Question about Keurig B100 Coffee Maker
After turning on my machinee it will only work occassionally. The water does does not flow through
The motor continuees to work but the water will not come through.
  • milliekarpman Dec 11, 2012
    the brewing process starts but either the water doesn't come out or takes a very long time. I can hear the motor running either way
  • 1,511 Answers
PLugged ports. Needs cleaning.
Posted on Jan 31, 2014
The unit was working filled up with water and then quit working. The LED's flicker but it doesnt turn on
It ispossible that the machine does not start off the cycle because there are errors possible failure of the controller unit. For the program to start up the main programcontroller must initiate the INLET/MOTOR/DRAIN pump/ valve to open up and allow each function to be driven starting fromthe flow of water into the drum as also the drain valve to open to exit thewater at the point of the program cycle. If this does not happen then thevoltage at the valve/motor/pump must be checked or the fault relates to novoltage from the controller. This meansthe controller is a suspect.If thewater flows though the inlet then the flow pressure should be good, if not theinlet valve is bad or there is dirt in the filter. Also check the flow at theinlet of the water line. Once the water comes into the system the WATER LEVELSENSOR - normally a pressure switch- must activate at the preset/chosen levelto give the signal to the program controller to switch on the motor. What ismost important for the motor to start functioning is that the door switch mustbe ON when the door is shut or this will be an error for starting the motor forrinse and wash.
Aug 03, 2012 | Whirlpool Cabrio WTW6600SBT Top Load...
Hi, My Hoover 600MB top loading washing machine is approx 8 years old. Recently it has occassionally not fully spun out - clothes still wet at end of cycle. Now it also often doesn't agitate - just...
Have a look for coins etc stuck in the drain pump or the tub outlet hoses especially where they fit onto the tub. If a coin or other foreign material blocks the water flow when draining , these machines wont spin properly.
Jul 26, 2011 | Hoover Washing Machines
Bissell Steam Cleaner
my cleaner is not spraying or sucking up the water?
May 10, 2010 | Bissell ProHeat Turbo Deep Cleaner Upright...
The water is leaking from where the drain hose is connected to the machinee. It is spilling a lot of water from here.
if you pop the back off or turn it on its side you can replace the drain hose
if you can get the part its easy to do its only held on with a spring clip on the drain pump
Oct 25, 2009 | Washing Machines
Hi, Seat Toledo 1996 occassionally cranks, fires,
check your air flow mass air flow sensor
Sep 11, 2009 | 1994 Volkswagen Jetta
PowerStar 125 not heating.
turn the temp to it;s lowest setting and isolate it from the other unit till it fires up, let me know if this doesn't work,, gary1121@ao.com
Jun 07, 2009 | Bosch PowerStar AE125 AE125 Whole House...
Water is not flowing in when turned on.
There are 2 solenoid valves that control the hot and cold water that fail occassionally. Try running just the hot or cold water (Its unlikely they both failed at the same time). If either the hot or cold works, then you have a bad solenoid valve. They cost about $25
May 20, 2009 | Kenmore Washing Machines
Water overfills and does not shutoff by itself to start machinee
It sounds like you have a faulty pressure switch. It is located in the top control panel. Sometimes, you can tap them and they will work (until they stick again.)
Nov 10, 2008 | Kenmore 22422 Top Load Washer
Keurig B100 Coffee Maker Logo
130 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
