Question about PfaFF Sewing Machines
My Pfaff 2046 just stops sewing. The machine wants to reset itself and then when I hit the pedal there is no power. Any ideas? If I let the machine sit for awhile and try again it will work for @ 10 minutes then do the same thing again.
  • PfaFF Master
  • 1,564 Answers
Intermittent problems such as yours can be caused by a few things. First move your machine to another area of your home to determine if it is the power in your sewing room.
Then carefully examine your foot pedal parts and cords. If you find a problem have that part replaced.
If these things don't work... take it in because it's a problem with the electronics.
Posted on Dec 10, 2012
SOURCE: pfaff 1222 and pfaff 1229
Have a certified repairman look at the power board in the machine. The power supply circuits are broken on the board itself. Can be repaired with wire and solder. How do I know? Just fixed my wifes 1229 that had the same problem.
P.S. New boards are NOT available from PFAFF or anyone else
Posted on Jan 20, 2009
SOURCE: - resetting the timing
I have been an upholsterer for over 30 years, I own a Pfaff 145 and Pfaff 545. Both are basically the same. Whenever my timing is off, where the threaded needle won't connect with the bobbin thread, I have always had success in re-setting the timing by taking apart the entire bobbin case. Remove the walking foot and the plate it walks on. Remove the bobbin and dismantle everything underneath it. Keep each piece and its screws together, and remember the order in which you removed it (last goes in first, etc.)Remove any obstructions, thread, fluff, etc. Surprisingly, when you put it all back together, your timing will be back to normal. This has always worked for me, and I hope it'll work fo you.
Posted on Apr 24, 2009
  • 13 Answers
SOURCE: Manual Sewing machine Pfaff 1229
http://www.sewusa.com/Sewing_Machine_Threading_Diagrams.htm
Posted on May 27, 2009
SOURCE: My Viking 5710 starts to sew without any pressure on foot pedal
Mine does the exact same thing. I think the problem might lie in the cord to the foot pedal. The cord packs into the foot pedal for storage, which forces the cord to to remain bent during storage. I believe the wires in mind became damaged and broken so I took it apart and reconnected the wires at the spot where the connector meets with the wires. But I still don't leave it plugged in if I'm not using it, it could be a fire hazard.
Posted on Mar 24, 2010
SOURCE: Pfaff Creative Vision embroidery/sewing machine says motor overload then shuts down
I had the same problem and it was my power supply. I've had more than my share of problems with this machine and it's only 3.5 years old. Good luck.
Posted on Aug 14, 2011
Needle hitting bobbin casing on Pfaff Quilt Expression 2046
If you have installed a brand new needle and it is still hitting, then the machine needs an adjustment. Take it for service.
Apr 01, 2017 | PfaFF Sewing Machines
How do you reset timing on Pfaff Creative 7570 Machine? Was sewing and heard loud pop, now will not work. Any ideas?
Hi Lisa,
"A loud pop" whilst sewing sounds as though a capacitor has blown probably in the power supply unit. I'd recommend that you take your machine to a Pfaff service shop to have it serviced.
To reset the timing on a sewing machine is a specialist job. To give you an idea of what it entails on a mechanical machine (your machine is electromechanical) have a look at this video
Good luck :)
Jun 21, 2015 | PfaFF Creative 7570
I have pfaff 2046 and the bobbin case will not face upwards. it is tilted to right side a little
Have you got your bobbin case and the area around it cleaned? This sort of thing often happens because there is a bit of lint stuck in the bobbin mechanism. Also, oil it! All sewing machines need a bit of a lube, even the new computer driven ones.
Nov 20, 2014 | PfaFF Sewing Machines
Pfaff hobbylock 776
it would be a good idea to have the pedal and the machine both checked. only a sewing machine repair shop can tell you what the problem is.
Jun 24, 2013 | Sewing Machines
My Pfaff 1229 doesn't stop sewing when I let off the pedal??
it could be a short in the wiring, the foot pedal, do you have a manual
for the machine?
May 30, 2012 | PfaFF Sewing Machines
I have an old Pfaff 90 Sewing Machine, largely mechanical. However, I seem to have run into an electrical problem. I was just sewing and pressed down the foot pedal and when I raised my foot, the needle...
I am pretty sure it is the foot pedal. It will need to be repaired. You might want to blow air inside to get rid of dust. The bottom usually slides to the rear. You can blow out all of the parts. You may want to slightly tap your foot pedal on the floor. Remove the thread first though. You may find that it will stop when you do this. Anyway, repair or replace.
Mar 24, 2017 | PfaFF Sewing Machines
Sewing Machines Logo
226 people viewed this question
Top PfaFF Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a PfaFF Sewing Machine Expert? Answer questions, earn points and help others
