Question about Toys
My greatland holiday express train doesnt run how can i fix it?
I out in new batteries and the light started working. The problem is that the bell, whistle, and the motor doesn't work. Please help!
I am now having this same problem as well. PLease help
Posted on Dec 17, 2013
SOURCE: Holiday Express Train Set
We struggled with this just today...finally figured out that you have to twist the small piece right behind the bell on the top of the locomotive.
Posted on Dec 19, 2009
Testimonial: "Thank you! Now... how do you keep it on the track? :O)"
  • 14 Answers
SOURCE: New Bright Holiday Express Animated Train - figures do not move
Make sure you the wheels on the cars are actually rolling and not sliding (being drug down the track) Most of the animation is down mechanically as the set moves.
Posted on Dec 16, 2009
  • 5 Answers
SOURCE: an electricalroblem with Holiday Express train
This train set is very particular and getting it to work each Christmas is a family tradition in frustration. First you must make sure that all the pieces of track are connected properly and that the track is perfectly symmetrical and flat. We double-check the battery positions every year and find one in wrong. There are + and - signs, but they're hard to see; use a flashlight. There is a black toggle switch below and behind the red stack that toggles forward (to make the train go forward) and backwards (reverse); straight out perpendicular to the train is the "stop" position. Also, you have to start at a stop/switch station. One other note: behind the red stack, there is a smaller black stack. If you turn this, you can make smoke come out of the stack. I think I remember someone suggesting a drop of cooking oil. Hope this helps!!! Hope you get it set up for Christmas!!!
Posted on Dec 24, 2009
SOURCE: My New Bright Holiday Express train set is 10
Make sure your track is clean. take a green scrub pad and rub the track to clean off any tarnish
Posted on Dec 28, 2009
SOURCE: No power to track and/or train. Power to Holiday Express Train
Power enters through the tender. You must have the tender and the engine both on tracks and linked with electric cable.
Posted on Dec 31, 2009
1994 Greatland Holiday Express train set. Where can I get at least two curved tracks?
There are places online that sell that track. It's pretty expensive. Measure the distance between the rails to get the correct track. Greatland may have the track, but if they don't, then look online for other places.
Dec 17, 2015 | MIA Toys
Have power to the track loco cab light turns on red bow lights up but train dosent move at all. No bell or ho ho and nothong on any of the other cars
Try new batteries in the controller Be sure they are in correct. The LED light should come on when it has power. Try moving closer to the train. Usually when the red light is flickering is when there is an engine problem. But here is the Manual just in case you did not have one. Also it has a number for lionel Service in there. Good luck. =) http://www.lionel.com/media/servicedocuments/60287110222501.pdf
Sep 30, 2014 | Lionel Trains Holiday Express G Gauge...
New bright greatland holiday express train
Check the connection from the transformer to the track, and that all the track is well connected. Make sure nothing is touching both tracks, shorting them out.
Nov 25, 2013 | New Bright 384 Holiday Express Animated...
I have an 01 alero that won't start. The security
the previous owner had the same problem with my alero, he had to go get a new security button put in or something like that
Aug 01, 2012 | 2001 Oldsmobile Alero
I have a Boreem 49cc, new battery but lights, horn etc don't work?
Your alternator might be bad. Check if your alternator is functioning well.
Apr 13, 2012 | Cars & Trucks
Remote is not working for my Lionel Holiday Tradition Express Train with new batteries. Any suggestions?
I rewired my train this weekend..it now works on my outdoor setup....I found that the circuit board inside the engine had a blown capacitor and the power transitor was fried. I by passed the engine board found that it only would run backwards....went into the tender and taped into the power from tack bypassing the rectifer... By the way the engine does not start up when one uses the remote...there is a 20 second delay before starting
Nov 27, 2011 | Lionel 11000 Holiday Tradition Express...
I turn on my 6505+ and after about 20 min or sometimes less it will start whistling. I've changed preamplifier tubes but no difference. This same problem happens every time I turn it on. The problem...
As you've already worked out Its more than likely a component breaking down. I'd take a good look at the circuit boards, look for a capacitor that's leaking, overheating or just the top is bulging out.
Oct 23, 2011 | Peavey 6505 Plus 120W Guitar Amp Head
99 mercury cougar replaced power window motor and switch window still does not work
That doesn't seem possible does it ?
You remove the inner door panel
You think the motor may be bad,so you unplug it,
knowing it is a DC Motor & can be hooked up either
way & will run in either direction
You put 12 volts to it. Doesn't work ,sounds bad,you
install a new one
Now you need power from the switch to run the new motor,
so you work on that
The switch can be disconnected & tested with an OHM Meter
& if worn,you replace that
You checked the fuse before you started & knew that wasn't an issue,
because all the other windows worked
So what did you mis ,short of having no wiring diagram, to make
things a lot easier?
Aug 04, 2011 | 1999 Mercury Cougar
Toys Logo
377 people viewed this question
Top Toys Experts
Andrew Taylor
Andrew Taylor
Are you a Toy Expert? Answer questions, earn points and help others
