Question about Maytag Refrigerators
Hi the refrigerator is running water at the bottom where the viggies are ,the water comes from the panel where the light is how can i stop this from happening
    Top Expert:
  • Maytag Master
  • 9,472 Answers
Check to see if the drain line in the freezer is blocked.
Posted on Dec 09, 2012
  • 51 Answers
SOURCE: refrigerator
If the freezer is on top then empty out the freezer and remove the bottom and back liner of the freezer compartment usually phillips screws. In the back you will see the freezer coils along with a defrost element. Below these two items u will see a drip tray that collects water from the coils on defrost cycle, in the center of the pan will be a drain hole that connects to a hose that leads to a pan under the refrigerator.Normally the water is collected there and evaporated. The hole in the tray in the freezer is clogged. Thaw it and clean it until you can pour water in it and it goes to the pan down below. please rate me
the thumping noise is normal
Posted on Jan 13, 2009
Sea Breeze
  • 4654 Answers
SOURCE: water collects in bottom of refrigerator
This is something you will be able to solve, the like below will take you to a detailed instructions and photos of what to do. Let me know if you need more help, Thanks Sea Breeze
http://appliancejunk.com/forums/index.php?topic=22.0
Posted on May 23, 2009
heatman101
  • 43501 Answers
SOURCE: Refrigerator not cooling
As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
heatman101
Posted on Apr 11, 2010
  • 3 Answers
SOURCE: Hi. I have a Samsung RS253BAWW refrigerator. I
I have Samsung model RS253BAWW, getting small water leak under left front of unit. Removed fron grill and it's not apparent where the water is coming from.
Any help appreciated.
Posted on Sep 04, 2010
caroldon
  • 17129 Answers
SOURCE: Water leak on floor of
It is so common that the drain leaks in many ways and is the most problematic fault in a washing machine. In all occasions it is important that your observation is most important and so is vital to the identification /rectification and solution. If you have noticed that water has leaked then as the drain hose pump/valve and fittings are located on the underside of the machine it is important that you look for possible leaks here. In some cases the drain hose would be clogged at the drain end to outlet of the house and so there will be back flushing resulting in overflow to the outside. Also the drain pump/valve can be clogged or the drain hose clamps can be loose on the grip which can all cause the leak to occurs. Removing and Cleaning the drain pump/valve, tightening of the hose is also very important. Also water can leak if there is gaps on the front door gaskets and must be checked but this will happen only during the cycle and not on the drain cycle end.
Check for tips on the link below to identify parts and removal:
http://www.espares.co.uk/advice/washing-machines/a/7
Posted on Aug 22, 2011
Scotsman cme456as-1a
Pull and clean water level switch. Check to see if water solenoid is getting power to it if so check to make sure you are getting water through it. FIRST check water filter make sure its not stopped up. if that is clear check make sure water line is not kinked. If your unit is not getting water then the unit will run high pressure and lock out on refrigeration.
Jun 14, 2012 | Scotsman Cooled Modular Contour Cuber Air...
Water leaking onto floor coming from under refrigerator
Their are a couple things causing that leak
1) the water valve(s) for the icemaker/door dispenser are leaking. Pull the refrif. out,remove service panel from the rear and inspect the valve(s) for leakage. Sometimes their is just one valve on certain models their is two.
2) the drain for the auto. defrost cycle in the bottom of the freezer back wall is blocked so the defrost water is running out of the freezer door at the bottom
Good luck,i hope i have able to help you stop the leak,
Aug 20, 2011 | Amana Side-By-Side Refrigerator 26 cu. ft....
GE TBF17PC top freezer water under vegetable
The drain hole is inside the freezer. you have to take the back panel off to get to it and thaw/clean it out. if this drain stops up it will cause water to run down the back wall of the refrigerator down to the bottom. you can pull the refrigerator out from the wall and see the plastic tube coming from the back of the freezer.
Jul 11, 2010 | GE Refrigerators
Hi GE top freezer fridge - 5 years old( no ice
Well for one thing that unit was manufactured 10 years ago. But it sounds like the defrost drain is clogged and the water is running down the inside of the unit. The evaporator (not condenser) is on the bottom of the freezer compartment. The bottom panel of the freezer comes out. They are a bit of a pain to do, but can be done.
Jan 03, 2010 | GE GTS22KBP Top Freezer Refrigerator
GE GSS20IEPHWW side-by-side refrigerator stopped cooling
First off, when the fans are both running, the compressor should also be running. Sometimes, because they run quietly, it is difficult to tell if they are running. Touch the compressor to feel for heat and / or vibration to confirm running. (if the compressor gets too hot, the overload will stop it until the compressor cools down. That could happen with too low or too high voltage, even with the cooling fan running) You did not say how long you let the unit defrost. To properly defrost it, you should empty out the freezer side, remove the shelves, and take the metal cover off the back inside wall of the freezer. Then, use a hair dryer to melt all the frost off. If the coils were blocked with frost, you probably have a burnt out defrost heater (located at the bottom of the cooling coils) when replacing the defrost heater, use part number WR51X10101 and follow directions, as it may have a different configuration than the original heater. A frost blocked evaporator (coils inside the freezer) will stop normal air circulation inside the refrigerator. Cold air will then be able to flow backward, into the bottom of the refrigerator side through the normal return air duct located at the bottom of the refrig / freezer divider. This cold air can freeze the water line or water reservoir located there. There for, solving your defrost issue most likely will also solve your water line freeze issue.
Nov 21, 2009 | Refrigerators
REFRIGERATOR MOTOR CONTINUES TO RUN AND WATER IS LEAKING.
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
u
Mar 22, 2009 | Whirlpool ET8CHEXSQ Dryer
Water freezing up in the bottom of the freezer
your defrost drain is stopped up then when it defrosts in steed og going down the drain its running in the freezer floor remove the back panel in the bottom of the freezer and clear the drain hole under the evaporator
Mar 12, 2009 | Kenmore 53642 / 53644 Side by Side...
Ice and water dispenser not working but light on constantly
We had the same problem. When we removed the ice receptical the mechanism that turned the ice make was broken and it stopped the ice from being dispensed. I hope it is that simple for you!
Aug 15, 2008 | Maytag 25.6 cu. ft. Wide-By-Side...
Kenmore bottom freezer refrigerator
This sounds like the Maytag bottom mount that has a High Voltage Control Board problem. Does this have the freezer/fridge temp. display/controls on the left hand fridge door? Whats the model number and on the manufacture tag does it something on it like Code:0304 maybe? Let me know I may have an answer I do work on these for a living.
Jan 26, 2008 | Kenmore 73503 Stainless Steel Bottom...
Refrigerators Logo
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
isaac johny
isaac johny
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
