Question about LG Computers & Internet
Function key is stuck on lg x120
My computer prints the small letters/numbers on the keyboard. I have to hit FN key to get the main letters.
    Sniper:
  • 85 Answers
Try restarting your computer on proceed to your BIOS settings. The same applies to all laptops.
Posted on Dec 11, 2012
Nitrotrike
  • 589 Answers
SOURCE: Panasonic Toughbook CF-51 laptop blue FN key locked on
Hit "FN" and the "NUM Lock" key together to unlock it.
I believe thats the combination.
Let me know.
Posted on Jan 09, 2008
  • 3 Answers
SOURCE: function keys
Hi you need to hold down the function key (FN) and press the number lock key (num lk). hope this helps
Posted on Jan 14, 2008
  • 16 Answers
SOURCE: What Fn Key enables the keyboard to type letters instead of #s
use fn key plus numlk key
Posted on Jan 13, 2009
SOURCE: letter keys are stuck on numbers don't know how to change them bo
Hold the "Fn" key down while pressing "F9" key, subtitled "Padlock" (!!) - is equivalent to NUM LOCK nomenclature used on most computers. Note - Repeating above resets number pad to ON.
If that doesn't work for you something is malfunctioning as far as I know.
Posted on Mar 08, 2009
BlacMamba
  • 215 Answers
SOURCE: the fn key function is stuck not the key but its
most times dust or damp culd cause a key to get stuck...so try using a suction blower to remove any residue left or take to an expert
Posted on Nov 11, 2009
Jumbled keyboard numbers
Are you typing on your laptop and notice the text has become illegible? What should be letters, have become numbers or symbols. This odd behavior can probably be explained be peering a little closer at your keyboard. Those little numbers on the keys. These numbers and symbols normally become active when you hold down the function key, usually labeled as the "FN" key. The "FN" key is similar to the Shift key, activating a second function assigned to a key. It can become active seemingly on it's own because a key is locked in the on position.
Before performing numerous key combinations, try the simple thing of lightly tapping the "FN" or "Num Lock" 5 to 6 times. There may be a small particle of something logged under the key that you can loosen, move, or crush down. Do not bang the keys, just press normally. Next focus on the "Numlock" key which usually located with the "Print Screen" and "Pause" key on the top right of your keyboard. Press the "Numlock" key, then press a scrambled key to see if it's normal. Older model laptops may require you hold down at the same time, the "Ctrl-Shift-Numlock" keys. Newer models may require holding down the "Shift" key and pressing the "Numlock" key. Turn off the Function key with the following combinations. Hold down the "FN" key and hit the "Numlock", Hold down the "FN" key and hit the "Scroll" key and Hold down at the same time "Fn+F12+Num Lock"
Feb 08, 2013 | Lenovo Computers & Internet
Keyboard numbers are jumbled
I can't turn the fn key off
The Fn key (also known as the Function key) is a feature found on most laptop computers. The Fn key allows keys on a laptop computer's keyboard to serve more than one function, a clever way of increasing the utility of the keyboard when space is limited. Dell laptops make good use of the Fn key, and if you own a Dell laptop, you should be aware of where the key is and how to use it.
Open your laptop and turn it on. Then locate the Fn key. It is located on the lower left side of the keyboard, next to the Ctrl key. Press and release the Fn key. Now examine the keyboard carefully. You'll notice that many of the keys have icons or letters and numbers printed in blue upon them. These keys and functions are operated when the Fn key is enabled, as you've just done. Test it out by looking at the lower right side of the keyboard. You'll see two keys with small blue "sun" icons. These control the brightness of the screen. Press the lower one several times and you'll see the screen darken. Press the upper one. The screen brightens. Press and release the Fn key again. Now try using the brightness keys. The screen brightness will not change. You've turned off the Fn key.
Feb 06, 2013 | Dell Inspiron 1501 Notebook
I want to know how to use the function button
The function button, or FN button, is used just like the shift key or ctrl key. Hold the FN button down and press the key with the pre programmed function you desire to use. For instance, on an HP 1245 the function or short cut key to put the computer in sleep mode is FN+F5. The Keys with functions have that feature indicated by a symbol for the function in a squared circle. Most of these are your F keys at the very top row of the keyboard. Some are on the number pad keys.
Oct 27, 2011 | IBM ThinkPad R31 2656 Notebook
HOW TO DEACTIVATE TEH Fn KEY IN DELL LAPTOP
Hi names Rui, to turn Fn in you dell you need to:
1. Open your laptop and turn it on. Then locate the Fn key. It is located on the lower left side of the keyboard, next to the Ctrl key.
2. Press and release the Fn key. Now examine the keyboard carefully. You'll notice that many of the keys have icons or letters and numbers printed in blue upon them. These keys and functions are operated when the Fn key is enabled, as you've just done. Test it out by looking at the lower right side of the keyboard. You'll see two keys with small blue "sun" icons. These control the brightness of the screen. Press the lower one several times and you'll see the screen darken. Press the upper one. The screen brightens.
3. Press and release the Fn key again. Now try using the brightness keys. The screen brightness will not change. You've turned off the Fn key.
The Fn key (also known as the Function key) is a feature found on most laptop computers. The Fn key allows keys on a laptop computer's keyboard to serve more than one function, a clever way of increasing the utility of the keyboard when space is limited. Dell laptops make good use of the Fn key, and if you own a Dell laptop, you should be aware of where the key is and how to use it. So i hope this will help you.
Jul 20, 2011 | Dell Vostro 1510 Laptop
My laptop is only typing the numbers that appear on the letter keys. For example when I hit the letter J, it types a number 1. When I hit the letter k key, it types a 2, etc. How do I get it to go back...
Usually you have to hold the "Fn" key to get to these. Look for a "NumLock" key to turn this off. You may need to use the "Fn" key to select numlock.
Mar 10, 2011 | Computers & Internet
The keyboard is locked. Instead of letters, it gives me numbers
Click Fn+Numlk as this switches your keyboard to the numbers printed in blue. Pressing that combination again, puts the keyboard back to normal. The Fn key will switch the function keys to the designated lower operation, so your F11 key has the NumLk operation controlled by the Fn key
Jan 23, 2011 | ASUS Laptop Keyboard for Asus Eee PC
My Fn key can't function!So are my arrow keys.
you need to dowload the hotkey utlitlity application from vedor site.
Jun 16, 2010 | Computers & Internet
Keying numbers instead of letters whun num lock on
Check 2nd Function keys. The problem you describe is normally a Fn +numlock keystroke on most systems
Dec 27, 2009 | Compaq Presario 700 470024-192 Notebook
Computers & Internet Logo
186 people viewed this question
Top LG Computers & Internet Experts
Michael Vincent Cruz
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
