Question about Honda 25cc 4-cycle Mini Tiller
Fg 110 mini tiller by honda
Brand new, won't run for long while tilling
  • fordtl Mar 15, 2009
    Same problem. Had mine for going into 3rd year. Taken back twice. Rebuilt carb and a plastic line replaced at honda's expense the first time. My nickel the second for a carb rebuild. What's up with this machine????
    Problem Solver:
  • 5 Answers
I have had the same problem.
The first time the solution was to replace the rubber membrane underneath the primer bulb. Take off the bulb, then remove the plastic part underneath the bulb. There is a rubber membrane underneath that. The ethanol in the gasoline tends to deteriorate the membrane. The honda dealers sell them for about 14 dollars.
The second time the problem was caused by the gas cap, not properly venting. In this case the engine would start and run, but when I gave it full throttle, it would quit.
It got so bad that it wouldn't even run. I noticed when I loosened the gas cap it ran great.
So I took off the cap, removed the inner parts, and got a diaper in and pushed it though the holes in the plastic part underneath the cap, and through the rubber plug in the center. I did this a few times and check with my mouth to see if I could pull some air through the cap. When it breathed satisfactorily, I put the cap back on the gas tank and it ran great. Now it runs better than new.
Posted on Sep 11, 2011
  • 126 Answers
Is this a 2 stroke (or 2 cycle) engine requiring premix gas & oil? if so, is it mixed at the correct mixture? if only gas (no oil) was used, the piston will not have the lubrication required in the cylinder to keep it running.
also, after the tiller is warmed up, are you opening the choke? it will not run long with the choke on and warmed up. turn the choke off after a few minutes, then begin tilling.
hope this helped.
Posted on Jan 18, 2009
Honda FG garden tiller 110, stoped running, took it apart, the timing belt loose, what do I need to fix it? Or is it worth fixing?
I'm not aware of them having a timing belt. Do you mean the drive belt? if so, it is supposed to be loose. in the disengaged position. and tight in the engaged position. and to answer your question it is almost always worth fixing. unless you have a lot of money and want a new one. I've seen tillers 30 and 40 years old work just as good as a new one.
Jun 22, 2016 | Honda Garden
model was launched 1998
replace the timing belt sounds logical
take photos of how the crank and valve cam cogs line up before replacing the timing belt
Honda FG110 ROTOTILLER USA VIN FAAA 1000001 TO FAAA 1199999 Parts Diagrams
Just purchased a new FG 110 tiller it seems to run fine for a while then I have to release the throttle to keep it from stalling out. It has less then 20 minutes of use. I have installed the oil. It will...
It sounds like you may have a "lean" carburetor mixture setting on the high side or full throttle. This carburetor may have limiters or special screws that will make it difficult for you to adjust. You may try contacting a dealer to see if they could try adjusting it for you or just take the unit back.
Feb 20, 2011 | Honda 25cc 4-cycle Mini Tiller
Honda mini tiller cuts off when start tilling. runs great when held above ground with no load. cut off seems to be associated with the movement and shacking when tilling ground.
Hi thermo259, sounds like the high speed adjustment is lean, find the high speed screw and turn it counter clockwise 1 half turn and see if that helps. Should cure it.
Dec 10, 2010 | Honda 25cc 4-cycle Mini Tiller
While operating the Honda FG-100 mini tiller, the tiller suddenly stopped turning. The engine runs fine. I couldn't find any advice in the manual. Any help would be greatly appreciated.
If the tines become jamed, the tiller will stop. This is especially true if you are preparing your lawn for seedng without doing an preparation of the ground. Also, check you accerleration line, there may be a loose connecton.. Otherwise, sounds like a service issue.
Aug 28, 2010 | Honda 25cc 4-cycle Mini Tiller
Tines rotate slow when I try to till.
The clutch is non adjustable if the clutch fails you will have drive all the time or it slips. if the tines spin at the same speed with the engine at low and high speed the clutch might be slipping, the common cause for this is the gear box is partly siezed due to no grease being pumped into it, most ppl dont even know about this untill its too late. you have to remove the LH side tines to get to the screw.
Jul 01, 2010 | Honda 25cc 4-cycle Mini Tiller
What type fuel; and mixture for honda fg 100 mini tiller
the Honda FG100 is a 4-cycle engine do NOT mix oil with the gas, - you will cause damage to the engine (head, valves, piston rings etc) not to mention if will not run well.
Mar 08, 2010 | Honda 25cc 4-cycle Mini Tiller
I have a Honda mini tiller FG-100. Haven't used
You need to check your engine oil on a very level surface.
Its all too easy to over fill these engines with oil and the results can spell disaster if not rectified. On a level surface, with the machine level (not tipped forward) the oil should just be reaching the top of the threads for the bung. Any more than that and you have to much in.
This symptom can also be caused of incorrect storage .ie the machine being left on its side allowing oil to fill the exhaust box.
Check your oil level first then run the machine until the left over oil in the exhaust box has been burnt off. I would then advise either replacing the spark plug with a new one or cleaning your existing one and checking / replacing your air filter
Oct 10, 2009 | Honda 25cc 4-cycle Mini Tiller
Dethatcher pins on my accessory for the honda FG 110 are broken
Jan 29, 2009 | PDP Systems Dethatcher Attachment for...
Honda 25cc 4-cycle Mini Tiller Logo
1,700 people viewed this question
Top Honda Garden Experts
John Trevino
Are you a Honda Garden Expert? Answer questions, earn points and help others
