Question about Cannon Video Cameras
Need power pbc for cannon zr600 camcoder - Cannon Video Cameras
How do I fix error code E61?
No need of any special solution. I had the same issue/error message with my DCR-DVD01 - Sony camcoder which is now 9 years old.
What i did is the following? (weird steps):
1. Turn on the sony camcoder - while connected to wall power
source.
2. Keep a heavy cloth on top of your dinner table or kitchen island.
3. Hold the camcoder facing up in the regular way as you try to
record a new video.
4. Hold on the front of the camcoder & at the back and gently tap
on the heavy cloth (as if you are going to smash it & break it).
5. Do this 3 times.
6. Shut down the camcoder.
7. Restart the camcoder after 3-5 seconds.
Thats it.
This worked for me.
Sep 29, 2013 | Frigidaire Dryers
Can the canon zr600 use an 8 gb sd memory card
According to Canon's specs, the ZR600 uses DV tapes, not memory cards.
May 20, 2011 | Canon ZR500, ZR600, ZR700, and ZR800...
What is the maximum capacity of the memory card which the zr600 can accomodate?
You can find the information in the manual And you can read this ZR600 manual online page 124 in the bottom few line of words
The vision is blury and it keeps flashing E:61:10
E:61:10 is a lens error code. Could be a connection issue between the lens and the main board or a bad lens. You will need to have this looked at by an experienced technician. www.austintelstarservices.com
Aug 29, 2010 | Sony DCR-SR47 Camcorder
What type of "Gauge" wires should I be using for the Kicker ZR600 AMP (Power cable, ground, Speaker wire)?
The lower the gauge, the thicker the wire.
You want multi-strand, not solid. This has better conductivity and less resistance over distance.
10 to 8 gauge will be able to handle anything that particular amp needs.
Remember an in-line fuse on the power cable as close to the battery as possible.
The speaker wire doesn't really need to be anything special
Sound good? Pun intended
Best regards
Mike
Apr 05, 2010 | Kicker ZR600 Car Audio Amplifier
How many watts are in the kicker comp zr600 amp? i was told that it was a 1000 watt amp. i just want to make sure that it is a 1000 watt amp and not a 600 watt amp. i am powering two 15'' kicker comp subs...
  • Amplifier Type: Dual Channel
  • Bridgable: Bridgable
  • RMS Power at 4 Ohms: 150 W x 2
  • RMS Power at 2 Ohms: 300 W x 2
heres a link to a stats page for the zr600>
http://www4.shopping.com/xPO-Kicker-ZR600#keyFeaturesArea
Feb 05, 2010 | Kicker ZR600 Car Audio Amplifier
I have a kicker ZR600 was shorted i dont have any idea how fixed my problem the 6 power ic's was toasted
mmmmm toast is correct, you may be lucky, examine the unit, it may have a fuse that actually took the short and simply replace it, if this was bypassed then the internal banks will be fried {toast}. The cost of repairs will exceed a replacement cost, I wish you Good luck
Nov 20, 2009 | Kicker ZR600 Car Audio Amplifier
ZR600 problem
Does it blow the fuse before the remote voltage is applied or does it only blow after remote voltage is applied?
May 25, 2007 | Kicker ZR600 Car Audio Amplifier
Cannon ZR 60 camcoder Cassette copartment does not open
Loading unit problem is a common mechanical problem in camcorders. To remedy the problem, trained tech need to disassemble the mechanical system around the loading and replace few broken gears (plastics) and adjust it. Repair cost may run close to half of the new camcorder. If you really got to repair this camera for some sentimental reason or for special needs otherwise better to invest the repair charge into a new camcorder.
Mar 15, 2007 | Canon ZR60 Mini DV Digital Camcorder
Video Cameras Logo
21 people viewed this question
Top Cannon Video Cameras Experts
abdul rauf
abdul rauf
Andrew Taylor
Andrew Taylor
Are you a Cannon Video Camera Expert? Answer questions, earn points and help others
