Question about Wurlitzer Jukebox CD Player
WHERE IS THE BATTERY LOCATED THAT HOLDS PROGAMMING MEMORY WHEN THE AC POWER IS REMOVED FROM THE UNIT? MY MANUAL SAYS THERE IS A BATTERY BUT I CANT LOCATE IT.
MY UNIT IS AS NSM ES V NOSTALGIA GOLD 100 DISK UNIT.
    Problem Solver:
  • 18 Answers
I would open up the cpu case and you will probably find the battery on the cpu board. Most likely a 2032 coin cell, although I am not real familiar with NSM, most others use them.
Posted on Oct 05, 2013
2 Suggested Answers
  • 567 Answers
SOURCE: i have a nsm nostalgia gold jukebox that won't play a cd with a err 73
error 73=check alignment of cd gripper
Posted on Dec 14, 2011
Testimonial: "how do you check the alignment of cd gripper"
The alarm display in the lower right corner on model #RC40-A keeps blinking and will not stop. This happens with both wake 1 and wake 2 options. I fixed it once by unplugging the unit but it this did not...
Hello
Just reinstall the battries and adjust the time once again.
Battery back-up operation
* This clock radio is equipped with
a memory holding system that can
be powered with 2 "AA" batteries
(included). The power failure
protection circuit will not operate
unless battery is installed.
* When normal household power
is interrupted, or AC line cord
is unplugged, the batteries will
power the clock radio to keep
track of time and alarm settings
programmed into memory.
* When the battery backup functions,
the digital display will not light,
however, the function of alarm
still occurs during the power
interruption if remaining battery
power is adequate.
* Normal operation will resume after
AC power is restored so you will not
have to reset the time or the alarm
To install batteries:
1* Remove battery compartment door
(located at the bottom of the radio)
by applying thumb pressure to the
tab on battery door and then lift
the door out and off the cabinet
2* Insert 2 AA batteries (included).
3* Replace the compartment door
Replace batteries every year.
Power is fed to the unit even
when it is not functioning. To
cut the power supply off, the
power cable must be unplugged
OK.
Jul 10, 2011 | RCA Rc40 Clock Radio
Media buttons along top, power button, power indicator, and mousepad lights lite up as soon as AC power cord plugged in, without having to press power button at all. Nothing else ever happens, HD spinning...
1) Unplug unit.
2) Remove battery from unit.
3) Flip unit over onto it's top, showing the bottom to you.
4) On most HP's, there's a small compartment where your RAM is held. This is in the almost direct middle of the laptop. It should contain either 1 to 2 small screws. Remove the screws.
5) The door should be able to pull up and it will expose your memory.
6) Remove the memory (there are two latches that hold it in place on the sides of it, spread the latches and lift up on the memory.. you might feel a little pressure.. it's okay.)
7) After removing the memory, flip the unit back over, plug it in and power it on.
8) The unit will beep a couple of times and shut back off.. this is a good sign.
9) Remove power cable again, flip unit back over and reinsert the memory.
10) Screw the memory cover back down.
11) Reinsert battery, plug power cable in and try to power on again.
good luck, hope this helps! if it does.. please rate for me ! :)
Mar 29, 2011 | HP Pavilion dv2120us Notebook
Our rain bird was off and i changed the battery. I tried to turn it on manually and it says, no ac?
The battery only holds the program in the memory. The No AC message tells you that the AC power that is supposed to operate the valves is not getting to the control unit. Someplace there is a power cord with a transformer that is taking the house current at 120V and powering the unit. Something has been disconnected or a circuit breaker is tripped. If there is an outside socket with a GFI in it, try resetting it.
Paul
Sep 17, 2010 | Rain Bird Xerigation XCZ-075
Blank screen on laptop
Sorry to hear you are having problems. I have had this same issue before with this particular model. The following solution works 90% of the time.Perform a hard reset as the first procedure.
  1. Disconnect all peripheral devices and remove all USB devices and media cards. You want to test the computer not the accessories!
  2. Disconnect the AC power adapter, remove the battery, and then press and hold the power button for at least 15 seconds .
  3. Reconnect the AC power adapter (but do not connect the battery), Press the Power button, Look for glowing LEDs near caps lock and num lock keys, and Listen for sounds of a disk drive and fan turning.
Meaning of Sample Blink Codes for some EFI Notebooks Number of Blinks or Beeps Location of Blinking LEDs Component Being Checked Error Condition Continuous glow Battery power LED Battery The AC adapter is attached and the battery is charging, but does not yet have sufficient charge to power the notebook. 1 Caps Lock/Num Lock CPU CPU not functional 2 Caps Lock/Num Lock BIOS BIOS corruption failure 3 Caps Lock/Num Lock Memory Module error not functional 4 Caps Lock/Num Lock Graphics Graphics controller not functional 5 Caps Lock/Num Lock System board General system board failure 6 Caps Lock/Num Lock BIOS BIOS authentication failure Continuous blink AC power adapter LED Power adapter Insufficient power
Blink codes are often displayed after a user adds memory to the computer but does not seat the module properly. The LEDs may also blink error codes if a hardware component is loose because the computer was dropped or jarred. Some HP Notebook PCs come with one stick of memory but have two memory slots. The problem could be that the stick of memory or one of the memory slots has a bad connection. The memory module compartment on most notebooks is located on the bottom of the case. The exact position varies by model. However, on some models, the memory compartment is under the keyboard. See your User Guide for the exact location of memory modules on your notebook.
Use the following steps to remove and reseat the memory modules: Step 1 - Remove the electrical power To remove all power from the computer and prevent accidental damage to the electronic components, do the following:
  1. Turn off the computer by pressing and holding down the Power button for about 30 seconds.
  2. Unplug the AC adaptor from the notebook.
  3. Slide and hold the battery release latch to the unlock position.
  4. Use your finger to lift the battery up and out.
  • Remove the memory module cover on the bottom of the notebook .Loosen the compartment's retention screws and lift up and remove the memory compartment cover. Remove the memory modules from the memory slots To prevent damage to the memory module, grasp the memory module by the side edges. Do not touch the metal contacts.
    1 - Pull the retention clips away from sides of the memory module
    2 - Gently pull the module out of the memory module slot
  • Reseat the memory module by holding module at a 45-degree angle, and pressing it firmly into the memory slot until it is seated.
    After reseating the memory module, replace the cover over the memory compartment before restarting the computer
    Hope this helps FiYa! If you find this solution helpful, please take a moment to leave us some feedback.
    Thank You!
    May 12, 2010 | HP Pavilion dv9000z Notebook
    Power light shuts off after only 3 seconds
    Disconnect the AC adaptor from the laptop and remove the Battery pack from the Battery bay. Then, remove the RAM module and reinstall it after cleaning the RAM slot. Next, connect the AC adaptor to the laptop then try turning it ON. Please make sure that the AC adaptor is connected to a functional wall outlet. If the laptop still doesn't turn ON then you may try cleaning the Battery bay and the metal contacts in the battery compartment then insert the battery and try turning ON the laptop. If the laptop still doesn't turn ON then the issue is with the power supply unit.
    Sep 04, 2009 | Dell Latitude D600 Notebook
    My hp pavilion
    Follow the steps below to determine whether the problem is related to the AC adapter or your notebook system board:
    1. Remove the battery and disconnect all external devices from the computer.
    2. Hold the Power button for several seconds, with all power sources removed. This drains residual power from the system, and may correct many problems.
    3. Connect the AC adapter to a wall outlet and plug the other end into the computer.
    4. Press the Power button .
    5. Is the Power indicator light (LED) on or off?
    ****If notebook power indicator light (LED) is on, the AC adapter is working correctly***
    If the power indicator LED is off, the AC power adapter may need to be replaced. To determine if the AC power adapter needs to be replaced follow the steps below:
    1. Ensure that the AC adapter is plugged directly into a known working wall outlet.
      NOTE: To check the wall outlet, plug in a different known working device like a light, radio etc.
    2. Check all of the following connections:
      • The connection from the AC adapter to the wall outlet.
      • The connection into the power adapter from the wall outlet.
      • The connection from the AC adapter to the notebook.
    3. Press the power button again to test the notebook PC.
    4. If the power indicator does not turn on, remove the AC power adapter from the notebook PC and re-insert the battery. Then press the power button. If the power indicator light still does not turn on, then the AC Adapter needs to be replaced.
    *****Reseating the RAM may resolve this issue.****
    Step 1 - Remove the battery
    1. Slide and hold the battery release latch to the unlock position.
    2. Use your finger to lift the battery up and out.
    Step 2 - Remove the memory module
    1. Locate the memory module cover on the bottom of the notebook.
    2. Remove the screw that covers the memory module.
    3. Use your finger or a flat head screw driver to lift the inside edge of the memory module and remove it.
    4. Push both tabs outward simultaneously to release the memory module.
    5. Grasp the memory module by the edges and pull gently to remove it.
    6. After removing one module, replace the memory expansion cover and then replace the screw.
    Step 3 - Replace the battery
    1. Insert the battery into the notebook.
    2. Push the battery into the base enclosure until you hear a click.
    3. Connect the AC adapter and turn on the notebook.
    fter the memory is reseated, connect the AC adapter and turn on the notebook. If the notebook boots normally and the Windows desktop appears no further action is needed. If this problem re-occurs often, contact an HP Support Specialist to schedule a repair.
    Aug 12, 2008 | HP Pavilion ZV5000, ZV6000, ZX5000 Series...
    Acs 755 a2
    Basically your bios need resetting or clearing there are 2 ways, you can use your main board manual to locate the jumper as descrobed below or if you cant find it or that fails then proceeed to the other method described.
    .) Find the Jcmos or Jp1 or JBAT jumper located on the board. Its a 3 pin jumper currently set to 1 and 2,,, set it to 2 and 4 wait a few then set it back to 1 and 2.
    If you cant find the jumper or that fails then
    1. Locate the battery on the main board
    2. unplug the system then remove the battery and the memory(rams)
    3. press and hold the power button for 3 seconds
    4. release
    5. replace the battery then the memory (rams)
    6. pulg in the system and turn it on, it should boot
    7. load the optimised defaults by entering setup , follow the on screen instructions to do this
    8. thats it your done
    Jul 28, 2008 | Computers & Internet
    Will not power on
    NOTE: If the PC will not start up and you experience another failure not covered in this article, see Related links . After the memory is reseated, connect the AC adapter and turn on the notebook.
    Jul 25, 2008 | HP Pavilion ZV5000, ZV6000, ZX5000 Series...
    Help please!
    Power unit off. Disconnect AC power. Remove battery. Remove the memory cover screw, memory cover and the memory modules. Peel back mylar from JOPEN1 solder pad. Short JOPEN1 solder pads for 30 seconds. Replace mylar. Replace memory modules. Replace battery. Power up unit. If all is well, replace memory cover and screw.
    Feb 22, 2008 | Toshiba Satellite A135-S2276 Notebook
    I cant get it to even turn on
    remove battery and use it off A/C power adapter, mine only works this way, maybe shorted battery.
    Jun 28, 2007 | iRiver PMC-120 Digital Media Player
    Open Questions:
    See all Wurlitzer Jukebox CD Player Questions
    Wurlitzer Jukebox CD Player Logo
    128 people viewed this question
    Top Wurlitzer Audio Players & Recorders Experts
    phil
    Donald Chadwick
    Donald Chadwick
    Level 1 Expert
    Are you a Wurlitzer Audio Player and Recorder Expert? Answer questions, earn points and help others
