Question about Brother IntelliFAX 4100 Laser Fax
Change drum soon
Does the brother Intellifax 4100e reset the drum counter when a new drum uint is put in or is there a reset I need to preform
  • Anonymous Mar 14, 2014
    Brother intellifax 4100e replace toner reset
  • Anonymous Apr 01, 2014
    Changed drum need to reset counter
    Genius:
  • 2,120 Answers
Instructions are in the box that the new drum comes in.
Posted on Jan 13, 2009
SOURCE:
Brother IntelliFax-4100e There is a message on the screen to change drum, and I already changed it. Also, there is a squeggy noize everytime we receive a fax. I tried taking the drum, carthridge and I...
1. Open the front cover and then
press Clear.
2. Press 1 to reset.
However, the drum may be defective and causing the noise. Try a different one if you can.
Nov 16, 2010 | Brother IntelliFax-4100e Fax
Brother IntelliFax-4100e Fax Reset drum counter
With the front cover still open, you should press Clear ("Replace Drum?" should appear on the display), and then 1 for Yes. Wait for "Accepted" message and close cover.
It may be necessary to remove the drum unit and put it back in, and then, with the cover open, do the a/m procedure.
Nov 07, 2009 | Brother IntelliFax-4100e Fax
Intellifax 4100 e series- we replaced the drum
clear the drum counter.
open the front cover leave it open and then press clear button hit number 1 for yes and that's it.you can close the front cover. :-)
any other questions please let me know.
Mar 03, 2009 | Brother IntelliFAX 4100 Laser Fax
Intellifax 4750e, prompted us to change the drum soon. We did change the drum but it is still telling us to change drum soon.
We went to Brother website and obtained a manual and we were forgetting to reset the counter. Once the counter was reset, the message went away.
Jan 13, 2009 | Brother IntelliFAX 4750 Plain Paper Laser...
Fax Problem
Once you have changed the drum unit on Brother 4100 you will need to keep the front door open and then press the option button. Your dispay should give show you a drum change option. press 1 to change drum and the machine should show "accepted" after a few seconds. Afterwards, close the door.
Oct 28, 2008 | Brother IntelliFax-4100e Fax
"CHANGE DRUM SOON"
To reset the drum counter, follow the instructions listed below.
  1. Open the front cover.
  2. Press the Options key on the control panel.
    The display will show "REPLACE DRUM - 1.YES 2.NO".
  3. Press 1 to reset the drum count.
  4. Close the front cover.
May 30, 2008 | Brother IntelliFAX 2800 Laser Fax
Brother intellifax 4750e
You need to open the front cover, then press the "Clear" button, and then press "1". This will reset the drum counter.
Mar 27, 2008 | Brother IntelliFAX 4750 Plain Paper Laser...
IntelliFAX 4750 Toner Empty
Hi, have you changed the drum anytime soon? If so did you clear the message before installing the new drum? The only other option would be to try a diffrent toner. There is not toner reset counter like there is for the drum! So I would reset the drum counter and see what happens. Good Luck
Nov 08, 2007 | Brother IntelliFAX 4750 Plain Paper Laser...
Brother IntelliFAX 4100 Laser Fax Logo
478 people viewed this question
James Cagle
James Cagle
Jim Keysor
ctnozil
