Question about Dimplex DF3003 Electric MidSize Heater
Dimplex fireplace E71416 running noisy
Runs loud
3 Suggested Answers
  • 4736 Answers
SOURCE: my dimplex fireplace is too
I have been dealing with electric fireplace/heaters for several years, now. And for the life of me, I can not think of a thing that would cause a noise like a 747 jet plane. Could you be a little more specific as to which function of the fireplace cause this noise?
Look forward to hearing from you.
Posted on Apr 05, 2011
  • 4736 Answers
SOURCE: How do you disassemble the
Good information. Thanks for sharing it.
Posted on Aug 23, 2011
We have a BF8000ST mod C electric insert fireplace. The fan is shutting off once the unit has run for a while. Right now, we are using the fireplace to heat our 5th wheel while we are in this transition...
If you have a Dimplex Fireplace Model # bf 8000st Mod C I can tell this. 1-Yes there is a EC (emergency cutoff) switch when this unit gets too hot. 2-There is a thermostat.These units are usually placed within a wall cavity. These cavities are closed and will build up heat very fast because - there is no vent for cool air intake. RESOLVE: Go to Home supply and buy one or two 2x12 inch register vents. Custom place this new vent(s) in the cavity wall where it may have excess to cooler air from the room.
I completed one vent yesterday and the fireplace runs continually now. I plan to add the second one for balance in the next couple of days. You will be as amazed as I was. IT WORKS NOW...
Oct 05, 2013 | Dimplex Heating & Cooling
Flame effect electric fire loud clicking noise
You need a new synchronous motor. This is the small motor which turns the flame effect rod. They are notorious for becoming noisy.
Nov 06, 2012 | ACE Dimplex (r) Compact Electric Fireplace...
Dimplex optiflame remote not working
The DFI2310 uses a simple plug-in remote.
You can either order one from Dimplex, or use an aftermarket solution such as this one from Skytech: Skytech 1315G Electric Fireplace Remote.
Oct 08, 2012 | Dimplex DFI2310 23 Inch Deluxe Electric...
My dimplex fireplace is too noisy. It's been that way from day one. We should have sent it back, I guess. Everything else is great about it but it sounds like a 747 jet!
Apr 05, 2011 | Dimplex DGWH4031 Heater
My Dimplex model #6901470100 (purchased new in 2007) just stopped working. It was on then just turned off by itself. Both lightbulbs are OK. What would cause this?
It probably overheated and the overheat module shut the heater down. It may reset itself once it cools down. Or the heating element has burned out. There are a host of issues with these electric fireplaces (not just Dimplex). They are sold as a decorative, supplemental heat source, but in fact, if you get more than a years use out of it without a problem, you're probably the exception. The heaters just aren't meant to run for a long period of time. It's like turning on a blow drier and letting it run for an hour. Nine times out of ten the blower driver will overheat and burn out.
I really wish I had better news for you (I answer this type of question at least 5 to 6 times a week), but I don't.
The only good news would be, if it's still under warranty (one year), have your Proof of Purchase and contact Dimplex USA. Technical Service: 1- 888-346-7539. Customer Service: 800-668-6663
Feb 23, 2011 | ACE Dimplex (r) Compact Electric Fireplace...
Need to replace noisy fan motor on Dimplex 6901470100 Not sure how to gett access to blower. Thanks
If you no longer have your Owners Manual go to the Dimplex home page and click on the Help tab. You should be able to download the Owners Manual for your model fireplace there in a pdf format. Also look for a Trouble Shooting tab.
Jan 31, 2011 | ACE Dimplex (r) Compact Electric Fireplace...
Heater in fireplace keeps tripping and has to be unplugged to reset (new unit)
heater is drawing to many amps for the heater to run correctly check the circuit it is on and possibly move to a different location on a circuit that has more amps from panel box.
Dec 10, 2009 | ACE Dimplex (r) Compact Electric Fireplace...
Remote control working with fireplace.
try www.dimplex.com go to customer sevices they should be able put you on to a local dealer in your area
hope this is of some help
Dec 13, 2008 | Dimplex DS5603 Heater
Dimplex DF3003 Electric MidSize Heater Logo
102 people viewed this question
Top Dimplex Heating & Cooling Experts
Paul Carew
ashburton
Kory Ronning
Are you a Dimplex Heating and Cooling Expert? Answer questions, earn points and help others
