Question about Sony Video Hi8 Ev-c100 Ntsc Video Cassette Recorder Magnetoscope
Tape isn't retracted into cassette upon eject on Sony EV-C100
I haven't used this deck in over a year and it has very low hours on it to begin with (>40 for sure) and went to use it the other day, when I put in a tape, it seemed to be jammed so I ejected the cassette. The cassette came out but the tape was unraveled back into the machine. I tried another tape with the same result. Any suggestions would be welcomed.
  • Michael Lyons Dec 09, 2012
    Thanks for the comments. I have taken the lid off the deck and inspected inside, there are no loose parts. I was going to put a tape in with the lid off to observe and see if I can determine whay it's not letting the tape retract back into the cassette when ejected but that means more damage to a tape.
    Top Expert:
  • Sony Master
  • 14,553 Answers
L would sacrifice a old or bad tape here, remove all the tape inside a cassette and tape off the small sensor holes on each side.
That way no tape to damage and you can insert it to see what is happening.
What likely is the issue is when stop it, it or if the tape does not fully load against the drum with heads, when the arms retract that pull the tape out of the cassette the mechanism is not switching to rewind it back into the cassette.
Usually this means a belt is slipping or the idler unit is not working---belts can break or stretch or even come off---belts will get slopply or bad from NO use and it is common.
Posted on Dec 10, 2012
  • 275 Answers
SOURCE: vcr jams on eject
What do you mean 'Tape crunches" Do you mean that there is tape slack, which then crunches when Tape is lifted during Eject? If that is the case, then the Supply Reel Roller Brake is bad. it is a Felt Pad, which needs replacing. If the entire eject operation is wonky, or if it's timing is bad, then I suspect that One of the eject Gears (On either side of the Mechanism) is damaged and needs to be replaced. One question, i assume that you are able to eject the Tape eventually, and so - Does the Tape Load into the VCR properly, when you insert it into the machine? This will help me in giving you a better diagnosis.
Posted on Mar 14, 2007
  • 158 Answers
SOURCE: Tape stuck inside
there is screws on the unit when the unit goes into rewind mode disconnect from mains and unscrew unit first check to see if the screws are scurity type haveng a hex or star shape on them if either then take to video and tv repair shop and explain that you need to remove a tape from unit you may have to pay for a small fee for it to be removed this part is all i can give but if you can remove screws yourself then locate the motor for tape ejet and load and manualy wind till tape is removed good luck
Posted on Aug 13, 2007
  • 1153 Answers
SOURCE: Tape keeps ejecting
You can check tape player for any type of object lodged in it. Maybe unplug and turn upside down to here anything inside. Or even any broken tape that come off inside. The only other thing is that the belts inside are worn and will not put device back in play mode.
Posted on Dec 22, 2007
  • 11 Answers
SOURCE: VCR keeps ejecting the tape
It needs Belts/Idler/Pinch roller.. If you UNPLUG IT, remove the cover you can wind the tape back manually....When you can get a DVD player.
Posted on Sep 28, 2008
  • 4234 Answers
SOURCE: Sony DSR-45 will not eject tape nor play,ff,rewind shows error
The generic error codes C32:xx indicate that a motor is not functioning. If you have not worked on these machines before, extreme caution is advised. These have extremely sensitive alignments that can easily be disturbed.
Please update this with your familiarity with these machines and I'll try to provide additional directions.
Thanks,
Dan
Posted on Feb 21, 2009
How to fix sony camcorder with tape deck that won't close. camcorder squeals and ejects tape.
bit late...but. STOP ASAP! by removing the battery, after removing battery, wait 20 seconds, re-fit battery & CLOSE the cassette door.
then wait 10 seconds, slap the closed door twice quite firmly. then open, if it opens, discard that cassette tape, clean the players head using cleaning tape.
use new cassette tape.
Jun 30, 2015 | Sony Video Cameras
Ev-c100 ejects on rewind
Try cleaning or replacing the mode switch.
Jul 28, 2013 | Televison & Video
Sony TC-WR690 doors will not open to remove the cassette.
If you remove the cover after unplugging the AC, you will see that when you push the eject button that on the back side the putton is held back by a white plastic piece. Push down the white plastic piece as you press the eject button. The door will open and the tape will release. I jsut did this today on my Sony TC WR 670 dual tape player. Both sides were blocked. I noticed that both fuses on the board were also blown. New fuses didn't solve the problem. May be that the transformer is out?
Apr 21, 2012 | Sony CASSETTE DECK Single Dual Cassette...
Unit accepted cassette, won't eject
It is likely that either the drive belt has broken or is slipping. Because the unit is still in "play" mode, the mechanism won't let the door open up. If you have not opened up these units before, do not attempt it now. This unit should be taken to an experienced tech for repair. Where are you located?
Dan
Apr 08, 2010 | Sony EVC100 Hi8 VCR
Cassette stuck in Sony TC-K611S deck
Rotate loading gear with your finger until mechanism released and set on stop position. press eject button and take out tape.
Jul 01, 2009 | Audio Players & Recorders
Tape stuck in uvw1800 beta cam sp
Use menu system to access "manual eject". Hold left arrow key and press menu to access menu. Follow from there.
Feb 22, 2008 | Sony Betacam SP Small Videocassette 30...
Cassette Tape stuck
Try pushing the eject button while pusshing the power button. Mine was doing the same and that is how I was able to eject the tape.
Good luck
sam
Jan 01, 2008 | Sony TC WE435 Stereo Dual Cassette Deck...
Sony Video Hi8 Ev-c100 Ntsc Video Cassette Recorder Magnetoscope Logo
174 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
