Question about Garden
I am about to pull my hair out trying to find a carburetor or carburetor rebuild kit for my 2006 Yard Machine lawn tractor model 13AC762F729.
When I put fuel in the tank it quickly leaks out. It fills the carburetor and comes pouring out. I think it may be the float and or float needle that is the issue? Anything else you think it might be? I have been all over the internet trying to locate parts for it and can't find one single carburetor or carburetor part for this model. If I could at least find the part numbers I could cross reference them if need be for an aftermarket.
    Problem Solver:
  • 14 Answers
Yes your needle valve is bad or your float has in a hole in it.
Posted on Dec 09, 2012
  • 1 more comment
  • Susan Tapia Dec 09, 2012
    Thanks, that
    Thanks, that is what I was thinking. Any idea where I can find the part numbers?
  • bgduff366
    bgduff366 Dec 10, 2012
    i need your model # it should be under the seat , also there should be a model # on the motor is it a briggs motor or kohler and what size is the engine?Or send pics of the model numbers and engine to 903-767-five five eight four
  • 41 Answers
SOURCE: yard man mtd 20hp 46
go to the online web site for the yardman this will give you the guide on how to replace the belt.
Posted on Jul 12, 2009
SOURCE: Murray Lawn Tractor won't go up hill
Your drive belt is worn/slipping
Posted on May 31, 2009
mowerman1857
  • 389 Answers
SOURCE: looking for wiring diagram for sears tractor
Go to www.searspartsdirect.com Enter your model number in the appropriate box, when the page loads, look on the left side of the page where it says "Browse sub-components" and click on "tractor-schematic" this will open to a total wiring diagram for you
Posted on Oct 22, 2009
mowerman1857
  • 389 Answers
SOURCE: Carburetor problem on Craftsman 14.5 HP B&S
The switch you are talking about is an anti-after-run solenoid. It shuts off the fuel flow when you turn off the key switch.
To check its operation is easy, turn the key on and off a couple of times and listen for a click, if you don't hear it, hold the switch between your thumb and forefinger to see if you can "feel" it click on and off.If you neither hear or feel the switch working, you will need to use a test light or meter to check to make sure it is getting voltage to it to make it operate.
If you just recently filled up the tank, it is possible that you have gotten some contamination (dirt or moisture) that has gotten to the carburetor. You will need to remove the float bowl to check this. You will need a very thin 1/2" wrench to remove the solenoid (electrical device) from the bottom of the carburetor to get the bowl off after you unplug the wires from it. Use some sort of small tray or cut off the bottom of an oil container or whatever to catch what is in the bowl to inspect it for contamination.
If you have a plastic in-line fuel filter look at it at its lowest point to see if there is any water in it. Water will look like a seperate bubble within the gas and floating at the bottom of the gas. Before removing the float bowl you might want to rig up something to plug or pinch the fuel line to stop the gas from flowing out of the tank while you are working on it
Posted on Oct 25, 2009
SOURCE: looking for briggs+stratton repair manual 271172
wiill not start has all new spark plugs and fuel filter
Posted on Sep 13, 2010
15 hp kohler lawn tractor engine will start if fuel is poured into carburetor but dies soon thereafter. engine model # cv15s
clean or put a rebuild kit in the carburetor. be sure fuel is flowing to the carburetor.
Jul 29, 2017 | HP Garden
Diagram of carbuerator for MTD 17.5 Yard Machine
First your Model number is going to be 13AD688G300.
Second would to looking by make and model of the engine to anything on the carburetor. Even with that their very little in the line diagrams for carburetors. A lot the new engines that even have individual carburetor parts or rebuild kits available.
Aug 07, 2014 | Garden
Why does gas come out of the exhaust of my lawn tractor
Gas will blow out the exhaust when there is a problem with the carburetor. Ports may get clogged up with deposits; the float may stick and or the diaphragm may have holes in it. Most often a rebuild kit will resolve this. First off alway remove the carburetor and clean it thoroughly and access whether anything appears to be obviously the culprit. Next, either rebuild or replace as you see fit. I recently have had many issues with carburetors. One took a good cleaning to resolve, another a replacement resolved the issue. Most often it comes down to replacement, I haven't had too much success with rebuilding them in automobiles but most often it seems to help with tractors. Tractors appear to have more success with rebuilds and cleanings. hope this helps
Jul 13, 2014 | Sears Garden
Mtd yard machine 13ac762f729
check belt an if thats not it the drive out in the transmission
Jun 26, 2014 | Garden
Will snowblower attachment 190-832 fit a 2006 yard machine lawn tractor
Most of the Yard Machine lawn tractors have a welded tube front axle and they are not strong enough to handle the weight of a snow thrower.
The snow thrower is generic but you will need the correct mounting brackets and center frame for your tractor. Go to the agrifab website, call the help number and ask them if they have a mounting kit for your tractor. You will need the model number off the nameplate on your tractor frame for them to help you.
Nov 01, 2013 | Agri-Fab Agri - Fab Snow Blower - 42"
I have a mighty lite 26 trimmer. It has a runxing carb. Where can I get a rebuild ket for it????
You can get a rebuild kit from PartsBuggy.com. Just go to their cross-referencing page and enter the model # from your carburetor (it should be stamped into the body of the carburetor), NOT the trimmer model #, and you'll be given all the available kits for it.
Sep 13, 2011 | Homelite Mighty Lite Lawn Trimmer
My toro 51970a trimmer has been leaking gas and flooding for the past few weeks, but I could start it. Today, it is gushing gas from the back when I pull the starter string. How do i fix this?
The carburetor needs to be removed and inspected. The malfunctions possibly indicate the need for a repair kit. I've been unable to locate your exact model, but if it has the 2-Stroke engine (gas/oil mix), then you will at the very least..need a gasket and diaghragm kit installed per inspection. There is the possibility that the carburetor needs a complete rebuild and would require the complete rebuild kit. Remove the gas lines (after draining gas). Remove the carb and inspect the screws and tightness of the screws in the 2 end covers. Are the screws tight? If not tighten them up and reinstall, trying to restart the machine. Post back if needed.
Oct 26, 2010 | Toro& Electric String Trimmer
I have a yard machine 5.75hp self-propelled mower won't start
Sounds like you will need to clean your carburetor.
Sometimes you can get by with priming it a few times, and letting it run a few times like that and it will flush the gunk out of the jets,but most of the time you will need to rebuild the carburetor.
If the mower/weedeater is over a couple years old, then I also recommend that you buy and install a new carburetor repair kit,because the diaphragm will get hard and that will cause it to be hard to crank.
When you clean your carburetor and remove the jet screws, You will first seat the jet screws and count the number of turns it takes to seat the jets from their original position.
That way when you go to put the jets back in, you know how many turns they were in/out.
Please do not forget to rate me, Thanks
Good Luck, I hope this helped
Jun 01, 2010 | Mtd 22" Yard Machine Push Mower
Carburation Getting gas to the carburator but will not stay running without choke on
If the mower is over a couple years old, then I also recommend that you buy and install a new carburetor repair kit,because the diaphragm will get hard and that will cause it to be hard to crank.
May 31, 2010 | Cub Cadet Street Sign- tractor lawn riding...
Garden Logo
242 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
