Question about Magic Chef MCBR445S1 Stainless Steel Compact Refrigerator
Magic Chef mini frig freezing everything.
The Magic Chef mini frig is freezing everything even at the lowest setting. It doesn't even seem to turn off. I suspect the thermostat, but I can't seem to find anyone with a replacement part. Help?
  • 7 more comments
  • Bob Mozer Dec 10, 2012
    Thanks for all the responses and I will consider them all. It also seems like the unit does not turn off. I can turn the temp control all the way to off and it seems to stay running. Does that help to narrow down the possible problem?
  • John Tripp
    John Tripp Dec 11, 2012
    nplug refrigerator and remove the two wires from the thermostat. Test the thermostat with a OHM meter forr continuity and that will answer your question....JT
  • Bob Mozer Dec 12, 2012
    Thanks John. I will try that.
  • Bob Mozer Dec 16, 2012
    Hey John...I removed the thermostat and found some loose pieces of copper cntacts floating around inside the part. I checked out the part you listed and it looks slightly different than mine (2 terminals on mine; 3 terminals on "yours"). I also found a tag on the part and couldn't find it doing a search. (WPF258-I02-022 0606.0003391.1) Think it matters? .
  • John Tripp
    John Tripp Dec 17, 2012
    Yes the difference may be important. Look this part over and call 800-269-2609 to insure that this is the correct part...JT http://www.repairclinic.com/PartDetail/T...
  • Bob Mozer Jan 03, 2013
    OK, John, now I have the right part, but unfortunately, I did not tag which terminal is for the black wire and which is for the white. Does it matter? or can you tell me how it needs to be connected?
  • John Tripp
    John Tripp Jan 04, 2013
    How many wires and how many connections on the thermostat? What are the colors of all the wires?
  • Bob Mozer Jan 04, 2013
    3 wires, 3 connectors; white, blk, and green. I know where the green goes; it's just the white and blk.. Would it be easier to call in with the part number?
  • John Tripp
    One of the terminals attaches to the tab that grounds the thermostat. The other two black and white does not matter which way they go....Thanks John Trippp
  • Magic Chef Master
  • 4,654 Answers
The thermostat is part of the temperature control found on page 6 here=> MCBR445S1_Parts_List Parts can be found here=> MCBR445S Parts If you have questions please let me know, Thanks Sea Breeze
RF-7350-59 Temperature Control Thermostat
Posted on Dec 10, 2012
2 Suggested Answers
toolkits
  • 1099 Answers
SOURCE: Magic Chef MCBR445W1 seems like it dosen,t stop
Most times this is a bad cold control, but there are other things to check for. Make sure the condenser fan is working and the coils are not covered with dust. A separated heat exchanger ( small capillary tubing soldered to the large suction line ) can separate from one another and make the fridge run too long. - tape tubing back together. A poor working evaporator fan motor could also make the fridge run too long and freeze - replace the fan motor. An inefficient compressor or refrigeration system could make the fridge run too long and freeze - have a service tech check this out. A misaligned control settings, make sure the air damper and cold control have not been bumped and are out of normal settings. Stuck open air diffusers or air dampers are becoming more and more common for allowing too much air to be blown into the fresh food section and freezing things. On all frost free fridge's the freezer temp air is blown into the fresh food section, if you have "easy" to freeze items ( eggs, veggies in water, etc ) in front of or under where the freezer temp air comes out, they could freeze - store them in a different spot. Doors not closing properly making the fridge run too long is something else to check for.
Check on the cold control if faulty, replace the cold control, not having found any other problem, do check on plastic air deflector at the top rear of the frig had been knocked off. replaced it if faulty. As you know, the deflector directs the freezer air toward the front of the frig and the rear of the cold control, which is now functioning properly.
Good luck.......
Posted on Aug 01, 2010
The Magic Chef Refrigerator Electronic Thermostat - SF-WB-4/CM will only cool to 45 degrees, Is it possible to change out the thermostat with another factory unit fom a standard mini frig ?
Putting another thermostat would not help it be cooler it actually stop it from functioning all together if it's not recommended by the manufacturer
May 08, 2014 | Magic Chef Refrigerator Electronic...
MY MAGIC CHEF, CONCEPT SERIES, W/MAGIC CONTROL CENTER DOESN'T LIGHT.
I have a Magic Chief Concept Series oven - Replaced the Thermo-coupler and the control switch. I now have a pilot light but the thermo-coupler doesn't get hot enough to light the burner, But if I take a lighter and put it on the thermo-coupler it will but when I take if off it shuts off after a few seconds. Could you please give me Ideas of what could be wrong
Dec 18, 2012 | Magic Chef Ovens
MCWC30MCG freezes reguardless of thermostat
Mine was doing the same thing. Needed a new thermostat. Part number is 1206856 or WDF18A-L or WDF22A-L depending on where you get it. $23-$25 easy repair you can do.
Jul 24, 2012 | Magic Chef MCWC30MCG Compact Wine Cooler
I have a magic chef ovan/mic unit, when I press the bake option and set the temp the igniter goes on but the gas does not kick in. model # 54FN-5TKVWM
even though the ignitor glows it doesn't mean it's good it opens the gas valve by amps not just because it glows,if you turn on the stove and when you see it glow if the flame doesn't ignite within 40 to 50 seconds you have a bad ignitor.if you leave it alone for a few minutes does the flame ignite?the only other thing it could be is a bad gas valve but most likely it will be the ignitor
Sep 25, 2011 | Magic Chef Ovens
My refrigerator is not working properly.. the freezer section is work fine.. but the other section is not getting cold...I bought this refigerator six months ago...the model is .. MCBR1010W
Your complaint is not unusual, except that you say the frig is only 6 mo. old. First, I suggest you call the manufacture for warranty service since the unit is still new. There are several items that could cause this problem. It usually will not help by playing with the controls for frig & freeze; the unit should work properly with the controls set at normal midrange for both frig and freez; changing the settings from normal cannot compensate for a mechanical problem. is the refrig in an enclosed space that cannot get good air circulation, or does this frig have the black grid coil in the back and you have the frig up against the rear wall so that no air can remove the heat from this coil ? Any other cause would require mechanical work within the frig components.
Aug 10, 2010 | Magic Chef Refrigerators
Good luck.......
Aug 01, 2010 | Magic Chef MCBR440 Compact Refrigerator
Freezer used as a frige?
it may be possible. Turn the temperature on the lowest setting and see what happens. If it still freezes everything up then it is not posible. If it doesn't freeze everything , then check the temperature with any temp probe. It should run at somewhere between 36 and 38 degrees. This is the normal cool setting on a refrigerator.
Nov 07, 2009 | Freezers
My Magic Chef mini fridge temperature trouble
That can be very difficult to do with a mini refrigerator. There is just not enough separation between the freezer and the refrigerator.
You will likely just have to find a compromise setting and accept the results.
Oct 20, 2009 | Refrigerators
MAGIC CHEF CTF1920ARA - Freezer works, Refrig. portion does not.
Sounds like a defrost problem. Check to see if there is any frost buildup in the back wall of the freezer. If so, it is not defrosting as it should.
  • possible causes:
  1. bad defrost timer
  2. bad defrost heater (in freezer)
  3. bad thermo switch in freezer
If you don’t know what these are then unplug the machine and let the ice melt in the freezer overnight with the door open. Then try it the next day, if is cooling fine then you need to have a service person replace one of the above items.
Jul 04, 2008 | Magic Chef Refrigerators
Magic Chef MCBR445S1 Stainless Steel Compact Refrigerator Logo
668 people viewed this question
Top Magic Chef Refrigerators Experts
evans_lloyd
Level 1 Expert
John Tripp
John Tripp
Lawrence Oravetz
Are you a Magic Chef Refrigerator Expert? Answer questions, earn points and help others
