th Main Road, 4th Block, Jaya Nagar
  • Bangalore -560011
If you need further help, let me know.
Good luck.
Thanks for using FixYa.
Nov 24, 2010 | Sprint Hitachi P300 Cellular Phone
I HAVE GLEM GAS COOKING RANGE PURCHASED 6 YRS BEFORE FRM SAUDI ARABIA. NOW IN INDIA CHENNAI. PLS LET ME KNOW THE SERVICE CENTRE DETILS
Please give me details of Glem gas cooking range service centres in Kerala . My id -mecentpl@yahoo.com
Nov 14, 2010 | Ovens
Can't get cook top open
Hi, the burners turn counter clockwise. they hold the burner to the top panel. Those need to be removed. Most of the time the tubing is disturb like this, they need replaced as well. Please let me know if this helps or if I can assist you further.
Thanks
Vic
May 23, 2009 | Magic Chef CGS3760 Gas Kitchen Range
Replace the switch lighter for magic chief cook top
I would like to replace all gas head(4 sets) of the Magic Chief gas stove in Thailand. How to find the service center?
Aug 16, 2008 | Magic Chef 31000 Gas Kitchen Range
Baking oven
if you got no display form clock assy ck the power lines leading to that control, unplug and relpug unit might have just glitched out, no clock no bake on this model all oven function run throughthis clock/control
Feb 28, 2008 | Tappan TGF363 Gas Kitchen Range
Westar watch repairs in bangalore
I need the address / contact details of the service center, where I can get my westar watch repaired.
Shalini Baig
Nov 05, 2007 | Watches
Kitchen Ranges Logo
24 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
