Question about iTEKIRO Replacement Laptop AC Power Adapter Notebook Charger (EMACHINESTAC090W008T7M10) for eMachines E430 E510 E520 E525 E525-...
Webcam in emachines e430 not working
Was working prior to software updates,system restore not working
How can I manually put in a restore point on Win 7?
You can't make a restore point today to Oct 19th, but you could have made it then or see if there is such and restore to it.
Note that system restore might cause file loss, so back up any data you have!
Mar 03, 2013 | Microsoft Windows 7 Home Premium 64BIT...
Restore pc to oct 20
The dates are only available if a snap shot taken. They initiated by reboots or software installs / updates Win 7 - Start > Search type System Restore. XP - Is Start > All Programs > Accessories > System Restore. Now choose a date prior to problem. You may have to try a few dates.
Nov 16, 2012 | Gateway Computers & Internet
1152 error solution
try this one, i just read it on other forum hope it help.
First, is the software Vista compatible? Second, ONLY plug in the device AFTER the vendors software and drivers are installed. If you connect the device first either Windows (Vista) will install incorrect drivers or not find any drivers.
Use the System Restore and restore the PC back to a date PRIOR to first attaching the device. That will get rid of any issues with plugging it in first. Then check with the device vendor for any updated software and to verify that the software is Vista compatible, the vendor may already have a fix for the installation problem.
Sep 07, 2011 | Computers & Internet
Slow
Try testing the system (if a Dell or HP, there will be diagnostics available in the BIOS or during boot up). If everything passes the diagnostics, then you can either provide more details on when its slow, how its slow, when it started being slow, what may have happened prior to it being slow (dropped, updates, new software, antivirus, etc.), OR back up all your software and files and use the PC Restore to reinstall/restore to factory condition.
Aug 16, 2010 | Microsoft Windows? Vista Home Premium...
I purchased A HCL branded Windows XP Home edition with SP1 during the year 2004. Till now I have not used much. Due to development in software the latest version of antivirus could not be loaded. Hence...
First I'd try booting the PC, as its booting press the F8 key several times. This, with luck, will offer several boot options. Choose Safe mode. (A stripped out version of windows)
Assuming it boots into safe mode, Click on start - all programmes - Accessories - System Tools - System restore.
Restore to a date prior to the SP2 installation.
If all that works, update by going through the windows update software - Start - All Programmes - Windows update.
That will update your o's to SP3.
Failing that, without a copy of windows you're a bit stuck.
However, if you are stuck and don't want to pay again for an operating system, you could download and install "Ubuntu" for free. Its a linux based operating system. Just Google Ubuntu, all instructions are on the web page.
Jun 28, 2010 | Microsoft Windows XP Home Edition
I've been using my 5300C scanner with Windows XP for years. Now, all of a sudden, my computer can't find it. My scanner is connected. I tried re-installing the scanner software but my computer tells me...
Most likely your scanner was put offline by a microsoft update. Mine was knocked out of business by a hardware driver update downloaded from microsoft update.
Try to roll back the scanner driver (my computer, system, hardware select scanner, properties, rollback driver to prior version) or go to your system restore function and do a restore to a earlier date when you know the scanner was working and see if that fixes it.
Worked for me. Windows XP pro
Oct 14, 2009 | HP ScanJet 5300C Flatbed Scanner
I downloaded an update for vista and now my sprint smartview doesnt work. it keeps tryin to reinstall when its already downloaded while plugged in and then it searches for a dial tone. when i uninstalled...
First thing I would do is to restore your computer to a date prior to this update, by clicking Start-Programs-Accessories-System Tools-System Restore and select a previous date to when the bad update was installed. I personally would not expect Vista to have caused this problem though, but for a Modem.
Oct 13, 2009 | Computers & Internet
I have lost all sound
Reload your sound drivers. I had this same trouble with this same computer. If you dont have the software, go to HP/Compaq support page.
I hope this helps you
a
Sep 27, 2009 | Compaq Presario 5000 PC Desktop
A sony update came in and now i cant get on the enternet, network adapters are not showing in network connections
Was this a driver update?You can do a system restore to a day prior to the update,It will remove the update and restore your computer to a working state.You can find system restore under system tools.
good luck
Sep 14, 2009 | Sony PCV-RS620G PC Desktop
iTEKIRO Replacement Laptop AC Power Adapter Notebook Charger (EMACHINESTAC090W008T7M10) for eMachines E430 E510 E520 E525 E525-... Logo
Top iTEKIRO Computers & Internet Experts
David Payne
David Payne
Are you an iTEKIRO Computer and Internet Expert? Answer questions, earn points and help others
