Question about Vizio E421VA 42 in. LCD TV
Firmware update vizio e421va
What does the firmware update or upgrade add?
3 Suggested Answers
  • 362 Answers
SOURCE: where is the audio output on my vizio e421va
simply doesnt have an output at all some do some dont yours does not route the audio signals to an A\V receiver instead
Posted on Dec 20, 2010
SD Tech
  • 14553 Answers
SOURCE: Vizio E421VA shuts down immediately after turn on
They are not usually available except by authorized service centers as no parts are really sold and only circuit boards are available in most cases.
Posted on May 24, 2012
How do I fix my Vizio TV model E421VA? Details are below. It has a black screen and no audio.
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Before going further; try a hard reset first. If it does not help you, replace the main digital board. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; visit the site linked here.
Nov 01, 2016 | Vizio Televison & Video
Visio e421va have stdby and power on light
This is going to be one of several problems. Very first think to check is fuses and capacitors. Then I would start with the power board. Check your voltages on the in and output side. If they are all good I would go to the logic board. That is the small board and pretty inexpensive. From there you have to go to the TConn, but I don't think that is it. The next step is the X and Y board. It is most likely going to be the Xboard. If you are not getting audio or video then you can unplug the logic board where it connects to the main board. If you get the sound upon turning it on with it unplugged then your logic board is one of the things that went bad. Most cases you will have to upgrade the firmware with your new boards.
Sep 29, 2016 | Vizio E421VA 42 in. LCD TV
Vizio m550nv logo blinking on ans off and will not power on
Corrupted firmware. An update is necessary. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
http://electro-medical.blogspot.com/
Firmware upgrade procedure to many TVs and other devices are given with illustrations.
Jan 17, 2016 | Vizio M550NV 55 in LCD HDTV
Getting no audio from speakers on a Vizio E421VA LCD HDTV, any ideas?
Do headphones work?
my guess is either the headphone socket or associated wiring/soldering is faulty or there is a faulty connector within (connector associated with the audio)
Jun 19, 2014 | Vizio E421VA 42" LCD HDTV
I have random restarts on my Vizio E421VA HDTV. Are there any firmware updates?
I have the same problem but only when using HDMI connection.
Jun 23, 2012 | Vizio 42 in. LCD TV
May 23, 2012 | Vizio E421VA 42 in. LCD TV
I have a Vizio Model E420VL and it gets into a state which the audio does not work (from HDMI input #1) and remote control processing in the unit also does not work. I had played around with the side...
hi,
It can be difficult to get things right on the first try. With that truism in mind, Vizio Incorporated includes USB ports on their televisions that you can use to load firmware updates onto the television. Vizio has released firmware updates only for certain television models, and the instructions for installing firmware updates vary slightly by model. To upgrade your television's firmware, you need to download and copy firmware drivers to a USB flash drive and then read and follow Vizio's specific installation instructions for your model.
1. Connect the USB flash drive to your computer
2. Click the "Start" button, and click the "My Computer" icon.
3. Right-click the flash drive, and click "Format" in the menu
4. Select "FAT32" in the drop-down menu, and click the "OK" button. Windows will format your USB flash drive with the FAT32 file system.
5. Open your Web browser, and navigate to the Vizio support Web site at www.vizio.com/support.
6. Click the "Select Your Product" drop-down menu, and select your model of Vizio television from the list. A new page will open that displays available downloads for your television
7. Click the "Firmware Update" link, and save the firmware update file to your computer.
8. Click the "Firmware Instructions" link, and read the instructions specific to your Vizio television model.
9. Right-click the file that you downloaded, click "Rename," and then rename the file to the exact name that is specified in the firmware instructions 10. Right-click the file, and click "Send to" > "E: USB Drive" or whichever drive letter corresponds to your flash drive. The firmware update file is copied to your USB drive 11. Right-click the "Safely Remove Hardware" icon on the right side of the Windows task bar, and eject the device from your computer
12. Disconnect the USB drive, and plug it in to your Vizio TV's USB port.
13. Follow the steps in the firmware instructions to install the firmware update to your television.
Only you can find is the problem with firmware by udating the frimware of your tv. ok
Aug 05, 2011 | Vizio E420VL 42 in. HD-Ready LCD TV
Some channels are snowy and some are clear and sound is not good on some channels as well.....i got the tv from a person who was having same issue so they gave it to me so i could get it fixed so was...
We literally have 1000s of LG TVs at work ranging from 32"-42" and beyond. Our joke is that LG stands for Little Good. We have to pay a few hundred dollars to replace the tuner board inside.
Jul 15, 2011 | Vizio E421VA 42 in. LCD TV
I just bought a Vizio E421VA last week. When trying to change the picture settings (brightness/contrast) using the Vizio remote, sometimes it just turns off all of a sudden. This also happened while I...
Hello, my name is Dan Busa with DISH Network. I happen to have seen this with other Vizio TV sets and would be very interested in taking a look into this. Even if you have resolved this please e-mail me at: daniel.busa@dishnetwork.com
Daniel Busa
DISH Network
Customer Service
Mar 21, 2011 | Vizio E421VA 42 in. LCD TV
Where is the audio output on my vizio e421va lcdhdtv. it doesnt seem to have an audio output just in puts.
Dec 20, 2010 | Vizio E421VA 42 in. LCD TV
Vizio E421VA 42 in. LCD TV Logo
262 people viewed this question
Top Vizio Televison & Video Experts
CoppellTVRepair.com
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
