Toshiba Qosmio X505 Q894
How do I know witch one of the USB port are the faster to plug? On Qosmio X505 Q894. I have look for these question and I dint find anything at all. Thank you
  •  squirt
    squirt Dec 11, 2012
    Thank you everyone for your sugguestion. USB works fine. I jus wanted to know witch one works better. I move allot movie files and I just wonder witch one was the main USB to plug 3.0 USB so I cant move/transfer files allot more faster. Agasin Thank you! Art M
  • 32 Answers
You have 4 usb 2.0 ports. They are all the same speed.
Posted on Dec 10, 2012
  •  squirt
    squirt Dec 11, 2012
    Thank you very much for you support, with my question.
  •  squirt
    squirt Dec 13, 2012
    Base In the manufactory one of the USB plug is the fastes, but how can I find this Information I am looking for? Or what is the better port to use to transfer movie files.Thank you
  • 24 Answers
SOURCE: I have a toshiba satellite A-135 laptop that will
Check to see if one of the USB ports is damaged. Sometimes they can be damaged and have connections touching the outside metal of the port which actually grounds the connection and will cause the other ports to not work either. If it is connected then use a flat tip screw driver (*with the machine off and battery out*) to make it not touch the outside of the usb port and try "other" USB ports that aren't damaged and see if it works. If it doesn't then you are looking at needing a new motherboard. Locate your closest ASP and take in for service, you can find them at support.toshiba.com.
Posted on Nov 19, 2009
mailtoravi
  • 186 Answers
SOURCE: USB
First of all, I recommend you to Uninstall the USB Devices from the Device Manager and reinstall the Chipset Drivers as per the instructions below :
Click on Start and then on Run.
Type devmgmt.msc in the Run Command box and click on OK.
This will open the Device Manager window.
In this, click on the + mark next to Universal Serial Bus Controllers which will display additional USB Entries.
Right click on each of the entry and select Uninstall.
Click on OK if you get any confirmation window. Repeate the same process untill there are no entries left under Universal Serial Bus Controllers in the Device Manager window.
We are done with uninstalling the USB Drivers from the Notebook.
Now, restart the Notebook and close any window which says 'Found new hardware'
Now, download and install the Chipset Driver in your Notebook from the link below :
http://downloadmirror.intel.com/8178/a08/infinst_autol.exe
Save the file in the Notebook and double click to install the Chipset Drivers.
However, if the issue with the USB Ports persists, I recommend you to check again with different devices to confirm if the issue is with the USB Ports of the Notebook itself.
If the Notebook doesnot recognize any of the USB Devices after installing the Chipset Drivers, you may need to get the USB Ports of the Notebook replaced or go with a PCMCIA USB Card.
Hope this helps....
Posted on Nov 18, 2008
mariolands
  • 2296 Answers
SOURCE: I have a Toshiba Qosmio X505 that has two files
If it is a bad virus that won't let you do anything on the computer, follow the instructions on this link. If you can install programs on your computer, follow only steps 7 and 8 from the above link.
If you still want to go further with the recovery CD, follow these steps. Power off the laptop. Press and hold the 0 (zero) key and at the same time, press the power button once to switch on your notebook. When the machine Starts beeping; release the 0 key. When prompted by the warning screen; select Yes to continue with the system recovery. Select Recovery of Factory Default Software; click Next. Select Recover to out-of-box state. Click Next again. Click Next to Start recovery.
Posted on Jan 05, 2011
  • 492 Answers
SOURCE: i just got my toshiba
depends how u have windows mobility set is it set to power saver but usually they advertise that the battery will last 4 hours but usually most wont but it does have alot to do with ur mobility settings
Posted on Feb 01, 2011
Es187
  • 71 Answers
SOURCE: my qosmio toshiba model x505-q882
If it isn't already, try plugging it in, it might have run out of battery power. Otherwise, you would have to remove the top shell of the computer (where the keyboard is housed) to get to your power button to make sure it's plugged into the motherboard properly, unless it's still under warranty, in which case, you could send it in and have them do it for you, so long as it wasn't the first problem. If it's not under warranty, and plugging it in won't work, just post a comment here, and I'll help you with making sure the power button is plugged in.
Posted on May 08, 2011
Beep codes
Did you solve the problem? I have the same here, in Brazil.
Apr 14, 2014 | Toshiba Qosmio Computers & Internet
Why it makes noise when I close my notebook's lid
maybe mic problem . please close the sound and test again.
Oct 23, 2013 | Toshiba Qosmio X505-Q8102 18.4" Notebook...
Toshiba X505-0885 screen keeps going blank and I have to reboot, anyone know what is wrong
In the Tray Notification Area right click the Power/battery Icon, Open Power Options, Change to High Preformance, click on Change Plan settings, Plugged in , mark, Never, Never. click on Change Advanced settings, Change setting to your preference. If you haven't cleaned your fan and vent, take a look, also make sure there is sufficent air flow, unblocked, from bottom of laptop to side vents. A loptop cooler is a option.
Dec 13, 2012 | Toshiba Qosmio X505-Q894 18.4" Notebook PC...
Blue screen after windows update
Reboot, unplug, remove battery, plug in, push on/off button. respod to post for further suggestions.
Nov 18, 2012 | Toshiba Qosmio X505-Q894 18.4" Notebook PC...
Where can I download drivers for Toshiba Qosmio X505-Q8102?
i guess every laptop comes with a driver dvd. if u dont have the dvd then go the place from where you had got the laptop or else ask ur friends abt the driver dvd if they have.
Mar 04, 2012 | Toshiba Qosmio X505-Q8102 18.4" Notebook...
My qosmio toshiba model x505-q882 wont turn on when i try to press the power button i just got it by mail a few days ago so i don't understand what the problem may be.
May 08, 2011 | Toshiba Qosmio G25-AV513 Notebook
Hi I need Service Manual (Repair) for Qosmio X5O5-Q850 I WILL BE HAPPY TO PURCHASE IT TOSHIBA WILL NOT SELL IT Best regard H.L
No need to purchase anything, t1lavih.
Here you go,
http://www.tim.id.au/blog/tims-laptop-service-manuals/#toc-toshiba
I would like you to go down to the line that begins with Qosmio, and click on X500.
The Toshiba Qosmio X505-Q850 is part of the Qosmio X500 series of Notebook PC's.
This is a PDF file.
You may have to allow up to 30 seconds to see the first page, and additional time for the file to fully download.
You will be only viewing it. If you wish to save it to your computer, and do not know how, please state so in a Comment, and I'll be happy to lead you through it.
This way you can then burn it off to CD disk for safekeeping, and delete it from your computer to save harddrive space.
I would also like to include this,
http://www.irisvista.com/tech/laptops/Toshiba-Qosmio-X305/laptop-disassembly-1.htm
Not your laptop, but I thought the pictorial guide may help.
ALWAYS remember to follow Anti-Static Precautions.
If you have further questions please state in a Comment.
Regards,
joecoolvette
Mar 07, 2011 | Toshiba Computers & Internet
I have a x505-q880 qosmio laptop it has a poweron password on it and toshiba will not help me because I was not the 'original purchaser' of the machine and can not come up with the proof of purchse other...
If you have a Windows password reset disk, you can easily reset forgotten Windows password with it. If not, you can follow the steps to create one. You just need an available computer
which can link to the Internet.
Step 1: Download and install Windows Password Breaker with the available computer.
Step 2: Run the program and burn a Windows password reset bootable CD/DVD or USB flash drive.
Step 3: Reset your forgotten Windows password with the created disk or USB.
It is easy and safe.
Feb 10, 2011 | Toshiba Qosmio X505Q880 (PQX33U01J00H) PC...
I just got my toshiba but it only lasts 2 hours when its suppose to last 4 hours - TOSHIBA QOSMIO Q894
Feb 01, 2011 | Toshiba Computers & Internet
Computers & Internet Logo
73 people viewed this question
David Payne
David Payne
