Blank screen Removed and inserted DIMM module, WLAN module, hard disk drive module and ODD module. Now when I turn on the screen is black/blank.
  • 7,627 Answers
I'm sure you removed the battery and unplugged before this. Why did you do all the things listed? what was the original problem?
Posted on Dec 10, 2012
Kidyubyub
  • 143 Answers
SOURCE: screen goes blank(not Black, but dark) after windows boots
Perhaps it is trying to power an external monitor. Try this: Once your computer boots up, hold down the "fn" key (usually bottom row of keyboard) and then hit the key that shows what looks to be a monitor on it. Usually on the Toshibas, its the F5 key. This key will always be in the F key row. Let me know if this helps.
Posted on May 14, 2008
  • 461 Answers
SOURCE: cant boot
If you are sure no one has tampered with it and entered a HDD password and it is not prompting for a password then it is most likely a HDD failure. It is possible the BIOS will still recognize the HDD. Try disconnecting and reconnecting the HDD if you can access it there should be screws on the bottom marked with a cylinder symbol.
Posted on Jan 25, 2009
rockitman187
  • 2559 Answers
SOURCE: windows vista wont start
Ok,Try safe mode with command prompt,If you can get to the command prompt
Type these in one at a time and press enter ( let each one completely finish before typing the next one.)
Bootsect.exe /NT60 c:
Bootrec.exe /FixMbr
Bootrec.exe /FixBoot
Bootrec.exe /ScanOs
Bootrec.exe /RebuildBcd
bcdedit.exe /import C:\Boot\BCDBackup
Posted on May 21, 2009
cabanagj43
  • 225 Answers
SOURCE: When turning on my laptop, screen is blank yet you
Immediately run the PSA test. Leave laptop off. Press and hold on the Fn key the press power button at the same time. Lest PSA test finish the quick test and determine if HDD is faulty.
If HDD is good no errors found then reinstalled the OS. If HDD is faulty then replace.
Posted on Oct 24, 2009
SOURCE: Acer 4520 Power up for 1 second and turns off
in acer4520 auto power off within 5 sec
Posted on Apr 06, 2011
RAM upgrade
(1) flip the Notebook/Laptop PC over - see Fig.1 below
(2) find the memory cover - it really easy to find in this photo.
Fig.1 Toshiba M35X bottom view - the memory cover is seen at center left and secured by a single screw.
(3) remove the (1) screw securing the memory cover.
Fig. 2 Toshiba M35X laptop shown with memory cover removed and HDD (Hard Disk Drive) removed, and with the HDD cover flipped up.
The RAM (SO-DIMM boards) are visible at center left.
The HDD cover is seen at the bottom of the photo.
(4) Using proper anti-static/static control techniques, clip alligator clip or your anti-static wrist strap to a frame ground of the laptop at an I/O connector or frame ground under the HDD cover.
(5) carefully remove (2) old 256 MB SO-DIMM DDR333 memory modules.
Store old memory boards in the anti-static plastic baggie in which the new memory boards were shipped.
(6) install (2) new 1GB SO-DIMM DDR333 boards, for total of 2GB of system RAM.
(7) reassemble system, and boot OS (operating system).
The laptop's ROM BIOS will auto-detect the new RAM and begin a standard POST (Power-On Self Test).
(8) If OS is MSWindows, it will also auto-detect the new memory, and allocate it to application software.
The technology of the Toshiba Satellite M35X-S349 memory module is called
DDR333, meaning DDR (Double Data Rate) SDRAM (Synchronous Dynamic RAM), at a memory bus speed of 333 MHz.
The Form Factor of the DDR memory card is SO-DIMM, which stands for Small Outline DIMM (Dual In-line Memory Module) (see photo).
Reference: http://en.wikipedia.org/wiki/DDR_SDRAM
Reference: http://en.wikipedia.org/wiki/SO-DIMM
Fig.3 Each 1GB SO-DIMM DDR333 memory module will look like this one.
The Toshiba Satellite M35X-S349 supports a maximum of two SO-DIMM memory modules.
Each memory module can hold (a) 256MB, (b) 512MB, or (c) 1GB,
in the SO-DIMM Form Factor compatible with the Toshiba M35X-S349 Notebook PC.
Dec 03, 2011 | Toshiba Satellite M35X-S349 Notebook
I have a tx1410 touchscreen hp laptop I have a black screen when i turn on my computer and all the buttons are lighting up. Everything works but the black screen. I put a dvd disk to boot it up and then...
First you need to check if you did not have any flash drive or device attached to your laptop when you turned it off. Because if you do, your system will not booth completely, you will only be having a black screen, and to solve that, you just remove your battery and insert in back then try to turn it on.
Ensure you have the battery fully charged. Then turn it on. If that does not help, then the problem could be a hardware problem, which could be that the module is faulty and the screen is not lighting up or the hard disk is disconnected or the RAM is not connected properly.
The module is like the flex on the laptop that assists the information from the motherboard be read on the screen. So if it is faulty then you will not be able to see anything.
For that, you need to open it up and replace the module. If it is the hard disk, just tighten the connection and the RAM too, then try to couple it back together and turn it on.
Try to hold down control+alt+delete to see if the task manager comes up, if it does, then you know it is not the module, then you select task manager and run an operating system disk, to format your hard drive and run a new operating system.
These are a list of most likely problems that can affect the screen of your laptop.
If you are not familiar with such technical activity (loosening the laptop), i will strongly advice you seek technical assistance from a professional, to avoid shock or further damage in the unit.
Take care and good luck
Oct 18, 2010 | HP Pavilion tx1410us Tablet PC
The laptop starts then black screen then restarts 25s later and it dosent stop.the hard drive maks a sound to.
The problem might be with the static charges on the motherboard, LCD screen, RAM or with the Hard Disk. Try the followings.
Remove Static Charges:
1. Disconnect the AC Adapter.
2. Remove the Battery.
3. Hold the Power button down for 30 seconds to 1 minute.
4. Reconnect the AC adapter and do NOT connect the battery now.
5. Turn on the Notebook power.
Still same, remove and reseat the RAM and Hard Disk. Check the below link for service manual.
http://h10032.www1.hp.com/ctg/Manual/c01602064.pdf
Refer to page 128 of 278 (Memory Module)
NOTE: If you have more than one memory module, you should test them individually to determine if one or both of them are faulty. Insert each module separately, then turn on the notebook to determine if the inserted module is working. Once you have determined which memory module is faulty, you can replace the faulty module and reseat the working module.
Refer to Page 123 of 278 (Hard Disk)
If still the same, you need to contact HP for hardware repair.
Sep 28, 2010 | HP Pavilion dv6000z Notebook
My computer often fails to start. even if the hard disk is running my moniter and keyboard doesn't show ant sign of power signal and the moniter screen just remain blank with power led of moniter blinking
Note: make sure that the computer is turned off before removing the RAM from the DIMM slot. Hope this helps.
Sep 27, 2009 | MSI 845 PRO Motherboard
Notebook won't start/lcd is blank but the power is on
You could have a faulty motherboard or RAM.
First remove the main battery and boot up the laptop without the main battery connected, if it boots up insert the battery, no need to power down. If that doesn't work, switch off/disconnect the adapter and insert the battery, then reseat the RAM modules and boot up.
If nothing works then you have a piece of junk. You can salvage the hard disk and put it into an USB hard drive adapter case and use it as an external USB hard drive.
Apr 12, 2009 | ASUS M51Sn-A1 PC Notebook
Disassembly
You didn't explain why you are taking it apart, but the two main reasons are Hard Disk drive Replacement
& memory (RAM) Replacement
The chassis of the computer is built sort of like the frame of a car
so I will detail how to do the two operations below
Hard Disk drive for 7510GX Laptop:
  1. Back up any data you want to transfer to the new hard drive.
  2. Before beginning, review electrostatic discharge (ESD) precautions.
  3. Shut down the computer, and then disconnect the power adapter.
  4. Disconnect the modem and network cables.
  5. Turn the computer over, and then remove the battery.
    1. Slide the battery lock to the unlock position.
    2. Slide the battery release latch.
    3. Lift the battery out of the bay.
  6. Remove the hard drive kit screw.
  7. Slide the hard drive kit out if the computer.
  8. If your new hard drive already includes the hard drive kit bracket, go to step 13. – OR –
Adding or Replacing Memory Modules
  1. Shut down the computer, and then disconnect the power adapter and modem and network cables.
  2. Turn the computer over, and then remove the battery.
  3. Loosen the memory bay cover screw.
  4. Remove the memory bay cover.
  5. To remove a memory module, locate the two clips on each side of a memory module, and then slowly press outward on the two clips at the same until the module tilts upward.
  6. Pull the memory module out of the slot.
  7. Hold the new or replacement module at a 30-degree angle and press it into the empty memory slot. This module is keyed so that it can only be inserted in one direction. If the module does not fit, verify that the notch in the module lines up with the tab in the memory bay.
  8. Gently push down on the SO-DIMM and make sure that the two clips on each side of the SO–DIMM click into place.
  9. Replace the memory bay cover.
  10. Replace the memory bay cover screw.
If you need to do something further, write back.
I hope that helps :)
TrustMe
Apr 16, 2008 | Gateway 7510GX Notebook
Qosmio g15 recovery disk error
If the discs are clean and pretty much scratch free, then this is most likely a bad hard drive. If you have another PC or laptop, try burning copies of the recovery cds and then use those. If the problem remains, you will need a new hard drive.
Dec 09, 2007 | Toshiba Qosmio G15 Notebook
Toshiba satellite monitor problems
Sounds like the memory module is bad. Return it or get a warranty replacement.
Aug 14, 2007 | Toshiba Satellite Satellite 5200 Series 15...
Computers & Internet Logo
23 people viewed this question
David Payne
David Payne
