Rival space heater model t 771 does not reach full heat
Spce heater blows warm at maxim heat setting
Buffalo12980
  • 625 Answers
SOURCE: reddy heat/scheu kerosene space heater no ignition
Typical kero heater uses either a spark ignition or a hot surface. The hot surface igniter is very fragile. A small bump may break the elements. Flame is detected by a photocell, signal is sent to the lockout relay board. Change the igniter costs about 50 bucks.
Posted on Nov 29, 2007
  • 74 Answers
SOURCE: Heater comes on but quickly over heats.
There is no Filter On this Model. Check to make sure there is Dirt in the Flow way of the two towers. if that is not it the back up fuse in the heater is going bad.
Posted on Dec 13, 2009
heatman101
  • 43501 Answers
SOURCE: I have a Janitrol space
The high limit switch is bad...on many of these furnaces it is a thermodisc type switch...the heater warms it up and it is cutting the furnace off too soon and then you don't get the heat that you should get...
Replace the high limit and you will be fine...
heatman101
Posted on Nov 30, 2010
SOURCE: i have a coleman evcon furnace model EB12B serial
Mine did that. My landlady had to replace the switch.
Posted on Dec 16, 2010
SOURCE: Where can I purchase a new Rival space heater,
I have two new ones without boxes, if ouy'd like to but one.
Posted on Nov 16, 2011
Bonaire gas ducted heating not reaching set room temperature anymore...
has the system air filters been serviced lately
is the system circulation fab been cleaned to allow full air circulation of the system
call in a technician to check for vermin infestation preventing the system from working properly
Jun 20, 2016 | Heating & Cooling
Bionaire heater sometimes turns on at very low intensity and just kind of chugs along as the yellow button flashes. It works fine just wondering why it does that
Amazon.com - Bionaire Heater with Rotating Grill ...
www.amazon.com > ... > Space Heaters
Amazon.com, Inc.Amazon.com - Bionaire Heater with Rotating Grill, BFH2242M-SM - Space ... The ultraquiet Bionaire® Heat Circulator with Rotating Grill circulates warm air ... High-intensity, sun-like warmth, Gentle heat, Medium intensity, whole room .... When temperature reaches what you have set it to, the heater turns off and sometimes.
Bionaire Office Heater with Worry Free Motion Sensor
www.amazon.com > ... > Heaters & Accessories
Amazon.com, Inc.
Rating: 4.4 - ‎71 reviews
Amazon.com - Bionaire Office Heater with Worry Free Motion Sensor - Space Heaters. ... Heat turns off after 30 minutes of no motion detected. ... If you place it under the desk, your feet will be very warm, but not so much the rest ... CONS: The High setting gets too hot sometimes, while the Low setting doesn't get hot enough.
Bionaire® Electric Fireplace Heater BEF6500-UM - Bionaire
www.bionaire.com/bionaire-site.../bionaire...heater/BEF6500-UM.html
The Bionaire® Electric Fireplace Heater provides the ambiance and warmth of a ...Flame Intensity; 12 Hour OFF Timer; Free Standing or Wall Mountable; 2 Heat .
Jan 30, 2016 | Bionaire Heating & Cooling
Unit blows cool air while in heat mode
model number? Heat pumps tend to blow cooler air than a space heater unless in money-gobbling mode.
Mar 28, 2014 | LG Heating & Cooling
Electric heater problems.
Plug in a ceramic 120 volt or oil type space heater to keep trailer warm. Most travel trailers are propane only, they do not have electric heat strips. I would bet that is why it only blows cold air.
Jan 28, 2014 | Open Range 2011 Mesa Ridge MR243F
Took 2000 dodge intrepid 3.2 engine to shop. NO heat. they sd it was the ac/heat control panel. they replaced it, when i picked my car up, still no heat. went and got another part from junk yard, now will...
the fact that after you changed the part from the junk yard it blew warm air indicates that the heater core is not the problem
could be the heater control is not fully opening or the junk yard replacement part is faulty
Jun 17, 2017 | 2000 Dodge Intrepid
I am trying to find a new switch for my Rival Titan Model T 771 Electric Heater.
http://rocker-switches.carlingtech.com/single-pole-switch__42.asp
I believe this is it
10A 250 VAC
15A 125 VAC
3/4 H.P. 125 250 VAC
They have a list of retailers who sell their products.
Dec 09, 2010 | Vacuums
Small Rival heater ... 1500 watts... model # T620/1 serial # 11-27 I love this small space heater.... but I've had it so long that the setting decals have worn off. I need to know where the heat/fan/...
Heh, I just went searching for mine because it was getting cold. The left knob is (from left to right) Hi, Lo, and Fan Only. The right knob goes from Off on the bottom left to Hi on the right. It doesn't click or anything, since it's the one controlling how hot you want it to be.
Oct 22, 2010 | Heating & Cooling
Heater only blows cold air but hoses are hot
Hi!
It appears we have an Air lock scenario and you will need to perform a system Bleed.
Park the vehicle on level ground, when cold remove coolant filler cap, start engine and leave to idle, turn heater on full and blower to max. When engine reaches operating temperature watch and listen near coolant filler, keep clear as gurgling and hopefully a boil over should occur. Top up with very warm coolant and wait as it may do it again.
Check for heat inside vehicle if warm replace coolant cap but keep an eye on temperature gauge as the ~Air lock may have moved on from heater matrix/core so proceedure needs to be carried out again from COLD.
If persistent boil ups/over attention must made in the cylinder head
or gasket area, or possibly water pump?
Please press the Blue button to appraise my FREE Efforts, Thank You!
Paul 'W' U.K
Feb 28, 2009 | 1996 Mercury Grand Marquis
Heater
First you have to make sure there is colant in the radiater to heat up...if full of coolant,try replacing the thermostat....very easy and cheap try...then make sure no air in system after filing,warming up vehicle,and shutting off a few times to work air from system...if there is still no heat and truck is running at temp(Aprox 200 degree) you may have a blocked heater core,and this can be cleaned by backflushing heater core..take both small hoses off of engine and water pump and run a garded hose through it both ways....good luck..Lee
Dec 15, 2008 | 1993 Chevrolet K1500
Heating & Cooling Logo
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
