Beeping, probably not charging but brand new.
SOURCE: Motorola MD760 dies after 5 minutes of use-- from being charged for days on base
this is a battery prob replacing battery will solve this prob hope this solves your prob make sure the battery connectors are conected propery securely first before replacing if ok then replace batt and prob should be solved check then conectors are clean where the phone sits on base and check phone sit on base properly if it does then it is def the batt replace.
SOURCE: BT Studio 3100 handset 1.
Help
My Bt Studio 3100 cordless telephone ( 2 Pack ). I have carried out the setting up procedures as per instructions.
Handset batteries are fully charged, but I am not getting the dialling tone.
SOURCE: My Beocom 6000 table base unit no longer charges
If your base has a charge indicator on it and it indicates that the handset is charging when the handset is in the cradle, I would say you need a new battery. RadioShack sells a replacement battery for $22.00 at the following link
http://www.radioshack.com/product/index.jsp?productId=2815547&CAWELAID=107599274
If the charge indicator doesn't come on it is unlikely that it is the battery. You may be able to get the phone repaired by the manufacturer but it may be better and more practical to get a new phone.
SOURCE: base unit on bt synergy 3505 keeps beeping and
If the handset displays 'Searching', 'Base' or 'Range out' on the screen, this indicates that the handset has lost its link with the base.
The following procedure should be followed to help resolve the problem:
SOURCE: Philips CD245 phone not working.
the same problem after it worked 3 years. any solution arround?
