Question about Rapoo H6000 Bluetooth Stereo Headset with Microphone Blue
Bluetooth on iPad can't find the headphones device rapoo. I have switched on the headphones and the green light is flashing every 2 seconds but the iPad doesn't pick it up
Can I pair my Bluetooth earphones to my iPad?
How to pair Bluetooth headphones to IPAD?
Most headsets have a power button or a switch to turn the device on. Press the "Pairing" button on your Bluetooth headset, if necessary. Select your headset from the Devices list on the iPad's Bluetooth window. Enter the passkey or PIN for your headset, if prompted.
Does the iPad Pair With Bluetooth Headphones? ' Chron.com
smallbusiness.chron.com/ipad-pair-bluetooth-headphones-62883.html Search for: How to pair Bluetooth headphones to IPAD?
Dec 05, 2016 | Radio Communications
Need instructions to sync with iPad and I phone
Are the headphones Bluetooth?
Strictly speaking, not Synching, but Pairing. Synching is an exchange of data so that both devices hold the same data by transferring data from one to the other so they are both the same.
Switch on the headphones, Go to Settings Bluetooth on the iDevice and click Search. When found, click Pair. If is asks for a code put in 0000 (4 zeros).
May 08, 2016 | Samsung Radio Communications
Iphone won't find auvio device
Your iPhone might not find the headphones if they have been previously been used with another devices. I recommend holding the call button for 3 seconds until the blue light flashes and your iPhone might find them.
Mar 06, 2014 | AUVIO Bluetooth Headphones
How do i pair HP500BT with device
After charging, turn on headset by pushing the power button until the charging led turns red and flashes. continue to hold the button until the light flashes red and green. Go to your phone or device bluetooth settings page and search for devices, it should show up as TPRO HP500BT. Select device and select to Pair with this device. The light should start flashing red really fast, then it should be paired!
Dec 28, 2013 | Technical Pro HP500BT Wireless Bluetooth...
How do you reset bluebuds x ?
Go into the Bluetooth settings of your device and remove the headphones (forget them)
Power on headphones; press vol + & vol - to enter pairing mode (alternating red-green lights flashing); press and hold vol + & vol - for 8 - 10 seconds until the light flashed orange; the headphones are now reset to factory defaults; pair the headphones to your device.
I have to do this every time I install an IOS update on my iPhone.
Oct 20, 2013 | JayBird Gear LLC BlueBuds X
Rapoo H6060 red light doesn't go off
DUDE THIS SAME THING IS HAPPENING WITH ME BUT I BOUGHT IT YESTERDAY AND TODAY NIGHT IT SHOWS RED LIGHT CONTINUOUSLY! PLISS HELLP MEE
May 23, 2013 | Universal Rapoo H6060 Bluetooth 2.1EDR...
My iPad won't find my Bluetooth speaker
Go to settings, General, blue tooth and remove any "other" previous paired BT devices & Turn off BT, then go to Sett. General, scroll down to reset and reset network settings, this will not delete anything. Power off BT speaker. after iPad re-boots turn on BT Speaker First, make sure BT is off on iPad as well as WIFI-wait like 10-15 seconds and then turn BT on in iPad it should see your speaker now and let you pair it up.
Jan 14, 2013 | Harman Kardon JBL Flip black
Parrot bluetooth b250 xt alternating red and green flashing lights
While device is on hold both volume buttons for 6 seconds till you hear 2 tones. Then plug in factory supplied charger for 10 seconds. Unplug a d re-pair to your device
Nov 19, 2012 | VXI Corporation Blueparrott B250-XT...
Can not connect my 9xxBackbeat bluetooth headphone to my laptop. My OS (Win 7 x32) recognize this device but then it says it can download the driver to run this device
In order to use this headset, your built-in Bluetooth in your PC needs to support the hands free profile, audio and A2DP profile. If it does, all you need to do is hold in the power button on the headset until you see the light on the headset flashing red/blue, red/blue. If it doesn't you'll need to load it onto your computer. Once the headset is flashing red/blue your computer should find it.
Good luck from Headsets Direct!
Sep 22, 2011 | Plantronics Backbeat 903 Bluetooth...
Backbeat 903 I tried to pair them but they don't with my g1
1. turn off the headphones
2. turn on bluetooth on g1
3. hold down the power button on headphones until u see the red and green light flash back and forth. (may take 8 seconds or so)
4 search for devices on g1
5. pair them. if it ask for code it... 0000 (4 zeros)
Nov 16, 2009 | Altec Lansing Audio Players & Recorders
Rapoo H6000 Bluetooth Stereo Headset with Microphone Blue Logo
97 people viewed this question
Top Rapoo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Rapoo Audio Player and Recorder Expert? Answer questions, earn points and help others
