Question about HP LaserJet M1005 All-In-One Printer
How to solve scaner error 12 - HP LaserJet M1005 All-In-One Printer
    New Friend:
Posted on Dec 24, 2012
Sir the scaner hp scanjet7710a show error code on screen adady no work any button . how can i solve this problam
It would depend on what the error code is for how to fix it - if in doubt call HP support in your country, they will be able to help best
Sep 06, 2016 | HP Office Equipment & Supplies
Scaner problem
hp laserjet m1005 display the scanner error 12 how can i solve this problem
Mar 22, 2014 | HP LaserJet M1005 All-In-One Printer
How can i solve this E244 error code
A E244 error code deals with the scaner. When you turn the copier ON will the scanning lamp turn ON? If it dose and you make a copy and thhe scaner moves & start to make a copy and then codes out. The problem is the BLACK scaner power cable has a crack in the coatting and is arching out to the frame o the copier..... It is not a easy fix.... If the scaner lamp is not turning ON???? You may have a blown Lamp or thermal fuse.... You can still find these parts..... The code will not go away till the problem is fixed.. Good Luck
Oct 21, 2011 | Canon NP 6035 Copier
Hp laser jet m1005 mfp scanner error 12 problem print ok
hi
1. check for driver update
if not resolv
2. Firmware Update
if not
3. the motor of the scaner is damage
May 30, 2011 | HP LaserJet M1005 Printer
HOW TO SET HP LASERJET 1005 PRINTER SCANER ERROR 12
how to solve engine scanner error for hp laserjet p1005
Oct 10, 2010 | HP LaserJet M1005 All-In-One Printer
SCANNER ERROR 12
it is a physical brocken piece that supports scanner mechanism.
if you open that plate /scanner mechanism and if you drill that plastic sheet and try some manufactureed alluminium or metal projection and place it in the hole drilled by you and put washer and screew so that that supports ;the scanner mechanism and your scanner /printer works . the scanner mechanism may costs you around 3,000-00 rupees.
Mar 19, 2009 | HP LaserJet M1005 All-In-One Printer
Technical suport
Try checking the fuser section,
1- bad thermistor
2-bad thermofuse
3-bad fuser lamp
Aug 07, 2008 | Office Equipment & Supplies
Scaner not workr
Hello, are you saying your scanner will not work with your OS windows xp? Did you pc tell you it had a problem with the driver. I need you to please post the exact error message thanks. lilacgerry xxx
Feb 10, 2008 | Computers & Internet
HP LaserJet M1005 All-In-One Printer Logo
61 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
