Question about Ridgid 85937 SP-500 1/2 HP Submersible Sump Pump
Ridgid sump pump sp-330d - Ridgid 85937 SP-500 1/2 HP Submersible Sump Pump
3 Suggested Answers
  • 16 Answers
SOURCE: Where do I find replacement
ON LINE
Posted on Dec 30, 2010
  • 257 Answers
SOURCE: Ridgid Sump SP-500P On -Off
www.ereplacementparts.com is the most complete place I have found
Posted on Mar 07, 2011
Need to rewire a sump pump
If sump pump is under water, I would buy new one.
There is no certain method to ensure that wiring is sealed, and that electricity will not flow live.
Apr 12, 2013 | Ridgid 85937 SP-500 1/2 HP Submersible...
The vertical float switch won't trigger when the water levels exceed extreme water levels
Sounds like the switch is faulty. You have to get the model of the pump and get a switch at a electrical repair center.
Mar 19, 2011 | Ridgid 85942 SP-330 1/3 HP Submersible...
Wont shut off...nothing is blocking ballast...
the problem is with the switch it self some gung got down inside the switch itself or the switch went bad unplug if doing yourself and clean or replace
Apr 06, 2010 | Ridgid 85937 SP-500 1/2 HP Submersible...
How do you overhaul a submersible sump pump when it runs too often and takes a long time to shut off?
in most cases that is the switch that is attached to the pump you can buy a new one at home depo about 35.00 dollars that will make the sump go on and off properly
Mar 08, 2010 | Ridgid 85942 SP-330 1/3 HP Submersible...
I have a 3-year old SP-500 that failed and my basement flooded. (Lots of damage). The float switch appears to have failed. Is this a manufacture warranty item?
Not after three years. Some pumps are warranted that long but floats are pretty easily damaged, jammed, or put into compromising positions so that they fail to activate the pump when they should. Rigid, on the other hand are very strong in their warranties. Some tools have a lifetime warranty. It is worth a check, but even if they replace the pump don't expect compensation for the dammages you suffered from the flooding.
Nov 01, 2009 | Ridgid 85937 SP-500 1/2 HP Submersible...
Sp-500 I noticed the pump was running for 2 seconds and plenty of gurgling after. I then played with the float and it started to run a full cycle with no more gurgling. What causes that?
The "gurgling" is the sound that the water makes as it flows back down the hose and out of the pick-up point. You say that after playing with the float the pump started to operate properly, which would indicate that the float was either stuck, or not working like it should.
Oct 23, 2009 | Ridgid 85937 SP-500 1/2 HP Submersible...
Ridgid 85937 SP-500 1/2 HP Submersible Sump Pump Logo
Top Ridgid Electrical Supplies Experts
Steve
Gene Haynes
Are you a Ridgid Electrical Supply Expert? Answer questions, earn points and help others
