Question about Krups Dolce Gusto KP 1006 Espresso Machine & Coffee Maker
Kp 1006 Heat pump water but not shoot, water flows on the table
2 Suggested Answers
SOURCE: krups kp 2000 water leak
I had the same thing happen. It turned out that the rubber hose connecting the water reservoir to the heating element had disconnected, probably due to grinding vibration. I found a triangular screw driver to open the coffee maker up at MicroCenter: http://www.microcenter.com/single_product_results.phtml?product_id=0332974
After removing the bottom of the coffee maker, the repair took 1 minute and it is brewing coffee again like new!
Posted on Feb 02, 2011
Where to buy extension table for bernina 1006
It is an older model, so most likely you will find only used parts. eBay is a place to look, although I can't say I've seen many replacement parts for the 1006. Of course, perhaps the extension table fits more than one machine (although that's not very common with Bernina). You can also check out the acrylic tables (ie Sew Steady) available from several vendors online or even in some stores (you'll probably need to order what you need since they are made to your machine's specifications).
Sew Steady SST Portable Extension Table 11 5 to 32 Wide 15 to 24 Deep 1 4...
Apr 03, 2016 | Bernina Sewing Machines
I am using this pump to build a stream table, and need to vary the water flow without access to the pump. Will hooking it to a rheostat damage the pump?
yes --- it reduces the voltage to the motor which increase the current flow making it over heat
to vary water volume ( flow ) put a tap in the line and regulate the flow that way
This allows the motor to run and be cooled by the fan in the back of the motor
There may be a way to do what you want so talk to a electrical; motor re-builder shop and get ideas as to how to do it like using a sine wave cutter as is used on ceiling fans
Oct 21, 2015 | Pool & Spa
Low flow message on balboa 500z system
The low flow message on any Balboa means that you are having an issue with the flow of water through your heating unit. This can be caused by a few things.
  • Low water levels
  • Dirty filters
  • Something is impeding your water flow
Top up your water level and make sure it is where it needs to be, clean your filters or replace them, and check that nothing is impeding your water flow at the skimmer or water intakes.
Here is a link to water flow issues.
F2 Error Code Trouble Shooting
Dec 24, 2013 | Intex 2500 Gal Easy Set Swimming Pool...
Hine ran out of water while making coffee. Now it wont work.
Sounds like an overload fuse has blown (possibly) there are resettable fuses in some, not in others. Have you checked you element?
Apr 07, 2012 | Krups Dolce Gusto KP 1006 Espresso Machine...
2005 Buick rendezvous heater blowing cold and temperature gauge not working properly?
Faulty coolant temperature sensor and a faulty heater control valve.
Jan 14, 2012 | 2005 Buick Rendezvous
No cooling water shooting from the visual indicator port - less than 6 month old 115 short shaft motor purchased new from dealer
if you do not see water shooting out, there are a couple of things to check, open the case and remove the hose and check for debris --- the fitting itself could also be blocked, clear hose and fitting and re-install -- test --
if no water is flowing after that, then there could be a chance that the water pump impeller is bad, ( note: if water impeller is bad the motor will get hot and the over heat light will come on ' red ' ), turn off and replace the impeller.
c...
Dec 31, 2010 | Yamaha Boating
Overheating and no heat 94 cadillac concours
Heater Core, very possible - you may be able to bypass it simply. Moisture or fogging on the interior of the windows may indicate coolant is seeping in. Sounds like you have done almost everything else.. Heater cores generally **** to replace..
Dec 07, 2009 | 1994 Cadillac DeVille
I have a Honeywell House humidifier HE 225A-1006.
In order of probability:
1) (incorrect wiring) Make sure that humidistat is in SERIES wired with the furnace.
2) (shorted wires) Check that two wires to humidistat are not touching...use your glasses if you need them!
3) (bad humidistat) disconnect the humidistat and put an ohmmeter accoss the two terminals when it is turned on you should read 0 ohms, and when off it should read infinate ohms, if not pass both these tests, you need new humidistat.
That is it, there are no other possibilites!
Oct 12, 2009 | Honeywell HE220A1019 Whole House...
Digital read out....fault high ref pressure.
Verify circulating pump is on and that there are no water flow restrictions to the heat pump. Make sure all necessary valves are open or in the proper positions to allow proper water flow to the heat pump. Verify filter and skimmers are clean. Check for water level in the pool. This condition may also appear if the heat pump has not been operated for an extended period. To clear the condition, cycle the heat pump, on and off, up to 3 times. If this does not correct the problem, call for service.
Jul 25, 2009 | Jandy Ae2500t 115,000 Btu Heat Pump
Krups Dolce Gusto KP 1006 Espresso Machine & Coffee Maker Logo
129 people viewed this question
Top Krups Coffee Makers & Espresso Machines Experts
cyfred
Level 1 Expert
Ross Keen
Are you a Krups Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
