Question about Maytag MTB1504ARS Top Freezer Refrigerator
My maytag is hold water at the bottom i have to clean it twice a week or it runs out on the floor. The water drips from the panel where the light is
  • Maytag Master
  • 4,654 Answers
I am pretty sure you are having a defrost drain blockage problem. Most defrost every eight hours and over a period of time the drain line that comes down from freezer into a cup like object top middle and back of the fresh food section. If blocked by gunk or ice you will see trails of liquid leaking down the rear wall of fresh food compartment until it reaches the crisper drawers.This is not always the same with every model as you may see frozen ice flowing down ther rear wall of freezers on side by sides. Here is an example Click here=> Whirlpool Leak Photo taken by TechnicianBrian He has been around a good bit and deserves credit for his contributions. Here is another way to make this look more si mple in clip below. TechnicianBrian.com And in this photo are several parts listed in photo group #1 were it is most likely running down the wall=> MagicChef CTB1921AR fresh food section. If you still have questions please ask and rate me if I was able to explain this well enough. Every refrigerator is made different so these are examples only. The key is to find if ice or just gunk has blocked you defrost drain. Unplug and then remove the rear panel in back of freezer. We need to see if the water is overflowing the condensate drain tray or if the blockage is in the turn the drain leads down back of your refrigerator. Much more on this page=> Leaking Refrigerators! This is a common tip so I will be placing this post and add as we go new ideas listed in Sea Breeze Tips Section. If you run into any problems along the way of repair please let me know, Thanks, Sea Breeze
Posted on Dec 09, 2012
aborcass
  • 2651 Answers
SOURCE: Bottom of freezer has water dripping into it
sounds like you have a clogged defrost drain tube. removing back panel of freezer will give you acess to drain trough, melt away the ice with a hair dryer, youll find a drain hole under there somwhere,pouring boiling water down the drain will clear it pretty quickly( i use a steam machine purchased from the infomercials works awesome, after you clear it and all water drain down tube wrap a piece of solid copper wirearound the heater( black calrod heater right above the drain trough) and stick it in the whole maybe an inch or so. now everythime the heater comes on to defrost it will prevent the hole from freezing over
Posted on Mar 04, 2008
22yooper
  • 828 Answers
SOURCE: maytag side by side multi problems
1. Ice maker is not cold enough to start the ice making process.
3. having to take off the back panel is an indication of a problem in the defrost system. Call to have a service tech check this out.
Posted on May 31, 2008
SOURCE: Maytag MSD2454 SIDE X SIDE
Hi I have had this also happen,I need have a repair man come in to fix this and was told it will NOT happen again.Surprise!! It has happened again.But I was told that thee is a plug in the freezer side that get frozened up so this time I had to take everything out of the freezer,the bottom rack,then un-screw the back panel,in the bottom there is a small hole and this is were it is freezes up.Why?? I still do not know,but once again I have a call into the repair man again.But this time I did notice were the coil sits next to the freezer wall,it has melted,as if a fire had been there,So No I am not a happy camper myself.But good luck with yours.
Posted on Jun 24, 2008
We had a similar problem. It ended up being a frozen pea that fell down into the defrost drain and was blocking the water from draining out each time the freezer defrosted.
Posted on Aug 23, 2008
Sea Breeze
  • 4654 Answers
SOURCE: water drip at base of freezer door at bottom!
Have you had a chance to locate the location the water inside freezer? There are many reasons for this to happen I just can not say it would be a defrost condensate drain blockage. Most times it is. Every 8 to 10 hours your freezer defrost and the water is surposed to follow a pipe or drain through the refrigerator to a pan below refrigerator where the warm air from condenser evaporates the water back to the air inside your home. That drain line sometimes slowly becomes blocked and then the drain hole becomes clogged with ice. Once that happens the drain needs to be cleared. I will try to help you solve this so for now I need you to see if water looks as if it came from rear of freezer. Placing photos on Flickr would be great! So tell me where you see it and yes we may need to pull a few things out. This is nothing a few towels, hair dryer hot water and Clorox and a wet vacuum cannot handle. Sea Breeze
Posted on Mar 21, 2010
Why is there a layer of ice on the floor of the bottom freezer of my refrigerator?
The water most likely is coming from a defrost drain blockage. Unplug and remove the rear panel inside the back wall of the freezer. See panel location #4 in the photo=> HERE
You will need to get that panel out of the way to see and clean out the defrost drain.
Click Here=>Leaking Refrigerators
I am here should have questions, Thanks John Tripp Appliance 911
Jul 23, 2014 | Maytag 22 cu. ft. Bottom Freezer...
Maytag mbf2258Wew1 bottom freezer has ice on the bottom and leaking. Trying to find the drip pan and drain to clean out.
The drain in the freezer behind back lower panel
needs opening. You can see it at the bottom of the back panel
underneath the evaporator coils. (The cold coils)
Run Hot water in the drain until it clears or use a hairdryer.
When the defrost melts the water it goes down the drain
If the drain is clogged with Ice or ? The defrost water
overflows into the ref. or freezer or on floor
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
If you need more help GO HERE:
http://www.applianceaid.com/procedures.html
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME IF THIS WAS HELPFUL
Sep 24, 2011 | Maytag Refrigerators
Hi I have an old Hotpoint refrigerator, Model CTX14CYSCRWH. For the past month, the water drips from the freezer inside the refrigerator(just next to the bulb) I have cleaned the freezer twice but the...
Leo Ponder
imufo2
Sep 20, 2011 | GE Refrigerators
Was cleaning refr, and freezer (french door bottom freezer) pulled out water on floor is there a drip pan?
Leo Ponder
imufo2
Sep 05, 2011 | Maytag Refrigerators
Dishlex Global 300 Dishwasher - ECO Light flashing - Manual indicates incorrect fill level - Manual suggests hold ECO button for 10 Seconds. No success. Have tried pressing and holding buttons - no...
eco light sometimes indicates that water has got into the bottom panel of the machine. A float switch is underneath to protect the machine ( and your kitchen floor from being flooded. ( Either from overfilling or a leak) If you tilt the machine backwards see if any water runs out. If the machine restarts , then you will have sourced the problem. Should the flashing start again later, you may have a water leak underneath. Also check the lower door gasket to make sure its clean. If the gasket is dirty, sometimes water builds up behind the gasket and drips over the front of the tub into the bottom panel underneath causing this symptom. When cleaning the gasket, be very carefull!! The edges of the door at the bottom are razor sharp..
Jul 26, 2011 | Dishwashers
My Maytag side by side refrigerator has water coming out of it. From time to time, you can see water on the floor which has come from both the bottom right and left side of the refrigerator. I...
We have the same issue on our Maytag Side by Side - MSD2734GE. Empty the freezer. At the back of the freezer are two panels in the back. It is only necessary to remove 3 screws. The first 2 screws hold on the very bottom panel. Remove the back panels and look at the drain located at the bottom. You will notice a thin piece of metal covering a drain hole. Remove the screw holding the metal in place. Then remove the ice build up around the drain hole.
Sep 01, 2010 | Maytag MSD2734GE Side by Side Refrigerator
Some water dripping on the bottom and freezes onthe bottom of the freezer and sometimes theres water on the floor.
The freezer drain is cloged.Drain is in the bottom of the freezer floor in the back you may have to remove back panel. Run wire or somthing down drain tube to clear clog.
May 16, 2010 | Freezers
Maytag fridge water dripping from inside freezer side
This sounds like the evaporator drain may be clogged either in the freexer compartment or at the outlet to the drain pan under the unit. Every defrost cycle the defrost element makes water by melting the ice on the evaporator coils. If the drain is clogged there is no other place for the ice to go. Many times the drain may just have ice buildup in the evaporator drain funnel that can be corrected with a manual defrosting.
To do this manual defrosting all you do is first unplug the unit then remove everything from the freezer compartment. After that place a fan blowing into the freezer section for a little over 2 hours. Please NOTE this will make more of that pesky water mess so be ready to tend to the mess as it presents itself.
After the 2 hour fan session plug the unit back in and reload the freezer compartment with previous content. Monitor for the possibility of the water manifeting itself again.
In addidtion to the above there is a drain pan catch basin in the bottom of the unit near the compressor. They are usually white plastic on Maytag units and not to rugged. Make sure that the drain pan is not loaded with debris. There is about a 1/2 inch diameter opaque plastic line that drains into the catch basin. That is the Evaporator darin tube. Ensure the very end of the tube does not have caked up debris in the very end of the tube. Sometimes this tube cakes up and then the debris dries hard inside the tube near the end. Make sure the tube is free of foreign objects and clean.
After all of the above / cleaning and clearing / manual defrosting it is still making water then most likely the lower panel under the defrosting element / evaporator may have become disconnected allowing defrost cycle water from the melted ice into the freezer compartment vs exit via the drain. To fix the disconnected power metal panel problem the rear freezer panel would have to removed to re-attach / repair the metal panel that guides the water into the evaporator drain.
Thanks for using FixYa.
Kelly
Mar 26, 2010 | Maytag 25.6 cu. ft. Wide-By-Side...
Maytag fridge has constant running water sound
you hear a constant running water sound? look in your manual under "normal operating sounds". it explains all of the sounds. it sounds like you're hearing the refrigerant going thru your evap. coil located behind the rear frzr panel. you unit goes into the defrost cycle roughly every 8hrs and water drip down into the condensate pan un the refrig.
Jul 16, 2009 | Maytag MSD2756GES Side by Side...
Icemaker not working
I have pooling inside the freezer, which freezes and then leaks on the floor. Does anyone have the 7 year wrap around warrantly? I bought one with my frig in 2002 and have misplaced it. I wonder what is covered on this frig full of problems.
Jul 25, 2007 | Maytag MSD2756G Side by Side Refrigerator
Open Questions:
Maytag MTB1504ARS Top Freezer Refrigerator Logo
77 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
