Question about Acer AL1713 17" LCD Monitor
Open monitor acer al 1713 - Acer AL1713 17" LCD Monitor
3 Suggested Answers
  • 23 Answers
SOURCE: Monitor Acer Al 1914, no signal
Check your connections to the PC. Make sure that they are nice and secure. If there is a resolution problem setting it should display the boot process and then go blank after starting the operating system.
Posted on Oct 28, 2009
budmrtn
  • 11361 Answers
SOURCE: I have an Acer AL 1914 Monitor. Green light
Check power supply section for bad caps first.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed ACER monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Posted on May 26, 2010
Hi! i got a acer al 1917 screen home from work, it seems fine when i start it and the acer startup screen comes up on display. but there it ends, when i plug it in, my cpu reacts on there is a screen...
Use a flashlight and shine on your screen. Look carefully is you still see the image on the screen. If you do, this is an indication that the monitor is still working, but the backlight has failed. A common solution with backlight-failures is to open the monitor, and look if you see any "swollen" capacitors (http://en.wikipedia.org/wiki/Capacitor_plague). If you see one you should replace it. Only open your monitor if you know what you're doing and have basic knowledge of electronics and soldering.
Mar 31, 2011 | Acer AL1917 LCD Monitor
My acer al 1711 monitor goes off after three seconds of applying new settings with resolution chgs or refresh rate the monitor display is blank but the light is green.
my acer al 1711 monitor goes off after three seconds of applying new settings with resolution chgs or refresh rate the monitor display is blank but the light is green.
Nov 27, 2010 | Acer AL1711 17" LCD Monitor
May 26, 2010 | Acer AL1914 19" LCD Monitor
I have a AL 1716 monitor and the on/off button is
More likely to be bad caps with bulginh tops in the power supply, common problems, see some example of failed monitors here: http://s807.photobucket.com/home/budm/allalbums
Jan 06, 2010 | Acer AL1716B 17" LCD Monitor
Oct 28, 2009 | Acer AL1914 19" LCD Monitor
Acer AL 1713
Capacitors C6 and C22 usually are the problem on this model. They are 220uf at 25volts. you may also notice that resistor labeled R1 may be discolored or a little "toasty" so I generally replace it while i have it apart. It's a 10ohm 1/4 watt resistor. I hope this helps.
Jul 25, 2009 | Acer AL1713 17" LCD Monitor
AL 1916 s
when you open your pc now,do you still hear a click sounds like you hear before ,when your computer has no problem yet? now there is no sounds .do the ff..
1.try to press the numlock key and observe it ,if the indicator LED lite on and off,the problem of your computer is your video card,
2.if you can't hear anything, when you open your unit and the indicator of your monitor goes the color orange,pls..check your memory .clean the memory and the memory slots using the contact cleaner .before you replace a new memory.
3. and try to use a another monitor,maybe your monitor has the problem
Mar 31, 2008 | Gateway FPD2275W LCD Monitor
ACER AL 1912 Colors bad screen shakes
your asking which part you want to replace. try first to check all the connections.
Jan 02, 2008 | Sceptre X20G-Naga II 20.1" Flat Panel LCD...
Acer AL1713 17" LCD Monitor Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
