Question about Microsoft Xbox 360 Console
From reading to open tray
Ok when ever i put any game (even when it's cleaned) my xbox will go back to "open tray" and then I got to start the thing all over again, and it's doing it with all my games! and I don't want to buy a new xbox 360 please help!!!!
  • mikebutler94 Jan 13, 2009
    my xbox, i opened it up down to the disc drive, only works when i have my finger on the disc. and only xbox original games work and if the game dosnt work it says i need to insert the disc in to an xbox 360 console. So ive tried cleaning the laser and everything, i want to know if there are anyother possible ways to fix this before i buy a new dvd drive.
You have one of two options you can take the drive apart and replace the laser with a new one because it's not reading the disc correctly anymore this is the easiest option but if you are electrically inclined like one of my friends using a voltmeter you can set the laser potientiometer higher but your best bet is to replace the laser flat out if its under warranty let microsoft do it if not you can go to llamma.com i believe it is and there are tons of tutorials on how to change the laser as well as determine which drive so you can order the correct replacement and shop around for replacements divineo has them for as low as 15 buccks sometimes but when stock is low they casn be as high as 30 console shop also carries them too from time to time
Posted on Jan 13, 2009
Thats no fun, ive come across this problem and was able to fix it by replaceing the dvd- romdrive which is the thing you put your games inside. its quite easy to switch out, the problem is finding one. I scrimmaged one off an old useless regular xbox....good luck. if ud like the steps on how to take out the dvd -rom drive just holla and ill give u the process step by step.
My xbox 360 doesnt want to read the game. when i put in gears of war, it tells me to open tray. i open it then close it and again it tells me to open tray. ive done the clean cd and still the same thing....
Unfortunately this is a common issue with the xbox. If you have tried all the steps that are provided on the xbox support website, it may be time to call xbox support and get your xbox repaired. If it is out of warranty, I'd honestly just get a new one cause the repairs run about $120 out of warranty.
Aug 17, 2011 | Microsoft Xbox 360 Console
When i put a game in my xbox 360 it says reading then open tray
I found a solution that works for me after a long period of time with this problem.
Get an air spray canister (just compressed air), open your Xbox's game tray, take the disc out, then spray the air along the tray, moving side to side inside the Xbox. You may want to spray into the vents, too, just to be sure.
This worked for me, and it was the only thing that worked for me. I had already tried hitting the console with the controller (gently), and doing the stuff Microsoft recommends etc.
If that doesn't work, you could try gently knocking the top of the Xbox with your conroller, when you put the disc in, as I've heard that works for some people.
Another thing that works for some people is taking the disc out, closing the tray, then when it goes to Open Tray, open the tray, put the disc back in and then closing the tray again.
Jun 19, 2010 | Microsoft Xbox 360 Console
Not playing game just say open tray
Hi, this is a pretty common problem for the xbox 360's. It is caused from the laser either becoming dirty or the laser is starting to burn out. The first thing I would try to do is open the disc tray and then unplug your 360. Then try taking some canned air or an air compressor and blow it into the DVD drive to clean off any debris from the laser. Plug it back in and try to load a disc. If you still get the open tray error, then your laser is starting to burn out and is in need of replacement. The xbox 360 uses the laser to determine whether the tray is open or closed, unlike the PS2 or PS3 which relies on switch. So, if it becomes dirty or burned out it can't read if the tray is open or closed.
Sep 02, 2009 | Microsoft Xbox 360 Console
My 360 will not read my disc even tho they are clean
The optical drive on the xbox wears over time. Call 1-800-4MYXBOX and get a repair scheduled.
Aug 03, 2009 | Microsoft Xbox 360 Console
My xbox will not read any of my games
try playing a different game *******
Jul 29, 2009 | Microsoft Xbox 360 Console
Xbox Will Not Read Any Thing I Put in it
i had the same problem with my xbox, i actually picked it up free because of that, when i got it home i tried cleaning the tray with the cd with little brushes on the bottom and that didnt do any good. i had to manually open the xbox 360 and then open the tray aswell, you can see on youtube how to open a 360 properly, its actually very easy, and then you actually open the tray and clean the laser eye with a q-tip and rubbing alcohol, its a few t9 screws to remove the xbox from the case and then 4 small star screws to open the tray and clean it, put it back together and it will run asgood as the day you bought it
if you need more details repost on this with your questions and i will answer them all
--that goes for anybody who needs a hand with a 360, i brought mine back from the 3 red rings of death 4 times without having to pay a hefty microsoft repair bill, just 6.00 for a few things that i needed to redo a few chips on the motherboard, if you need help i will do my best to help you--
(wish i had someone to help me when me and my wife figured this out):D
Tyler
Jul 06, 2009 | Microsoft Xbox 360 Console
My xbox 360 doesn't play my games
it could be that u got **** like food in your x box360 open it up and clean it out put it back to gether and try it if this dose not work tell me at alexswierenga@yahoo.com ty
May 29, 2009 | Microsoft Xbox 360 Console
When i put the game in it says reading then just says open tray and wont read. it used to read after a few try but now it wont work no matter how many trys
Most likely it is your laser lense is dirty. Crack the case get in to the DVD drive open it. While in there give it a general cleaning then clean the laser lense with glass cleaner and a q-tip. Three other things to check. There are three motors in there one slides the tray in and out when you hit the eject button (small hole lower left of metal box under drive) another moves the laser when the tray moves back in you should see the laser move slightly and the lense bob up and down and light up, third is the spinner motor put and disc in the tray and close the tray the disc should spin up if it doesn't then the motor is bad. If all these things have work ok put it back together and test it out.
Mar 23, 2009 | Microsoft Xbox 360 Console
X Box 360 Won't even attempt to read disc
when i put a game in the xbox 360 it keeps on saying clean the disk whith a soft cloth
Aug 05, 2008 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
53 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
