Question about Sony SA-WM40 Subwoofer
Where is the fuse on a Sony SA-WM40 Subwoofer? It will not turn on
Trying to locate the fuse for the subwoofer. Turn on the unit their is not power. Does anybody know where the location of the fuse is
2 Suggested Answers
dunnbiker
  • 8546 Answers
SOURCE: My Sony SA-WM40 subwoofer has
Probably, or the woofer coil itself is experiencing a heat, volume or motion related short. Clean any dust or debris from the heat sink fins in the back. Make sure it has lots of space for cooling ventilation.
Posted on Mar 31, 2011
My Sony SA-WM40 subwoofer has power, but sound kicks out. I'll turn off power for about 5min and when turn power on, sound is back. Is something overheating?
Mar 31, 2011 | Sony SA-WM40 Subwoofer
My Subwoofer Sony SA_WM500 was always burn the fuse therefore I had to change the STK, but now it takes off sound very low, How can I have back the high sound level? Zaruque Quimuenhe
It's no clear what you mean by "I had to change the STK", but if that means you have somehow defeated the fusing or place a larger fuse than it requires then STOP and shut it off. You might be risking a fire or more serious damage to the amp.
I would recommend you find a hands-on tech to look at it.
If you have resolved the fuse problem and now just have low subwoofer volume, you might want to track it back to the source and ITS subwoofer volume setting. There IS a volume level control on the sub, too. Turn it up.
The manual is here:
http://www.retrevo.com/support/Sony-SA-WM500-Subwoofers-manual/id/752ag404/t/2/
Jan 11, 2011 | Sony SA-WM500 Subwoofer
My sa-ma40kicks off after it plays for a few minutes
This sounds like a power supply problem. If it works after is sits or cools, check at the power supply for bad or disturbed solder connections, a lot of time if you look at the circuit board where the component comes through you will see a small ring in the middle of the solder.
Dec 22, 2010 | Sony SA-WM40 Subwoofer
Sony SW no sound
does this sub have an LFE output? if so, connect that to the LFE input on the reciever and make sure it is set up properly in the set up menu in speaker configuration. if the sub has speaker line input outputs, connect speakers to input of sub and out of sub to amp/recvr
May 10, 2010 | Sony SA-WM40 Subwoofer
The speaker is starting to buzz during the low
It probably buzzes all the time, you just notice it when it is outputting little volume. Check the cables for loose connections or replace them with other cable as a test.
Mar 08, 2010 | Sony SA-WM40 Subwoofer
Unit blew the internal fuse. SONY SA-WMS367 SUB-WOOFER
Bad output IC or voltage rectifier are the most likely at fault.
Nov 28, 2009 | Sony SA-WX700 Subwoofer
Sony SA WX 700 - Fuse (6.3 A 125V) keeps burning out
The switching power supply transistors have shorted out. Other parts may be gone also. A difficult fix. Too bad, it's a great sub.
Sep 13, 2009 | Sony SA-WX700 Subwoofer
Sa-wx700 with no sound
If you are a rock music lover, chances are the speaker has burn out. try to turn on and place your ear near the speaker and listen for humming
sound. if no sound at all, then its the speaker
Jun 26, 2009 | Sony SA-WX700 Subwoofer
I don't have no power replaced the fuse still no power
i have a sony subwoofer with no power. i found out that the voltage regulator (ic's)are bad. check that.
Dec 07, 2008 | Sony SA-WM40 Subwoofer
Sony SA-WM40 Subwoofer Logo
113 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
