Question about Samsung LN Televison & Video
Where is the T-Con Board located on Samsung LN55C610N1F
3 Suggested Answers
SOURCE: T-con board for your samsung
The t-con board is very easy to replace. The only problem is you need to take a bunch of stuff off before you can get to it. How to replace it:
1. Take off the back of the TV
2. Unplug all the wires connected to the middle boards, you will need to take off the whole assembly that the 2 boards are attached to, the main power board and audio/video board.
3. The t-con board is under the shiny metal cover near the top of the TV. There are four small screws holding the cover in place. (You should be able to see the cover when you take off the back plastic cover of the TV).
4. There are 3 connectors attached to the board. The white one that comes from the audio/video board and 2 small ribbon type that connect to the front of the TV, probably the LCD panel.
5. The 1 separate connector is self explanatory. The other 2 are a little more difficult. They just slide into place. When you look at the connection, there is a brown "flap" holding the ribbon in place. You need to flip it up from the top side of the TV.
6. The old t-con board just comes out and the new one goes in.
Hope this helps!
Let me know if you have any other questions.
Ben
Posted on Sep 16, 2008
lovejoy91
  • 691 Answers
SOURCE: hi where is the t.con board located in samsung
Usually it is the small board at the top middle of your set, most time it is behind a medal plate with 4 screws. There will be 2 or 4 flat ribbon cables connected to it. Hope this helps!
Posted on Dec 13, 2010
I have a samsung modle ln55c610n1f the picture gets dim and then back to normaal
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
http://electro-medical.blogspot.com/
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Nov 25, 2016 | Samsung Televison & Video
Samsung LCD... Power supply, t-con or inverter?
Samsung LCD TV Repair - TV Won't Turn On - How to ...
? 8:22
https://www.youtube.com/watch?v=n54IurMvr6o
Apr 4, 2014 - Uploaded by ShopJimmy.com
So in this video today we are going to be looking at a Samsung LCD and how to diagnose if you have a bad main or a bad power supply.
Samsung LCD TV Fixing Power Supply Problem - YouTube
? 10:52
https://www.youtube.com/watch?v=F6qgCg8lsxc
Dec 23, 2011 - Uploaded by Studio G Vision
Samsung LCD TV Fixing Power Supply Problem. Studio G Vision .... How switch mode power supplies (SMPS) work - Duration: 19:22.
Samsung LCD TV Power Supply Repair, Capacitor Replace ...
? 25:23
https://www.youtube.com/watch?v=lL0id3-YZsQ
Feb 9, 2013 - Uploaded by HandySavesMoney
... LN46A630 LCD TV. This procedure will apply to several otherSamsung TVs. ... Samsung LCD TV Power Supply Repair, Capacitor Replace, LN46A630. HandySavesMoney .... Country: Worldwide; Restricted Mode: Off.
Jan 27, 2016 | Samsung Televison & Video
How do I identify a bad capacitor on a Samsung LN55C610N1F power supply board?
you can tell by the top of them,when there bad they bulge ( as if there going to pop )
Nov 26, 2015 | Samsung Televison & Video
What component should I get to fix my Samsung LCD TV?
HI,
Probably the t con broad is faulty. t con board id the on which drives the LDC panel. I some tvs its not possible to replace the T con board as it would be integrated to the LCD panel normally in 32 inches and bellow. In others i would be separate board which is replaceable individually. I have added a video to know how to locate a t con board which is replaceable individuality. As you didn't mentioned the model number its not possible to add the exact image. In all most all the tvs T con Board (individuality replaceable one ) will be placed on the top center of the tv cover with a metal shield. If its incinerated to the LCD panel then inside the LCD protection metal chassis. Check and fin which one you have.
Samsung LCD TV Repair Identifying Samsung Con Board Part Numbers How to...
www.electro-medical.blogspot.com
Sep 10, 2015 | Samsung Televison & Video
I have the samsung 55 in lcd tv with the double vision ...i see the picture on the home page and it is exactly like the picture...how much will this cost me..i bought my tv back in aug of 2009...
If all pictures including the menus appear in double than most likely your T-con board or T-concable are defective. The T-con is located on the upper portion of the rear of the LCD panel itself. Here is a link where the board and the cable can be purchased. Note there are a few different versions of the T-con board and they wil not cross with each other. There is a bar code on the T-con board with numbers that corralate with the correct part number. Follow that before ordereing : )
http://www.shopjimmy.com/catalogsearch/result/?q=UN55B8000
Jul 25, 2011 | Samsung UN55B8000 55 in. LCD HDTV
My Samsung LN52A550 has vertical lines in the middle and right side of the screen is black
This most likely a problem with the T-CON board.
If this set is under warranty you should return it to get it repaired/replaced by the seller.
IF YOU KNOW HOW TO WORK WITH ELECTRONICS REPAIR(board replacement ) or have a friend with knowledge/skill you can fix it.
Sometimes due to heating/cooling or contamination the connection pins on the T-CON board and cables do not make good contacts. The T-CON board is located in the center of the set.
After taking off the back cover and shield over the T-CON board carefully remove the flat cables connected to the T-CON board. I believe there are 4. The connectors have a lip on them to hold the cables so be careful.
Now reconnect the cables. Recheck the display now. If it has not corrected you can disconnect and reconnect again.
The very first solution I entered on fixya.com had essentially this same problem and solution.
If this does not solve the problem you can replace the T-CON board.
The T-CON board look something like;
Mar 02, 2011 | Samsung LN52A550 LCD TV
No picture sound only
If the backlight works (meaning that when the tv is on, and the lights in your house are turned off, there is a black glow coming from the screen) then you know your backlight is powered and such.
So far, so good... the next problem lies in one of two places (most likely). It could be the main board which is where your connections plug into the set... If this main boards output to the t-con board is dead, then replacing the main board will fix this problem....
However the more likely problem is with the T-CON board. If you open your unit, there is a silver metal casing with some screws near the top of the screen. You will notice some metallic tape at the top of this metal piece. Also, you will notice a wire harness/ribbon cable connecting just under the base of this metal. Beneath the metal is the T-CON... This board is pretty much the only thing between your main board and the screen.
Replacing the t-con could fix your issue.
If you locate this board, there should be a model number located on the upper-right corner. Be sure and replace it with the correct part.
Please keep in mind that although I am tech savvy, I am not a certified samsung technician.
I hear that a good place to order such parts is shopjimmy.com
Good Luck!
Feb 09, 2011 | Samsung LN-T3253H 32 in. LCD Television
T-con board
small board at the top of the lcd panel under the shield
Jun 16, 2008 | Samsung LN-S4692D 46 in. LCD HDTV
Samsung t-COn board
the T-con board is located on the top of the lcd panel under a shield
Jun 13, 2008 | Samsung LN-S4692D 46 in. LCD HDTV
Televison & Video Logo
54 people viewed this question
Henry  Thomas
Henry Thomas
