Question about Garden
WHAT IS THE IDEAL FUEL/OIL MIXTURE FOR A YAMAHA MT110 WHEN RUNNING AT ALTITUDE (1600 Metres above sea level)?
Need to know fuel mix - petrol/oil for optimum running at 1600 metres above sea level
5 Suggested Answers
  • 3567 Answers
SOURCE: Correct oil fuel ratio,1980 Pe 400
32 to 1 gas and oil > Two Stroke Engine Oil ( not Motor oil ). This equals 4ounces oil per gallon of gas.
Use premium unleaded gas. No Ethanol gas.
10w40 motor oil for the gearbox. Stick with the major brands; Pennzoil, Quaker State, Mobil or Shell.
Please take a moment to rate this solution. Thanks Beetle100! :)
Posted on May 03, 2009
steve_lima
  • 181 Answers
SOURCE: I have a Brigs&Straton 6.5 Quantum lawnmower will not stay running. I can keep it running by restricting the amount of air entering the carb with my finger (choking it) The mower will start if it
the problem is in your carb.,at the bottem of the carb. there is a bolt that threads in to the carb.pinch off the fuel line so that no fuel comes out after the fuel bowl is off the mower.now look into the bolt that you took off.there should be a hole oppisit the head of the bolt.there are also two holes that go through the sides.these holes are the fuel intake to the carb,the hole in the center is the fuel nozzle.most likely you have dirt blocking this hole and not letting the motor get enough fuel to run.thake some carb cleaner and spray it in the hole.take an air hose then blow the nozzle out.while you have the screw out take the bowl off and check to see if there is any water or dirt in the bowl.after cleaning.reinstall the bowl and start mower again.should be running ok now.if not let me know and i'll guide you through another fix.let me know if this helped or not................
Posted on Jun 02, 2009
MNfisherman
  • 11896 Answers
SOURCE: nannie what can be wrong with my power devil
Check air filter, check screen in bottom of fuel tank,
New spark plug and also check the spark.
If there is a weak spark, the coil may need to be replaced.
If you have good spark, clean air filter, and clean fuel tank screen, then the carberator will need to be pulled of and cleaned out with solvent
Posted on Jun 23, 2009
carlsbiz
  • 1124 Answers
SOURCE: 185 cc lawnmower Briggs and Stratton was operated with mixed oil,
Was it blowing out blue-ish smoke before ??
Take the spark plug out and clean it good with gas & wire brush..
Hope this helps !!
rate me good ;o)
Posted on Jul 14, 2009
What is the petrol to oil ratio for this engine
http://www.csgnetwork.com/oilfuelcalc.html
In the Mix
All STIHL gasoline-powered equipment uses a 50:1 gasoline/oil mixture. The chart below can help you figure out the correct measurements to use. For high-performance fuel that requires no mixing, choose STIHL MotoMix® premixed fuel.
Jul 20, 2015 | Garden
Oil and fuel blowing out through top of motor in yamaha golf cart 4 stroke engine
Engine got to much oil in it? Worn engine allowing fuel down into engine diluting the oil and raising the oil level? Blocked engine breather, pressurising the crankcase. Oil change and clean the breather. Worth a try
Jan 10, 2013 | Yamaha G1 G-1 2-cycle Gas Golf Cart Tune...
Need to know fuel mix for mcCulloch gladiator 550 petrol hedge trimmer
I don't know the age of this machine, but more and more of the newer units are using a 50:1 mix to satisfy the newest EPA emissions regulations. I suggest using a synthetic or synthetic blend of 2 stroke oil. ....the big box stores sell the oil...Echo one of the best. I would use synthetic and mix it 40:1. Here is a fuel mix chart to show you how many ounces of oil in a gallon of gas that is. If you make a 1/2 gallon batch of fuel mix, just use half of the listed oil amount for the mix.
http://support.mtdproducts.com/app/answers/detail/a_id/347/~/two-cycle-engine-fuel%3Aoil-mixture-chart
40:1 is 3.2 ounces of oil in a gallon of gas...or 1.6 ounces of oil in a half-gallon of gas
Jul 04, 2011 | McCulloch Garden
I just moved from Charleston, SC to Colorado and went from sea level to 6,200 Ft above sea level...do I need to make any adjustments for the higher altitude?
it its fuel injected it will have an atmospheric pressure sensor that compensates for altitude. if its carbs you may have to alter the height of the needle and slightly smaller main jets
Jan 04, 2011 | 2003 Yamaha V Star 1100 Classic
What is proper gas mixture?
fuel mix ratio is 50:1 using good quality 2 stroke oil
ie if you mix 20 mils of oil for every 1 litre of petrol that you mix
that is 50:1
or if you want a 5 litre mix put in 100 mils of oil into a clean petrol container 1st then put in 5 litres of fuel only and give good shake
cheers paul
Aug 13, 2010 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
I inherited a Rancher 50 20" chainsaw from my uncle only noone know the oil gas mixture.
using good quality 2 stroke oil use ratio 50:1
that is 20 mils of oil per 1 litre of petrol that you mix
put oil in can 1st then add petrol and give good shake
so if mixing 5 litres pour in 100 mils of 2 stroke oil and add 5 litres of fuel only
cheers hope it helps
Aug 07, 2010 | Husqvarna Garden
I need to know the ratio of a gas and oil mix for a 1999 yamaha outboard motor 90 horse power already broke in...
I'am amazed it doesn't have an oil premix that gives it auto oil mix.If it doesn't than the mixture is 50/1.That is fuel /oil ratio.e.g. 50 litres of fuel to 1 litre of oil.Hope this helps
Apr 17, 2010 | Boating
Confused a little
A 4 stroke motor does NOT have Oil in the Fuel. There is NO fuel mixture. Just use regular gas. The only place you need oil is in the sump, and regular 20/30 motor oil will be fine.This only needs to be replaced when low on dipstick in crankcase.
Mar 08, 2010 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
My yamaha yz 125 is dumping to much fuel and fouling out the plugs but i need to knoew how to adjust my carb its a 1997
There are only two adjustments to make on your carburetor; the idle speed, and the idle mixture adjustment. If the spark plug fouls frequently, first make sure you are using the correct spark plug. Your 1997 YZ125 uses an NGKB9EGV. Then be sure you are using the recommended two stroke oil, mixed to the proper ratio, in the fuel. Also make sure the air filter is not excessively soiled.
With all of the above confirmed and corrected, start the bike and run until the engine is up to normal temperature. Adjust the idle mixture screw to attain the fastest idle and best throttle response. Then adjust the idle speed.
If you are still fouling the spark plug, verify that the carburetor has the correct size jets by consulting your owner's manual. Keep in mind that if you are operating your bike at an altitude higher than about 6,000 feet above sea level, the stock jetting may be too rich. Down-size the main jet in small increments until satisfactory operation and the correct spark plug color is obtained.
Nov 02, 2009 | Yamaha YZ 125 Motorcycles
Garden Logo
130 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
